Bearing hub noise on bike but not off
Quoted: 5224 Post(s)
Liked 3,581 Times
did a nice ride last week & rolling the bike to my back yard I noticed the sound & subtle vibration of the rear hub/bearings
took the wheel off on my stand & spun the wheel but no noticable sound or vibration. the hub is also not loose or tight. meaning it seems to spin perfectly fine
put the wheel back on the bike, on the stand & the sound is back. the quick release is set to a proper tension, basically just tight enough to hold the wheel on, same as it's been for years
thinking the hub needs service of some kind. make sense?
Half way there
Quoted: 986 Post(s)
Liked 880 Times
Many wheels with bad or mis-adjusted bearings will spin just fine. I like to remove the wheel and turn the axle by hand. The feedback you get will provide some clues. If the axle turns with a silky smooth feel without perceptible play you're in good shape. If notchy or rough you may just need a simple adjustment or perhaps a rebuild is in order. A lot of things move around when you roll a bike. Hearing a sound and feeling a vibration when rolling the bike may be nothing ... or it may be any number of things.
Quoted: 1438 Post(s)
Liked 1,092 Times
Your quick release will slightly compress the axle and tighten the bearing adjustment vs off of the bike. So you may need to back off the adjustment slightly to account for this. I use one of these axle vises to adjust the axle with the QR installed: https://www.steintool.com/portfolio-...ub-axle-vises/
Likes For dsbrantjr:
Liked 3,581 Times
def. not that, but thanks (famous last words)
Liked 3,581 Times
Bikes: '04 LeMond Buenos Aires, '82 Bianchi Nuova Racing, De Rosa SLX, Bridgestone MB-1, Guerciotti TSX, Torpado Aelle, LeMond Tourmalet 853, Bridgestone Radac
Quoted: 101 Post(s)
Liked 46 Times
That would suggest to me that it's the bearing in the freehub that's sounding a bit rough.
Liked 1,092 Times
For me this is balanced by the better support of the axle by the bearings, greatly reducing the incidence of axle breakage in the freehub designs.
Liked 3,581 Times
heard from the shop. the hub is toast. I'm donating the wheel so bikes-not-bombs can cut it out & lace in another. I'm buying a new wheel. one they described as having a low maintenance workhorse shimano hub. $125, $150 installed, checking spoke tension, swapping gears, tube/tire & adjusting the rear derailer. I'll get it back next week, ready to ride
sound reasonable?
sound reasonable?
Quoted: 980 Post(s)
Liked 582 Times
Liked 3,581 Times
just to follow-up. got the bike back w/ the new Alex DA22 32 spoke wheel & Shimano FH-RS400 hub. should be smooth sailing now
Likes For rumrunn6:
