Where can I find cheap wedges/shims for the cleats?
I can't seem to find cheap wedges/shims for the cleats anywhere. The lbs was selling them in boxes for $25 and online that's all I've found so far. Anyone know where I can get some for less than $10? I don't need a ton of them...
Thanks!
Thanks!
Bikes: Cannondale EVO, CAAD9, Giant cross bike.
Quoted: 67 Post(s)
Liked 7 Times
Buy the box. They will chip and bend a bit, so extras are good to have.
Making a kilometer blurry
Seriously, I'd just use window/door shims from The Borg. This isn't rocket surgery
Get the ones in the small pack that are shrink-wrapped together, about 7" long. Those monster 10" ones that are strapped together are probably going to be too thick on the thin end.
Bikes: Klein q-pro carbon, Record, Ksyrium SSC
Call around. My LBS sells them individually for around $2 each. I also have a couple of extra speedplay pattern shims if you're interested in taking them off my hands for a buck or so each plus shipping.
Quoted: 104 Post(s)
Liked 5 Times
If you have 2 or 4 bolt cleats, you can sometimes use thin steel washers (real cheap at any hardware store). Washers are harder to use with 3 bolt cleats.
Another cheap method is to put a strip of cardboard under one side of your insole.
It appears that the only thing around (for 3-hole cleats) is a $25 product from bikefit.com. That's all the LBS' carry as well as the online stores. For thin plastic pieces, that just seems over-priced.
Fuji Shill
Bikes: Fuji Roubaix
Listen to the guys who are telling you to make them out of crap you already have.
