Cracking saddle
Cracking saddle
Old 09-16-18, 01:28 PM
dvai
Quoted: 106 Post(s)
Liked 4 Times in 4 Posts
Cracking saddle
So I need your help.
My saddle cracks a lot. I have a Trek Domane with standard seat post (steel clamp with carbon post) and a WTB rocket saddle with titanium rails.
You can reproduce the creaking by holding each edge of the saddle and torquing up and down...
The interesting thing is that the creak can increase or decrease depending on how tight the front and rear screws are set. The issue is that you need to adjust those screws in order to set the ideal saddle angle.
I went to my LBS and they said the creaking seems to be from where the rails is inserted in the saddle. They put some lubricant in the area but didn't helped a lot.
I tried to install another saddle (sella italia also with titanium rails) and something similar happens.
Thoughts?
Is this to be expected?
Is there something wrong with the clamp in the seat post?
Is this common in titanium rails?
The creaking drives me nuts when riding.
Any thoughts?
dvai is offline
Old 09-16-18, 02:11 PM
MagicHour
MagicHour's Avatar
Quoted: 85 Post(s)
Liked 12 Times in 10 Posts
You try greasing the seatpost bolts?what about hardware on seatpost clamp? Ie barrel nut if it has one.
You can also try wiping down clamp interface/saddle rails too with some rubbing alcohol. I’ve heard of lightly greasing seatpost/ti rail interface too but IME can lead to slippage but something else to try if all else fails.
MagicHour is offline
Old 09-16-18, 03:16 PM
dvai
Quoted: 106 Post(s)
I tried grease.. same issue.
I tried cleaning too. Even though not with alcohol.
dvai is offline
Old 09-16-18, 10:22 PM
NILS14
NILS14's Avatar
Bikes: Specialized Secteur Sport 2015, Vitus Zenium VRS 2014
Quoted: 17 Post(s)
Put a lot of grease anywhere metal touches metal.
In my case it was the lower saddle clamp part moving against the seatpost that was the issue. I had cleaned and greased it but I hadn't put enough grease.
NILS14 is offline
Old 09-17-18, 07:36 AM
maartendc
maartendc's Avatar
Bikes: BMC SLC01, Trek Checkpoint ALR5
Quoted: 542 Post(s)
Liked 32 Times in 26 Posts
Thoughts?
Any thoughts?
For me, the type of creaking you describe is usually from dirt and dust in the seat rail clamp.
Take out the saddle and clean the seat clamp VERY thoroughly. Then apply a bit of WD40 to the area. (don't know about grease, seems messy to me). The reinstall the saddle and see if that worked.
Could also be dirt between the seatpost inside of the seat tube. You can take the seatpost out and clean both thoroughly with a rag. Then apply some fiber grip paste to your CF seatpost.
Good luck!
maartendc is offline
Old 09-19-18, 02:55 PM
nesdog
Bikes: Domane SLR7 Disc
Quoted: 68 Post(s)
Liked 68 Times in 39 Posts
I get this same sound on my Domane, using an SMP saddle. It comes and goes so I've never really done anything about it. Drove me nuts as I was thinking it could be BB or spoke or who knows what! Creaking stopped when I unweighted the saddle. May try some of the fixes listed above.
[insert clever quote here]
nesdog is offline
Old 09-20-18, 10:13 AM
dvai
Quoted: 106 Post(s)
What do you mean with "unweighted the saddle"
dvai is offline
Old 09-20-18, 10:45 AM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
I expect the Ti rail is flexing, get steel rail saddles,
or live with the side effects of your gram cutting.
fietsbob is offline
Old 09-20-18, 10:48 AM
fietsbob
Bikes: 8
Getting your butt off of it.
fietsbob is offline
Old 10-04-18, 05:46 PM
dvai
Quoted: 106 Post(s)
I tried everything.... complete cleant rais and clamp.... with grease, with carbon grip...
Still creaking.
So I switched to a Fabric carbon saddle (carbon rails) and the noise is gone.
The Fabric Scoop is not as comfortable as the WTB but should do.
So is the creaking issue a known problem with titanium rails?
Maybe my saddle had an issue?
dvai is offline
Old 10-04-18, 05:51 PM
Lazyass
Quoted: 2432 Post(s)
Liked 638 Times in 395 Posts
Make sure it's not your seatpost creaking inside the seat tube. I've had a couple of them I've had to shorten by an inch or two so they don't stick down so far. If they go down too far they can creak. It does sound like it comes from the saddle.
Lazyass is offline
GoldenBoy12
Bicycle Mechanics
24
12-19-17 11:38 AM
Chesterton
Bicycle Mechanics
2
08-19-15 05:04 PM
CanadianBiker32
Bicycle Mechanics
2
07-11-15 10:38 PM
due ruote
Classic & Vintage
5
05-17-13 05:19 PM
shralpster
Bicycle Mechanics
4
05-29-10 12:04 PM
