Campy experts tell me what I just bought please!
Quoted: 1079 Post(s)
Liked 1,899 Times
(I didn't buy that one, I found another one cheaper.)
I don't think I'll need to re-dish the wheel. The sprockets will just shift 1mm towards the drive side independent of the hub and rim.
And I gather that converting the shifter to friction will not give you the Doppler action in the C-Record that prevents autoshifting, correct? i.e., there's no friction clutch in the mechanism that senses the direction that you're pulling or pushing the lever. The resistance to autoshifting resides in the notches
I'm excited I might get the index shifting working if I can get that D-ring tight enough though!
Liked 1,899 Times
I’ll install the spacer when that arrives and see if it makes any difference, but to be honest I’ve been riding around in friction mode and everything is singing, so I won’t be too disappointed if it doesn’t work.
Thanks for your help though!
