1977 restored Schwinn Suburban women’s 10 speed
Hello everyone! I am very new to the vintage bike world but I recently picked up a 1977 women’s Schwinn bike that was completely restored. I went out on a ride today and the front breaks are squealing pretty badly. After some investigating it looks the right break pad is in the reverse toe in position!! The break pads are Weinmann brev SR 75 Any advice on how I should correct this? Or any advice in general for a vintage Schwinn suburban. I’m excited for this find, and have now have a soft spot for suburbans
Quoted: 702 Post(s)
Liked 672 Times
Those may be the original pads. Are your rims chromed steel or aluminum?
Insane Bicycle Mechanic
Quoted: 805 Post(s)
Liked 706 Times
Suburbans had chromed steel rims.
Schwinn brakes could squeal when new. (I was a Schwinn mechanic in the early '80's.) When that happened we'd twist the brake caliper so the front edge of the brake pad hit the rim first, aka "toe-in". This takes an adjustable wrench and gentle pressure on the brake caliper to adjust the angle of the brake caliper arm. It's harder to describe than to do it
Jeff Wills
Jeff Wills
Quoted: 702 Post(s)
Liked 672 Times
the pads look brand new, I will try that. Also, the rear brakes take a lot of force on lever to work and also are squealing
Quoted: 702 Post(s)
Liked 672 Times
If the squealing doesn't go away after you adjust them, look into "Kool Stop" brake pads, they may work better.
Quoted: 702 Post(s)
Liked 672 Times
Kool Stop International - High Performance Bicycle Brake Pads Since 1977
[QUOTE=branko_76;21433364]your local bike shop may have them, but before you call, go to koolstop.com to find the correct
thanks for the link, will adjust them tomorrow and see what happens....
Mr. Anachronism
Quoted: 526 Post(s)
Liked 256 Times
I used Kool Stop Continentals when I refurbed a similar Collegiate for a friend. They work great on steel rims.
Likes For Hudson308:
cool, these are inexpensive thank you. Do you have any advice on the right break lever? It takes a lot of pressure for the rear brakes to work, seems like they need some adjustment. New brake pads on the rear as well.
Quoted: 702 Post(s)
Liked 672 Times
New pads, cables and proper adjustment will go a long way.
Quoted: 805 Post(s)
Liked 706 Times
Jeff Wills
Jeff Wills
Likes For Jeff Wills:
