Heart rate monitor that works with rouvy/zwift
Old 10-14-18, 05:20 PM
dvai
Quoted: 71 Post(s)
I wonder if there is any specific monitor that works with those services. I assume that means being compatible with an ipad (which is how I get those services).
I have a garmin HR monitor that I use with my garmin computer, but it does not work with the ipad. Thoughts?
dvai is offline
Old 10-14-18, 05:38 PM
JohnJ80
Bikes: N+1=5
Quoted: 627 Post(s)
Liked 55 Times in 44 Posts
If it has to connect to the iPad, you will need either a HRM that support bluetooth or the NPE dongle that converts ANT+ to BT.
JohnJ80 is offline
Old 10-14-18, 05:53 PM
Athens80
Quoted: 135 Post(s)
Liked 15 Times in 12 Posts
Wahoo TICKR (ANT+ and Bluetooth) or 4iiii Viiiiva (Bluetooth, ANT+ and ANT+ to Bluetooth retransmitter) or Scosche Rhythm (Bluetooth and Ant+ on armband)
Athens80 is offline
Old 10-14-18, 06:07 PM
rms13
Quoted: 274 Post(s)
I have Wahoo Ticker and it works with both and more. Ant+ and Bluetooth should be compatible with most software and hardware
rms13 is offline
Old 10-14-18, 06:17 PM
Seattle Forrest
Seattle Forrest's Avatar
Quoted: 12032 Post(s)
Liked 3,371 Times in 1,884 Posts
To clarify, the HRM you get has to be compatible with your iPad, not with Zwift. Usually that's not an important distinction, but folks have different levels of familiarity with computer tech, so maybe putting it this way will help.
John told you exactly what you need.
If I was going to buy a new one I'd want a Wahoo or 4iiii that you can use with a phone or iPad and also with a Garmin.
Seattle Forrest is offline
Old 10-14-18, 08:11 PM
zacster
Quoted: 22 Post(s)
Liked 178 Times in 143 Posts
I have the Garmin HRM and an ANT+ USB dongle and it works with Zwift on my computer, but not on my iPhone or iPad. The newer iOS devices need an expensive adapter to make them work, lightning to USB, or a lightning to 30 pin and then a 30 pin dongle. So, just get a bluetooth as suggested and be done with it.
Even though I do the same commuter almost every day, I still wear it every time.
zacster is online now
Old 10-14-18, 10:16 PM
caloso
caloso's Avatar
Quoted: 2245 Post(s)
Liked 935 Times in 486 Posts
You need a 4iiii hrm https://4iiii-innovations.myshopify....-rate-monitors
It acts as a blue tooth to ant+ bridge.
caloso is offline
Old 10-15-18, 06:16 AM
Dan333SP
Serious Cyclist
Dan333SP's Avatar
Bikes: 2013 Madone 3.1
Quoted: 5618 Post(s)
Liked 111 Times in 58 Posts
I use this one-
https://www.amazon.com/Onlyesh-Bluet...=bluetooth+hrm
Cheaper than the name brands and it sends out both a BT and ANT+ signal so I can use it for Zwift and also have it sync with my on-bike computer while riding outdoors. It's cheap but has worked perfectly other than some issues with the contacts getting corroded after washing the strap, cleaned them with a wire brush and it's back to normal.
Dan333SP is offline
Old 10-15-18, 07:07 AM
dvai
Quoted: 71 Post(s)
Thank for all the good advice!!!
dvai is offline
Old 10-16-18, 06:21 AM
bobwysiwyg
bobwysiwyg's Avatar
Quoted: 927 Post(s)
Liked 287 Times in 173 Posts
Originally Posted by Dan333SP View Post
I use this one-
I was interested so checked it out. The feedback suggested nearly 30% of purchasers regret it. My regret limit is no more than 10%.
bobwysiwyg is online now
Old 10-16-18, 08:13 AM
rms13
Quoted: 274 Post(s)
I'm all for saving a few bucks but I'd cough up the extra $10 for Wahoo Tickr since it's proven
rms13 is offline
Old 10-16-18, 12:40 PM
em.jay.el
Bikes: Specialized Tarmac Expert | Specialized Crux Elite | Specialized Diverge Elite DSW
I use a wahoo tickr with my ipad and zwift.
em.jay.el is offline
Old 10-21-18, 04:56 AM
macca33
macca33's Avatar
Bikes: 2017 Ridley Noah SL - Candy Apple DA9000, 2011 CAAD10 Berzerker Ult6800, 2013 FOCUS Mares CX Ult6800
Quoted: 26 Post(s)
Wahoo Tickr is faultless in my 15,000Km+ experience to date.
cheers
macca33 is offline
TopEnd Rider
5
01-15-19 12:10 PM
whitemax
Road Cycling
10
08-22-18 07:28 PM
WorldIRC
Road Cycling
20
04-09-17 08:32 PM
Oncoming Storm
1
02-26-16 05:01 PM
peterbotwin
2
02-01-13 07:16 PM
