700 x 28 tubeless recommendations - rec rider
shortnugly
back on road tires after a long hiatus,
reconstructing an older Giant OCR1, just picked up a set of Fulcrum Racing 7 wheels with 15.4 mm internal rim width.
Looking for a recommendation for 28 wide tires, not too heavy but not competition price tag. I don't race so Im looking for a set that can withstand about 2000 miles a season, no gravel or offroad
thanks in advance
thanks in advance
Quoted: 2337 Post(s)
Liked 2,818 Times
why tubeless, especailly at 28...... I have had really good experience with the Conti GP5000 I am 240 and ride and commute on them 700x28 running 115psi just under 600 miles no flats no issue (compared to vitoria corsa g which at similar mileage i ha 6 flats) your can get the gp5000 for $35 to 40 from the UK bike shops. and if you must they make a tubeless version
Quoted: 2494 Post(s)
Liked 738 Times
I would do tubulars (again) before I would ever try tubeless. That way lies madness. a 25mm or 28mm high pressure clincher from any of at least three companies should more than serve the road needs of someone that is "not racing". FWIW.
Bikes: Norco search xr
Quoted: 198 Post(s)
Liked 146 Times
Continental GP 5000 tubeless.
I do not know how many miles you can get out of them a season.
Bicycle rolling resistance
Likes For Gconan:
Bikes: 2021 S-Works Turbo Creo SL, 2020 Specialized Roubaix Expert
Quoted: 762 Post(s)
Liked 4,032 Times
Likes For MattTheHat:
Quoted: 174 Post(s)
Liked 177 Times
Everyone I know who's gone TL has never gone back. Yet here's someone who's never even run them telling someone else they're a bad idea. Absurd.
Sorry for the bad attitude, but posts like this are difficult for my covid brain to comprehend.
Likes For Ross520:
Liked 2,818 Times
Tubeless has little to do with racing... It's about a more comfortable ride, and less flat-tires. Why would you go tubular (which is just-about EVERYTHING to do with racing) before even trying tube-less? Sounds like you're so stuck in your ways you aren't open to new ideas anymore, which makes your opinion irreverent being that you have ZERO experience with them.
Quoted: 174 Post(s)
Liked 177 Times
just look in mechanics and see the problems people have with tubeless. Tubeless was originally for big tires on mountain bikes at low pressure to avoid pinch flats and sealant works well in the lower pressure. That make sense for big tires on gravel and road bikes....but 28 mm is not a big tire and if you are any significant weight the pressure needed is such that sealant is not as effective. so at 28 and below with 32 being border line I don't see any advantage for tubeless. also tubeless have stiffer sidewalls so I am not sure how you get comfort in a 28 tubeless over a good 28 tire with a thin tube.
If you go to a dishwasher forum, you're gonna find a lot of posts about broken ones. You won't fine any threads titled "hey guys, dishwasher is running great!".
There is a name for this type of bias, but I am too tired to remember at-the-moment.
Likes For Ross520:
Non omnino gravis
This tubeless thread has even more misinformation and disinformation than a typical tubeless thread on here. Amazing. I always have to wonder-- if a person has zero experience with road tubeless, what is it that compels them to blunder into these threads and offer up baseless opinions?
I am a counterpoint-- I haven't put miles on a tubed tire in almost 5 years. I have close to 50,000 miles tubeless-- and my Cervelo runs 700x23s. If you get a lot of "nuisance flats," tubeless is an advantage, regardless of the tire width.
In 700x28, I would look at the Giant Gavia AC1, Continental GP5000, and Hutchinson Intensive 2. Pricepoints will be close on all three, ~$50 a tire, but all will easily go 3,000+ miles as a rear. I get 3,000-3,500 out of Gavia 700x25s.
Likes For DrIsotope:
Quoted: 762 Post(s)
Liked 4,032 Times
There is some comfort advantage too, but I probably run my tires with more air than I should, so the comfort difference is minimal for me. And It’s still worth it.
Liked 738 Times
Just saying. My Bontrager Hardcase 23mm 700c have never flatted in two years. I don't even carry tire tools for short trips. I'm on that bike every day on the same roads where Schwalbe Marathons flat monthly and Kenda Kwests flat daily. No special rims, no special tires, no goop. If it ain't broke I ain't fixing it.
Liked 2,818 Times
so I will go back to orriginal and keep it simple...... I have been super happy with my Conti 5000. I ride them with tubes at 115 psi. I would expect the tubeless version to be good also as this is a flagship tire for Continental so whatever flavor GP5000 for the win
Likes For squirtdad:
Quoted: 174 Post(s)
Liked 177 Times
Judging by how much Orange Seal goo was on the inside of my rear triangle when I washed my bike last week (it had been a couple thousand miles since the last wash...I know, I know). I’d hate to know how many rides and how much time was saved over the past months. There are probably a dozen or more Orange Seal boogers on the back tire alone. I didn’t even know about a single one of them!
Luddites gonna luddite.
Likes For Ross520:
shortnugly
So I picked up a 3 Michelin Lithion.2 700x25 tires for $35 new. I figured thats a start. Cheap enough to throw these on and start riding.
Also picked up a set of DT Swiss All Road R1700 wheels.Bladed spokes, very lightly used.
Internal width 14.45mm
10 speed Shimano hub
Front is 710g without skewer
Rear is 865g without skewer
My Fulcrum Racing 7 are:
Front 800g without skewer
Rear 1095g without skewer
Internal width 15.4mm
So I'm going with the DT Swiss wheels off the get go and the Michelin tires. Once I lose about 7 lbs of Covid wonderful beer weight, I can get serious about a different wheelset with a wider inter rim width so I can eventually go 28 tubeless.
Thanks for all your info, good knowledge i'll retain on my next step. I'll post back when I get everything setup.
