Picked up my 89 Ironman Expert today and have a few questions.
Bikes: 1983 Univega Super Strada, 1986 Panasonic DX5000, 1984 Fuji Team 85 Univega Gran Turismo, 1984 Lotus Unique, 1987 Centurion Expert, 1987 Centurion Ironman Master,
Quoted: 677 Post(s)
Liked 459 Times
Picked this up today and it seems to be in great shape except for the RD cable being frayed and the problem with the RD shifter.
When I turn the D ring on the shifter it turns but doesn't click and the red dot which I assume changes to one of the 3 settings doesn't move at all.
Does anyone know any shops in the Columbus or Toledo Ohio area that specializes in vintage bikes? Here are some photos of the bike.
Quoted: 4560 Post(s)
Liked 2,802 Times
Nice condition, nearly identical to mine.
I'm literally eating pizza right now as I write, but I'll take a look at my GPX shifter later to refresh my memory of the three settings. There's one for standard Suntour Accushift index shifting, one for some other index shifting standard, and friction mode. I wouldn't bother with friction mode, other than curiosity. The GPX shifter friction mode was an afterthought, with poor feel compared with earlier good purpose-designed friction shifters.
Definitely gotta replace that shifter cable loop before doing anything else. No point trying to adjust the shift lever until the cable is replaced.
If there's an REI or good local bike shop nearby you can buy just enough cable housing to redo the whole bike for a few dollars. They can even cut it for you. Just bring in the old cable housing and they can use it as a guide for cutting fresh cable housing. Add some new cables. And offer a tip or buy some extra stuff at the regular shop price as a thank-you. I never leave my LBS without buying a little something.
Quoted: 1949 Post(s)
Liked 2,010 Times
That is a nice bike (frame). I got an 89 IM frame to replace my son's TREK 560 that he crashed and destroyed. The PO kept the GPX group for another frame. I put the Shimano 600 from the TREK on the IM with some Open Pros laced to the 600 hubs. It is an awesome riding bike. Don't mess with the shifter until you remove that bad cable. It is possible that someone already tried to use/adjust the shifter with that frayed cable and destroyed the innards of the shifter. Cross your fingers. Remove the cable, squirt some solvent/liquid wrench/WD40 at the shifter and see if that helps.
Bikes: 1984 Miyata 310, 1986 Schwinn Sierra, 2011 Jamis Quest, 1980 Peugeot TH8 Tandem, 1992 Performance Parabola, 1987 Ross Mt. Hood, 1988 Schwinn LeTour, 1988 Trek 400T, 1981 Fuji S12-S LTD, 197? FW Evans
Quoted: 531 Post(s)
Liked 1,004 Times
Thrifty Bill
Quoted: 1236 Post(s)
Liked 964 Times
You have to loosen the attachment bolt, move the red dot to the position of your choice, and then tighten it down. Suntour in that era had some goofy positions on their shifters, I tend to google it every time I run across it.
RE = standard indexed shifting
UL = Ultra 7 speed shifting for Ultra 7 narrow freewheels.
P = Friction.
Crazy to have a DT shifters with two different indexing options.
Getting a shop with the knowledge and interest to work on vintage stuff? I've never found one. Most shops prefer the latest/greatest/wizzbang stuff. I've had shops tell me no bike over five years old was worth working on as they are functionally obsolete.....
May be able to find a forum member in your area, as they are "everywhere".
P = Friction.
Quoted: 796 Post(s)
Liked 522 Times
Not sure if you have searched You tube but I am often surprised how much vintage bike content is on there, maybe RJ the bike guy did a video on GPX shifters. I would never be able to afford this hobby without doing my own, slightly more than adequate, wrenching. On pre 1995 bikes its actually pretty straightforward even for a ham handed mechanic like me, Knowledge+Patience+time+beer+remembering to walk away and calm down when things go south, means I can get most jobs done.
Very nice IM OP have fun with it.
I have the identical bike. My GPX stuff worked pretty good but can be a bit finicky. I switched the freewheel to a 12-28 Suntour to help with hills and put a Sram PC 850 chain. It needs to be a little longer to make up for the larger cog. It was quieter and shifted good. After about 1000 miles I have decided to change it up for riding RAGBRAI so I am switching it to 10 speed on the rear and a triple on the front. I am using Shimano down tube shifters and Utlegra brakes. This will be the second Ironman I have done this way. In fact I am robbing the triple off the other one and switching it to a DuraAce crank. I love the way these bikes ride & handle and with a little more modern drive trains they are even better. BTW there is another thread that most of us Irongents post on https://www.bikeforums.net/classic-v...aint-jobs.html
Here is mine shortly after I bought it
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
P = Friction.
P = Friction.
Shimano faced the same thing, but their solution was a little plastic shim that allowed their 7-speed shifter to index a 6-speed. Judging by how rare those are now, cyclists must have been content to stick with 6- or 7-speed Shimano on a particular bike in the end.
Quoted: 677 Post(s)
Liked 459 Times
P = Friction.
P = Friction.
I'm thrilled that you got such a nice bike. Get a new set of shifter cables for that thing. Chunk the RD in a bowl of diesel or mineral spirits and let it soak for a couple days. Put it back together and have fun riding it. DIY and save some $green$.
Quoted: 677 Post(s)
Liked 459 Times
Well after changing the RD cable and a little adjustment it seems to shift ok. Sometimes it skips second gear and goes into first and you have to click it twice to shift from 7th to 6th. It is loud when you shift. I think I would actually prefer friction shifting. My old Lotus had suntour blueline shifting and once I got used to it it was smooth and quiet.
Liked 2,802 Times
@robertj298: Try a SunRace chromed MFR30 13-25 or MFM30 13-28 freewheel, and KMC Z72 or Z50 chain. It'll fix those nagging shift issues. Seriously, no more ker-chunk shifting. The lever will snick-snick into place.
Or, stick with the original Suntour freewheel but get a new KMC narrow chain, like the cheap Z7 "narrow" chain. It'll settle that annoying "hunting for the cog" clatter.
For now I'm back to a Suntour freewheel, mostly because I wanted to try the 13-26 to go with the 50/39 chainrings on my Ironman. It's good and helps on climbs on hot days with tired legs, just a little more easy spinning than the SunRace 13-25, without going overboard into the 13-28 that I use on the other road bike with 52/42 chainrings. But the Suntour freewheel is slightly pickier about chains and setup. It kerchunks again, while the SunRace freewheel and KMC Z72 are quiet and smooth.
Be sure the drivetrain is clean, including the rear derailleur pulleys. And the cable and RD are adjusted. Later I'll attach a screenshot of some basic tips for quickly adjusting the rear derailleur.
A set of inexpensive Tacx sealed bearing pulleys polished off my GPX setup. It's so slick and smooth I wouldn't go back to the original sintered bushing bearings. Costs about $15 or less on Amazon and worth it. The Tacx pulleys won't improve the already good Shimano Centeron pulley, but did help the Suntour GPX RD.
Quoted: 677 Post(s)
Liked 459 Times
Tesgin
Bicycle Mechanics
18
07-17-18 10:00 PM
Fennecfox
Bicycle Mechanics
1
08-08-12 12:24 AM
