Double Butted Reynolds 531 Seat Tube Inside Diameter?
Gear Hub fan
Bikes: Civia Hyland Rohloff, Swobo Dixon, Colnago, Univega
Per what i have read most standard bicycle tube sets have a particular seat tube inside end diameter which varies by make and type of tubing.
Does anyone know what the inside diameter of the Reynolds 531 double butted seat tube is and what the correct diameter seat post should be? My recently bought Peugeot frame with French language Reynolds 531 sticker on it had 26.0mm seat post installed as bought. I suspect this may be incorrect.
it would be 27.2 however there are allot of "but"
-there are many other (mostly high quality) tube sets that are 27.2 as well
-it may be straight guage and not double butted but still be 27.2 (might be wrong on this)
-the 531 in taller bikes was of a thicker guage
it would probably be easier to just identify your frame model and year, then lookup the corresponding spec's
Quoted: 443 Post(s)
Liked 27 Times
My '74 PX10 takes a 26.4.
Bikes: Cinelli, Paramount, Raleigh, Carlton, Zeus, Gemniani, Frejus, Legnano, Pinarello, Falcon
Quoted: 12 Post(s)
Liked 8 Times
I think it varied. I've had 26.8 to 27.2 fully butted Reynolds English bikes, and the French bikes were even smaller inner diameter...
hmmm interesting, so you mean the 531 for some french bikes ie: px10 had differing wall thicknesses from the 531 used by other manufactures. or am i getting this totally wrong
Quoted: 443 Post(s)
Liked 27 Times
French bikes used metric-sized tubing. The outside diameter of a Peugeot seat tube is 28mm instead of the normal 28.6mm (1 1/8"). That's why they take odd-sized seatposts and why some clamp-on front derailers tend to slip on French seat tubes.
Decrepit Member
The French used a different size Reynolds 531 tubeset than everyone else.
The British/I.S.O. standard seat tube outside diameter is 28.6mm, while the French standard seat tube outside diameter is 28.0mm.
Seat tubes are single butted, not double-butted; the butted end goes into the BB shell. The most common British/I.S.O. 531 seat tubes have 0.9mm walls on the BB shell end, and 0.6mm walls on the seat post end. 2 x 0.6mm = 1.2mm, which, when subtracted from 28.6mm, yields an inside diameter of 27.4mm. However, the tolerance on the wall thickness and roundness of the seat tube made it so that you rarely could fit a 27.4mm post inside, even before brazing. And then, the seat tube always got distorted during brazing, making it even less possible to fit a 27.4mm in there, but a 27.2mm fit nicely.
My guess (and this is only a guess!) is that the French 28mm O.D. seat tubes also have 0.6mm walls on the seat post end, so 2 x 0.6mm = 1.2mm, and 28mm minus 1.2mm = 26.8mm. Then subtract 0.2mm for the wall thickness and roundness tolerance, and distortion from brazing, and you'd get a seat post diameter of 26.6mm.
EDIT - I just read Dirtdrop's response that his PX10 takes a 26.4mm seat post. That passes my sanity check...
Quoted: 413 Post(s)
Liked 109 Times
I received an e-mail from Reynolds awhile back and it basicly stated the I.D. could vary from 26.6 to 27.2 depending on the tubes being Imperial or Metric, the set your starting with and a manufacturer boring out the tubes.
I asked, "what size seatpost does 531 tubing accept?"
Reynolds reply: (Peugeot switched to Imperial tubing around '81-ish)
this is really difficult to reply to.
>You see when we supplied Peugeot we did supply tubes that were metric size
>(28.0mm outside) and imperial (28.6mm outside).
>Then in each diameter the thickness of the tube was also supplied, 0.7mm or
>0.55mm.
>The frame builder would also ream the inside of the tube, so really it could
>be a 26.6, 27.0 or 27.2 depending on the seat tube and reaming done.
>0.55mm.
Gear Hub fan
Surf Bum
Bikes: Lapierre Pulsium 500 FdJ, Ritchey breakaway cyclocross, vintage trek mtb.
Quoted: 13 Post(s)
Liked 5 Times
FWIW, my 80s Reynolds 531 frame takes a 27.2 seat post. Same as my '07 Bianchi aluminum frame...
Disraeli Gears
1. I have a Jeunet frame that is certainly R 531, since the fork blades still have Reynolds decal remnants, and the frame is fairly light, too, for a 63 cm height. But the seat tube measures 26.0 or 26.2. I haven't built it up, so I haven't had my trusted LBS check this out (I have only a dial caliper), so it may be, like you say, a larger seatpost that someone fit a too-small seatpost to along the way. But my bet is that because the frame is so large, the constructor used straight-gauge tubing.
2. I do have an English (Falcon) frame that came to me with a 25.4 mm seatpost. The seat tube was ovalized at the top, measuring 26.6 at the max (athwart) and 25.8 min (fore-aft). I re-rounded it to the best of my ability using a stem in conjunction with a brass shim, and patiently tightening/checking/tightening/checking. I got it pretty round (26.2- x 26.0+), then took it to the "professionals." They at first thought that it would take a 26.2; but using their reamer and trial posts, they determined that it actually took a 26.4! They showed me with a very long post that went right down the tube. I'm virtually certain that this bike is not DB tubed, because it's not light, and the tubing is seamed, not seamless. And if it were DB tubed, it's more than likely that the seat tube would be single-butted anyway.
OTOH, you might have a bike with a single-butted tube that's just got a bit thicker wall than Reynolds suggested to miamijim. Then too, a 26.4 mm PX-10/Simplex post just sold on eBay. Best course is trial and error, with the proper tools.
Quoted: 443 Post(s)
Liked 27 Times
That Simplex post on eBay is steel, for a sixties PX10. Otherwise I'd bid on it.
I'd much rather have a correct Simplex post than the high zoot single bolt Super Record post I have in there now.
Señor Member
Quoted: 1492 Post(s)
Liked 1,095 Times
RE: Charles Wahl:
my wife's reynolds 531 extra leger '81 andre bertin c70 uses a 26.6 seatpin
Since Reynolds apparently drew the metric-sized tubing to the same wall thickness used on Imperial-sized tubing, and the standard seatpost for a 70s/80s R 531 Imperial tube was 27.2, it stands to reason that 26.6 would be correct for a Frenchie (0.6 mm smaller OD).
Quoted: 3811 Post(s)
Liked 6,711 Times
Another data point: I picked up a frame recently that I believe is a 70s Allegro--Swiss made w/ French threading and sizing. It still has remnants of its Reynolds DB 531 sticker, and it takes a 26.6mm seatpost.
Neal
Neal
Bikes: Schwinn Paramount P15, Fisher Montare, Proteus, Rivendell Quickbeam
Quoted: 12 Post(s)
I have a 74 Motobecane Grand Record that is DB 531. It came with the original Campy seatpost and is 26.4.
My 73 Raleigh Super Course is straight gauge 531 and also takes a 26.4 seatpost.
Quoted: 413 Post(s)
Liked 109 Times
From Reynolds:
I suppose that could be interpreted to mean French, Spainish and Swiss bikes woud take a 26.4 or 26.6 while the rest would take 27.0's or 27.2's.
In the 1970's there was only France, Spain and Switzerland that used metric tubes.
Light Makes Right
Bikes: Gianni Motta Criterium, Dean Hardtail
Gear Hub fan
Some very interesting bike history coming out here so I am glad that I asked the original question. I, obviously along with many others, was not aware of the Metric versus English 531 tubing size difference. Always something new to be learned.
Quoted: 16 Post(s)
Liked 24 Times
In the English sizes there were 3 weights of 531. SL, Standard, Heavyweight (Later called Tourist, I assume at the suggestion of a marketing type.)
The SL and the Standard both had nominal 27.46mm seat tube IDs. The butt was thinner on the SL. Some skilled builders such as Chris Kvale would occasionally have so little warping that they could use 27.4 seatpost.
Heavyweight/Tourist had a nominal 27.15mm seat tube ID. My Jack Taylor Lugged Tourist takes a 27.0 seat post.
BTW My 23" 1957 Raleigh Record Ace 531 frame weighs only 4 lb. 3oz. yet takes a 1" seat post. Raleigh brazed in an internal sleeve so dealers would only have to stock one seatpost size.
