Advice on new saddle purchase
Quoted: 88 Post(s)
However, I'm looking for some input from those of you who have either upgraded saddles or have found yourself looking for something new.
I have been battling discomfort on the bike this year, and it's developed into a saddle sore. I have ruled out bibs as the culprit. I was fit at a local shop, but I'm starting to consider the saddle itself may be the culprit. I have never been truly comfortable on it.
I am currently on the stock saddle that came with my bike, and it measures 136mm wide. My sit bones measure at 110mm wide, give or take a mm. Which falls on the narrow side of the spectrum. My initial thought was that my current saddle may be too narrow and have been looking into a wider saddle. However, everything I have read states that a wide saddle can cause chafing, not a narrow one. Which is exactly what I'm experiencing.
I thought maybe a wider saddle might be in order, but I reached out to Fizik and they suggested I run an Antares Regular (130mm wide). I have also been looking at a Fabric Line Shallow Elite which is 134mm wide.
Now I'm confused.
Maybe my only option is riding demo saddles from a local shop.
Now I'm confused.
Bikes: ...a few.
Quoted: 2010 Post(s)
Liked 408 Times
Have you tried Brooks saddles? If I didn't ask someone else would have. I've got a B17, and while it's comfortable enough for long ride, I didn't find it to be more comfortable than any of my other ones.
Quoted: 88 Post(s)
Nope, I haven't tried anything other than the saddle that is on my bike which is an All City Gonzo.
Quoted: 20810 Post(s)
Liked 9,456 Times
There are things that you can do to help predict which type of saddle might work best for you, but a lot of times it's only going to narrow the field and it's still just going to come down to trying different saddles and seeing what actually works.
Having an idea of your sit bone width is a good start (do you actually feel that your saddle is too wide? Do you feel the edges of the saddle on the bottom half of the pedal stroke?) and I think that minimal padding is generally a good thing (how firm is your Gonzo? ...oh, that just sounds wrong) and if you're feeling any perineum pain/numbness, you may need a saddle with a cutout.
Bikes: Basso Luguna, Fuji Nevada
Quoted: 4261 Post(s)
Everyone is different and what is a comfortable saddle for some can be a torture device for others. I went through 8 saddles before I bought the Specialized Power Expert saddle. It is a short saddle with a huge cut out. Check it out and oh yea, use Chammy Cream or Bag Balm before you ride.
Advocatus Diaboli
Quoted: 4731 Post(s)
Liked 1,531 Times
I was with you till the end.. kind of a mixed review if one reads that this saddle only works with Chammy Cream/Bag Balm combo.
Quoted: 88 Post(s)
So, perhaps this is being caused by the width of the saddle creating friction OR my other thought is that I'm unable to stay in a position on the saddle that puts all my weight on my sit bones, which is causing me to perhaps slide forward and put more pressure on the soft tissue and cause rubbing.
Yes, numbing and pressure on the perineum is also something I have consistently experienced, it usually sets in rather early, probably 20 min into a ride.
Yes, I always ride with chamois cream (chamois butt'r brand)
Quoted: 88 Post(s)
Liked 9,456 Times
I remembered a decent article by Cervelo on saddles - worth the read. https://www.cervelo.com/en/engineeri...f-road-saddles
I just bought a tube of butt'r after using dz nuts and Enzo button hole, I like the butt'r best. I've never had chaffing, just discomfort in the soft tissue between my site bones and saddle. Though I have had a couple bouts with saddle sores from riding a seat with too much padding, I guess that to be sort of chaffing.
I have a narrow Terry FLX saddle that's well reviewed. I think it's 130mm, a demo version. If you would want to give it a try let me know. You can look it up online.
Non omnino gravis
Bikes: 2015 CAAD 10; 2016 Felt Z85
Quoted: 156 Post(s)
Liked 5 Times
I had a feeling it would come down to a crap-shoot and a lot of trial and error. Right now the Fizik Antares regular seems like first saddle I should try...it's the narrowest that I have found at 130mm which is 6mm narrower than my current. Beyond that, most saddles seem to fall within a +/- of 3 mm of my current saddle.
I've had trouble with discomfort on my Felt Z85.
I realized that, while riding my other bike on the trainer one winter (without wearing cycling shorts - just regular underwear & shorts), that I could ride in comfort.
So I just went out and purchased the same seat for my Felt.
Now I rid the Felt in relative comfort.
My thought -it's not only the size of the seat, but the particular curvature as well.
There does seem to be trial and error involved.
Think about it: even if 2 seats differ by only 1 mm - that small amount could make a big difference in the way your butt feels.
Quoted: 88 Post(s)
Totally, but most shops carry a very limited selection, and if they do carry your brand, their demo versions are 2-3 years dated. This is what I'm finding anyway.
Vintage bikes enthusiast.
Bikes: 2015 Fuji Roubaix 1.3 / Old ass Free Spirit / Centurion Ironman Dave Scott Master 1989
Quoted: 9 Post(s)
Quoted: 62 Post(s)
Quoted: 88 Post(s)
To me, this is a more important issue than the chafing. Don't let it go unaddressed.
Quoted: 88 Post(s)
Ended up going with a Fizik Arione VS
What sold me was the narrow 130mm width, and the channel. I think the former will hopefully reduce inner leg friction by being narrower than my current saddle, and the latter will reduce pressure on the perineum.
Thanks all for the input, will report back.
Quoted: 182 Post(s)
Saddle sore = some chamois cream, vaseline works.
Saddle discomfort = find the right one.
I've test ridden 20 plus saddles and purchased a few, ranging from WTB padded saddles to Sella SMP, which I rode for year on rides up to 190 miles, thought it was okay. But - finally - after everyone kept talking about Brooks Brooks Brooks ... I tried one. They are clunky and bulky and don't match a $5000 carbon road bike and we all want to look cool, but it was obvious after a few rides that what they say is true. Brooks wins. I'm riding faster simply because my mind is no longer on my butt, i.e. I can exert power more evenly through the pedal stroke without being distracted by discomfort. Try a Brooks if you are not entirely happy with the Fizik.
Non omnino gravis
I will definitely give Brooks the edge on aesthetics-- the Titanico is ridiculous looking. But it sure is comfortable.
Quoted: 62 Post(s)
This was my experience as well, just with a Selle Anatomica Titanico in place of the Brooks. I think it's the 7th or 8th saddle I've used in less than 3 years. I would get 1,500-3,000 miles out of a saddle without issue, then one day, that saddle would just turn straight evil on me. I've given away a whole bunch of very lightly used saddles.
Non omnino gravis
My Titanico X has proved to be the most trouble-free saddle I've ever used. I'm a bit past 5,000 miles on it, and I think I've put maybe four turns on the tension screw. I was initially worried because I had read so many reports of bent rails or the saddle prematurely stretching, but have experienced none of that myself. Thomson Elite seatpost, rider weight 190-200lbs.
