Why do pro's have all the fun? New engineering plea [long]
Rides again
Bikes: Giant OCR T, Trek SC
Yuck! A triple with a 16 tooth granny would shift horribly. The smaller gears in your setup would also wear out faster.
Your premise is completely backwards - the professionals and racers are the only ones who need such tightly spaced gears. The rest of us are perfectly happy to pedal a little slower or faster cadence than optimal rather than constantly shift between tightly spaced gears. Beginners are the ones who benefit the most from lower range gearing and they tend to shift as little as possible.
Well, 16 may be overkill. I was just working the numbers and not concerned about replacing gears.
I think others interested in tightly spaced gears are A- those who participate in any road or tri races, B- those who are regularly faced with winds, C- those who are getting older but don't want to slow down as much, and D- those who
face a variety of hill grades in their riding.
My thinking is that the rider would only shift from low-medium-high chainring to get in the range of gears
for current conditions and the rest of the shifting would be just progressing up and down their cassette. If don't want
as close gears but good range, they could shift to a 12-25.
Rides again
HiYoSilver;
I would love it if you could be forced to ride your suggested gearset and see how bad it is.
The 9-10 shift and 18-19 shifts, either direction, would be monsters as you need to shift across 8 cassette sprockets to reach the next gear. By the time you do you have slowed down too much so need to shift back. Also the gear steps are too close together, particularly in the lower gears where the rider can easily handle larger gear steps.
I was wondering how much change in GI % is acceptable in lower gears. I have noticed that the larger jumps in lower gears does not generate a momentum hit like it does in the middle and high ranges.
Agreed the 9->10, 10->9, 18->19, 19->18 would require double shifts. Ideally it would better to have a single shift solution, but there is not such a system widely in use today.
The 16-31-53 front rings would give very poor shifting on to the middle ring as they exceed any front derailleur capacity limits. The total range of 46 teeth also exceeds rear derailleur takeup capacity and your gearing scheme ignores rules about not cross chaining.
Agreed about the derailer current limits, which is why started by asking for a re-engineering effort. I'm not a mechanical engineer and so don't understand the physical limitations. And yes, I ignored "cross chaining" rule because it is based on current engineering solutions. I haven't seen any creative solution to the common rider gearing experiences in the last 40 years. Thus I credit this to lack of vision instead of to lack of engineering ability.
If you want to eliminate duplicate gears and have a wide gear range then get something like the Rohloff IGH Hub.
I did look at that, but it seems to have problems with 1) weight, 2) transfer efficiency, and 3)ease to understand how to best use it.
Math help to understand it , : https://sheldonbrown.com/gears/internal.html
Gear Hub fan
Bikes: Civia Hyland Rohloff, Swobo Dixon, Colnago, Univega
Here is a discussion of Rohloff efficiency printed in the IHPVA Journal.
https://www.ihpva.org/HParchive/PDF/hp55/hp55p11-15.pdf
At high power levels they claim similar efficiency to derailleur drivetrains which, depending on gear selected, are not as efficient as frequently claimed.
https://www.ihpva.org/HParchive/PDF/hp52-2001.pdf
As for weight the Rohloff was compared some years ago with a XTR group and the difference in weight between them was about 200 grams. Remember with the installation of an IGH you are losing the weight of two derailleurs, rear derailleur hub and cassette, two of three chain rings and one shifter. The current XTR group has been further lightened but I would still expect the difference to be only about a pound.
I am not a racer so do not worry much about drivetrain efficiency, about which there is relatively little published data any way. I figure a few % lower efficiency just means a better workout while riding.
The 100+ page Rohloff manual, available for download in English from their web site, discusses the various hub models and frame requirements for installation.
Derailleur drivetrains without duplicate gears, or with minimum duplicates, were designed in the days of 4 and 5 speed freewheels. They were advantageous then but with 20+ speeds (double) or 30+ (triple) now available I do not see the necessity now.
Gear Hubs Owned: Rohloff disc brake, SRAM iM9 disc brake, SRAM P5 freewheel, Sachs Torpedo 3 speed freewheel, NuVinci CVT, Shimano Alfine SG S-501, Sturmey Archer S5-2 Alloy. Other: 83 Colnago Super Record, Univega Via De Oro
Visit and join the Yahoo Geared Hub Bikes group for support and links.
https://groups.yahoo.com/group/Geared_hub_bikes/
Rides again
Thanks for the updates. I haven't had time to review the rohloff plan. I missed the basic explanation that it replaces both derailers and couple of chainrings. It would be have better if Rohloff had an image: "not this" but "this". The 13% may be a tad high, and I seem to vaguely recall an issue with span of total gear range.
13% in real life is not much, and as its 13% the next gear the difference
is smaller as the gearing goes down.
OTOH with the chain tensioner , you can get a second chain-ring, double crank, for about a 6 or 7% difference.
to half step the hub .. 3~4 tooth difference .. in the top 7,
as said the bottom 7 are already getting closer.
hub cog will take any 8 speed 3/32" chain.
I've got a 17" low and a 90" high and find it a fine range .. 38/16x26"wheel
recent acquisition a BikeFriday Pocket Llama its Geared 53/16x20"wheel
combine it with a Overdrive Schlumpf High speed drive crankset ,
and you could wheel suck behind mopeds.
Rides again
to half step the hub .. 3~4 tooth difference .. hub cog will take any 8 speed 3/32" chain.
Rides again
Still haven't had time to review Rohloff range. I can't find data on the GI for the different gears. The supplied link to the pdf did provide the efficiency data.
90.8% to 89.8% rohloff
94.6% to 93.3% shimano
That's about a 4% hit. With wider gearing of 13, I'ld never make that up by keeping pace level.
It was the lost of efficiency that led me to discard this engineering solution last time.
Rides again
Ok, reviewed Rohloff with brain in gear. This is not a viable solution. It costs $1,200, approximately. It's range is a mtb range, 19 to 98GI. This does not work for road riding. It would mean giving up 3 top end gears.
Bike ≠ Car ≠ Ped.
How fast do you really want to go, then? Is 35-40 mph too slow?
Quoted: 38 Post(s)
Liked 11 Times
On the internal hubs,why can't you raise the gearing?You don't need 19 inches on a road bike. They have a torque limit,but they don't have a speed limit.
Bikes: Windsor TimeLine; Linus Gaston 3; Sears Free Spirit
Quoted: 43 Post(s)
Liked 99 Times
Interesting thread. HiYoSilver, I believe that the solution to your problem already exists: The hybrid IGH-cassette drivetrain. In my view, it's being overlooked because (1) the components involved aren't Shimano, Campy or SRAM (though SRAM does make at least one hub that allows it; to my knowledge, the Alfine and Nexus hubs don't have this feature); (2) because the system hasn't been used in racing; (3) fears about excess weight and mechanical complexity; (4) the sheer novelty of the thing puts people off; and (5), I think only Brompton has taken the plunge and put the system onto a production model.
Sturmey Archer makes at least two different internal gear (3-speed and 5-speed) hubs that have splines for adding 8- or 9-speed cassettes to the drive side of the hub:
https://www.sturmey-archer.com/products/hubs/cid/4/id/64
and
https://www.sturmey-archer.com/products/hubs/cid/8/id/58
As I understand it, a hybrid drivetrain essentially uses the IGH as to provide additional "rings", with the splined cassette serving its normal function. Thus, you could have 45 speeds if you combine the 5-speed IGH with a 9-speed cassette: Effectively, you get the equivalent of 5 chain rings for a 9-speed cassette. Of course, you'd have to play with the actual chain ring size to prevent the highest gears in each range from becoming too high to be usable, but this presents no real obstacle to implementing the system.
I've been messing around with the gearing calculator on the Sheldon Brown site, experimenting with the possibilities (some of which I've printed out, notwithstanding the warning on the page that the print function doesn't work. It does, and you can print a screen capture anyway). The program lets you run calculations on various derailleur (single, double, triple ring) and cassette drivetrain combinations. It also lets you experiment with gearing combinations for igh drivetrains and for hybrid igh/derailleur set ups:
Example: For the SA 3-speed, using a 39 tooth ring (the inner ring on a Trek Madone) and a 13/14/15/16/17/18/19/21/24 cassette, as the hub steps from Low (.75 of direct drive) to Direct (1.0) to High (1.33 over direct) (call it Low, Mid and High range), you'll get the following, in gear inches, rounded to the nearest whole number:
Low: 58/54/51/47/45/42/40/36/32
Mid: 78/72/67/62/59/56/53/48/42
High: 104/96/90/84/79/75/71/64/56,
with obvious possibilities for changing these values by using different rings or cassettes. Also note that CS-RF3 hub is compatible with an ordinary mountain bike left hand shift set-up as used for triple chainrings. I believe that a standard rear derailleur and shifter would operate the cassette.
As I recall, Sixty-Fiver has (had?) a bike with this hybrid set-up. He can give us an in-fact-not-theory evaluation of how it performs.
and
Kid A
Liked 5 Times
This thread sucks -- I'm trying to read why most cyclists are "bored" compared to pros. Maybe it's because they have to read internet threads as long as the Old Testament.
I got bored with the rant and stopped reading. I've been saying for years that compacts are for cyclists who need lower-than-standard gears but are too vain to use a triple. That sounds like you. If you want more low gears without giving up your high ones, get the triple. For hills, I run a 30/39/53 along with an 11-32.
Rohloffs are pricey, it is true. They are very wonderful, though.
Bikes: 2000-something 3 speed commuter, 1990-something Raleigh Scorpion
A hub is just a ratio-changer. You can easily raise or lower the overall range by changing the chainring/sprocket ratio. There's a low-gear limit due to the problem of over-torqueing the hub, but no upper limit. You could run a 13t sprocket with a 53t chainring if you really needed it.
Quoted: 111 Post(s)
Liked 5 Times
Why can't SRAM and Shimano design a gruppo that would allow regular
riders to have as much fun as pros?
I don't know about you all but I'm getting pretty tired of cycling companies
ignoring the needs of cyclists. I'm buying a new bike and spending way way
too much. Bottom line is it boils down to gearing options are simply not
available. ....
available. ....
You are nitpicking over very tiny faults, in a gear system that even with such 'improvements' would still have a number of glaring shortcomings.
My thoughts would mainly involve three features:
1) the maintenance should be minimal--say, for a casual rider, once every five years? Maybe once every couple years for a frequent rider. That rules out just about any exposed chain setup.
2) the inter-gear spacing should be reasonably small.
3) the (single!) gear shifter control should functionally place all the gears "in order", so you don't need to know which-combination-of-what controls to go to the next higher or next lower gear. (this also assumes that there will be no gear-ratio duplication, too)
Quoted: 5 Post(s)
Liked 11 Times
I can imagine coming to a halt and toppling over on a hill trying to figure out what to shift........
Had a road bike with a 52-42 up front and a 12-28 8 speed cassette. Worked very well around here. Orange County Ca has surprisingly stiff climbs and open highways with a constant tailwind. You will never always have just the right gear. That's what legs are for.
Heck the Pros are part of Marketing the new stuff, the engineers do all the design
and prototyping,
spring classics they run the stuff around Belgium and such, to see if the strong,
Trained racers can break it , in one day of racing,
then summer .. TdF, getting people to think it can make them faster,
if they buy the latest stuff
then that fall the trade-shows take dealers orders for the bike companies
that bolt it on their brands.
and prototyping,
Quoted: 43 Post(s)
Liked 99 Times
You make a good point about the length of the posts But I wouldn't say that the thread sucks. I find the idea of alternatives to current systems fascinating, and this probably the best sub-forum in which to discuss the possibilities. But I can't see any of the major pro teams making themselves test subjects for such experiments. And there's certainly no percentage in it for Shimano, Campy or SRAM to push something so far removed from conventional methods. As for me, I ride a single speed Trek Cruiser and an old Schwinn 3-speed. Simple is good, even if exotic is interesting.
Alexandria, eh? I grew up right across the Potomac, near what's now National Harbor.
Quoted: 43 Post(s)
Liked 99 Times
and prototyping,
and prototyping,
Bicycle Repair Man !!!
The new dual drives that incorporate an IGH with an 8-10 cassette do provide a lot of options, particularly in regard to smaller wheeled bicycles where getting adequate high gearing for performance applications can be a challenge.
With regular sized bicycles a derailleur drive provides the most weight and cost effective option while with bikes like roadsters a simple dual drive can really add some range.
My dual drive set up a simple 2 by 3 to give me a 6 speed with a nicer range but when I want to get out and have serious fun I run a derailleur equipped road bike with closely stepped gears.
Insane Bicycle Mechanic
Quoted: 806 Post(s)
Liked 708 Times
Y'all realize that HiYoSilver started this thread more than a year ago, doncha?
Jeff Wills
Jeff Wills
Pedaled too far.
Quoted: 11 Post(s)
Liked 7 Times
Have you sent this to the concerned manufacturers? I'm impressed with your analysis, but we're not going to do anything about it here on BF.
"He who serves all, best serves himself" Jack London
