Surly LHT
Surly LHT
Looking at a used LHT at a local bike shop. It's olive green, but they don't know what year it is. Does anyone there have an answer for me?
Mark
Mark
Ozark Hillbilly
Bikes: Long Haul Trucker
Quoted: 136 Post(s)
Directly quoted from the Surly website FAQs | The Information Hole | Surly Bikes:
"You know that serial number on the underside of your bottom bracket? No?! Ok, so flip your bike over and take a look closely at the bottom bracket shell (the cylinder at the bottom of the frame around which your crank rotates). There will be a code stamped into the shell starting with the letter "M". Sometimes this stamp has a bunch of paint that has collected in it but look closely, it is there, I promise. The following number after the M signifies the last digit(s) of the production year of your frame. So, for instance, M2598144 was made in 2002, M8128666 was made in 2008 and M10034269 was made in 2010. Now write down the serial number and keep it somewhere you can find it in case your bike gets stolen. This might be the only identifiable mark on your frame if it comes back to you!"
Surly has all their catalogs online. You could check there, assuming it's the original paint job.
I just did a Google search and came up with 2008-2009 ( they keep same colors for 2 years).
I doubt it matters .. all that changes is the paint color.
<adding> It was in a shop, but you came here to ask people who can't even see it?
WRT to LHT framesets, rear dropouts changed to Breezer-style in 2008/9. Fork changed in 2012 to include bosses in fork crown. No other changes (that were made public knowledge) other than color since beginning of model production in 2002.
sage green=2002-2004
olive green=2008 Some of the olive green (darker color than the original sage green) have Breezer dropouts:
https://pedalrevolutionblog.files.wo...011/02/041.jpg
If your olive green LHT has breezer dropouts, then it's late production 2008, or 2009, since color runs didn't necessarily start/end with calendar years.
Olive green, great color = 2008. I loved mine but traded it for a LHT Deluxe frame (S&S couplers & mid-night blue). There's only subtle changes from year to year, none that would concern me. If it fits and you like it, get it.
LHT in Alaska, 2011
LHT in Alaska, 2011
Quoted: 18415 Post(s)
Liked 15,541 Times
Liked 15,541 Times
By the way, you probably need to work on your approach to answering people's questions.
I did find out that it is an '11
Mark
Mark
Liked 15,541 Times
I have a '10 or 11 in black. Not sure which. I had an earlier model but it was stolen out of my house near the end of '11.
Does it have Alex Adventurer rims? Mine does, which is why I asked. I think those rims were discontinued and that later model LHTs have something else.
Taking the old girl for a three-day starting tomorrow.
The bike doesn't look like one gathering dust in a shed.
How bout one of your Deluxe?
Thanks for sharing.
Not sure about the rims. Going this weekend to get more details. The serial number begins with M11....., so I ASSUME that it is an '11. The color is green.
I'm no expert on this stuff, so I'm asking people who I hoped would know. There are some of you here that seem very knowledgeable, but don't seem like you want to help. I am retired and spend a lot of time on forums, mostly hockey and bicycles. I know your type is out there, but still will never understand why someone would answer the way you do. If you think I'm asking too much and don't want to help, then simply don't answer. Easy enough?
Mark
Mark
Bikes: Surly LHT 26in 52cm 2008
You must be relatively new here.
2008 Surly LHT 26in 52cm
my front Rim is Velocity Cliffhanger 26in 36holes 28mm wide
my Rear Rim is Sun Ringle Rhymo lite XL 26in 36holes 29.2in wide
@MJH - Hey Mark, are you still going this weekend to check out this bike? I'm interested to hear what you find out. I've had two different Surlys - a Cross Check (which I bought new & sold 4 years later for $99 less than when I bought it new! In my market, they hold their value). I bought. 2015 Straggler 659b in August that I love. They're not the lightest bike, but you can transform them into just about anything.
Good luck and please post back what you find.
Planning on going. I'll let you know what I find out.
Mark
Mark
Land Between The Lakes Rec Area, 2014
Ottawa National Forest, 2015
Sleeping Bear Dunes, 2015
OK, I went back to look at the bike today. It does have a M11..... serial number, but according to the catalog (thank you Velocivixen), it is a 2012. It is dark green, not olive green, so my bad. The rims are Alex rims of some kind. Pretty solid looking. Although I really don't need everything that is included, it does have a Brooks B17, nice pump, Topeak rear rack, and a light set. Oh, disc brakes. Never had those before.
I can't ride right now because of cataract surgery, but did ride it the other day. Pretty darn sweet. I've been salivating about a LHT for quite awhile now, so I bought it. They are putting interrupter brake levers on for me and raising the bar a bit. I've been riding a flat bar for some time now, but really want to try this. I did 120 miles on the Katy trail last weekend and, although some of it is on me for not being as ready as I should have been, I had some real pains on the ride. Back and neck and even my bottom on my pretty well broken in Brooks. I want all of the hand positions. I really want to take some longer tours next summer. Also want to at least do a metric century next summer, too.
Thanks for all those that helped. I'll try and post pictures when I get the bike.
Mark
Mark
Quoted: 3459 Post(s)
Liked 1,465 Times
Quoted: 5 Post(s)
Get a professional bike fit by someone who understands touring.
It will be worth the money.
Mike
The shop is going to do that. I do trust them, plus I know how I want to feel.
I'm dying to ride, not just because a new bike is coming, but I just want to get out there.
Mark
Mark
How do you put pictures on a thread? They're on my phone so would like to do it from there. Thanks in advance.
