Crank length preference?
I’ve always used 170 and 172.5, I just bought a Shimano triple crankset with 175’s. I’m waiting on the
derailleurs so I haven’t rode with them yet. Anybody switch to a longer crankset and have issues
with them? I have 170 arms on standby just in case.
Semper fi
Semper fi
Bianchi Goddess
Quoted: 2930 Post(s)
Liked 2,925 Times
I somehow settled on 172.5 for my road bikes long ago, but do have 170s on two bikes for various reasons. I think since I never really learned to spin well the slightly longer crank makes pushing a bigger gear easier.
The only bikes I ever had 175s on were MTBs and they came with them like most MTBs did (still do?). The idea being if your seriously mountain biking the longer cranks gives more torque, at least as explained to me many many moons ago.
Sugar "Kane" Kowalczyk
Likes For Bianchigirll:
Quoted: 800 Post(s)
Liked 753 Times
This is an interesting video. It's long, but worth the watch in my opinion. I'm definitely going to experiment with some shorter cranks if I find any for cheeeeeep.
Bikes: Numerous
Quoted: 1678 Post(s)
Liked 3,098 Times
It's never made much difference to me. I have all three lengths scattered amongst my bikes. I was thinking about that while riding today. Does 2.5 mm make much of a difference if my butt slides 1 cm along the saddle during the ride? If I measure my femur length 10 times, how often will I get the same measurement within 2.5 mm?
To each his own though; I get it if someone wants it just so.
Likes For Spaghetti Legs:
Quoted: 378 Post(s)
Liked 1,409 Times
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
Oh, you really don't want to get me started on this... I am a crank on the subject,
But shorter is better. There just isn't any advantage to longer cranks. People talk about leverage; yes, you have more leverage with longer cranks. That's great, but you don't need leverage. You need to spin. And you will spin better with shorter cranks.
Since the shortest C&V cranks you can find are 165 mm, I recommend 165's. If you can find shorter ones, go for it. You won't regret it for more than a half hour or so.
www.rhmsaddles.com.
www.rhmsaddles.com.
Quoted: 2588 Post(s)
Liked 4,824 Times
I tried a pair of 165s once - felt like I'd lowered my saddle 6" or more. Very, very noticeable and weird. I took them off after one ride and put my normal 170s back and they've been there ever since.
What works for some...
DD
DD
Likes For Drillium Dude:
Quoted: 790 Post(s)
Liked 1,767 Times
I have found the slightly longer 175 cranks can help a bit when running a larger range triple but don't seem to make much difference on a basic double or single where I would actually say go shorter to a. 165 for clearance you should be fine on most 80' though 90's road and mtbs. But with 70's stuff especially French and Italian you will have pedal strike clearance issues. Show us a pic of the bike you want to put the 175 and the crank and someone here will tell if it will work help.
I'm vertically challenged at 5'4. I played around with 165's and 170's on road bikes until I found folding bikes, and decided to experiment with much shorter cranks. My purpose was twofold: shorter cranks for easier packing of the disassembled bike in a suitcase, and let's see what they do to the power curve.
I had Mark Stonich of www.bikesmithdesign.com shorten a couple cranks, which I still have. An Ultegra triple and a 105 double, which started life at 170mm, now both at 148mm.
Power curve results were not encouraging. Easier spinning, which was nice, but greatly reduced leverage. Hills and wind became more pronounced, or maybe just my ability to deal with them. Felt like a spinning hamster wheel going nowhere fast.
In the end, I removed them and went back to my 165 and 170. Might dig them out again for a project or if I need a short crank for a particular frame setup.
I’m changing the derailleurs to LX and I just picked up a set of Deore 175’s. I have a set of 170 arms with the same bcd, I might switch them.
Semper fi
Semper fi
I’m not worried about them fitting on the bike, I’m just not sure if they would be comfortable to use.
Semper fi
Semper fi
Quoted: 790 Post(s)
Liked 1,767 Times
Also a point to consider almost all component groups with stock gearing low to high old or new are optimized for a 170mm standard crank.
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,702 Times
My experience is 175s is only on ATBs- but 170s on all my "road" bikes.
I also have stubby legs.
Commence to jigglin’ huh?!?!
I moved down for a 160 mm 105 R7000 on mine. It was 165 mm before and my commuter has a 165 mm.
So far is great and I see my cadence is coming up to 80-90 rpm.
Since my commute was majority or rides before the stay home stay healthy, my cadence was on 70s.
When spinning hard on 165 mm last year I got some discomfort on my right knee that went away after couple days.
Also experimented a 145 mm last year and tried it but was too weird.... If some want to try, is a triple JIS one .
Quoted: 790 Post(s)
Liked 1,767 Times
[QUOTE=sloar;21471633]I’m changing the derailleurs to LX and I just picked up a set of Deore 175’s. I have a set of 170 arms with the same bcd, I might switch them.
[/QU
On this bike no stay with the 170's and keep it simple. Trek matched there cranks to the frame set using 160, 165.170 and 175 Why rethink something that was already done.
[/QU
Quoted: 656 Post(s)
Liked 469 Times
I’ve long subscribed to the belief longer is more leverage for climbing and accelerating and have ridden 175 for the last 30 years. The video makes interesting points about fatigue and hip injury from longer crank arms. Not getting any younger so I might build something with 170 to see how it feels. I’d finally be able to use the take-offs I’ve accumulated over the years.
I stick with 170’s and my knees seem to like it. I would go 165 but they seem hard to find. Right now I have to use a 172.5 on a project and am hesitant. Too close to 175 which I know causes me knee pain. I switched the rings on the 172.5 with bio-pace to maybe lesson the harshness as I go around and push down.
I prefer 175, mostly because they are the most comfortable for me, and I feel like they fit me best. 172.5 or even 170 are OK too. I can feel the difference between all of these, but I'm not sure it makes a huge difference, or any difference in power. Shorter cranks are easier to spin up. Longer ones feel better for stomping big gears up climbs. I should note that my pbh is 36+ inches.
I remember Jobst B giving some long winded explanation of why it doesn't really matter on a ride a long time ago. Can't remember the reasoning though.
Bikes: Colnago (82, 85, 89, 90, 91, 96, 03), 85 Cinelli, 90 Rossin, 83 Alan, 82 Bianchi, 78 Fountain, 2 x Pinarello, Malvern Star (37), Hillman (70's), 80's Beretto Lo-Pro Track, 80's Kenevans Lo-Pro, Columbus Max (95), DeGrandi (80's) Track.
Quoted: 179 Post(s)
Liked 198 Times
Most of my bikes have had a crank length of 170mm but I have had the occasional 172.5mm and 175mm cranks and I don't take much notice of the crank length when riding. I also have one bike with 165mm cranks and they do feel slightly small but not to put me off the bike.
Bikes: 1978 Bruce Gordon, 1977 Lippy, 199? Lippy tandem, Bike Friday NWT, 1982 Trek 720, 2012 Rivendell Atlantis, 1983 Bianchi Specialissima?
Quoted: 345 Post(s)
Liked 175 Times
quOTE]
If I had both sizes on hand I would try them both and go with what I liked best.
quOTE]
Quoted: 1104 Post(s)
Liked 1,825 Times
Quoted: 1143 Post(s)
Liked 1,740 Times
I've been riding mainly 170, but have recently picked up 172.5 for a couple of rides. 165 is hamster cage for me at 6'2".
This thread reminds me that I have Campy SR in 180. I haven't used that bike in years.
Bikes: '68 Masi Special road, Grail bike
Quoted: 108 Post(s)
Liked 70 Times
all the fit guides and thigh measurements told me I should use 170s which worked out
well as that was stock on all bikes BITD. after 6+ yrs. of hard riding and many miles
my beloved Campys started to crack. I was able to make a trade with a guy for 165s
I liked how I could spin faster but they seemed a bit much which is how I learned that
the size for me is 167.5 hard to find now. glad I have a NOS backup set!
Bikes: '94 Litespeed Ultimate, Litespeed SS, 72 Raleigh Super Course, 73 Raleigh Super Course SS, 81 Panasonic DX2000 chrome, 74 Panasonic Sport modded, 86' Mongoose ATB Chrome modded, 97 Specialized Stumpjumper modded
Quoted: 22 Post(s)
Liked 33 Times
165mm
I had a bike with 172.5mm cranks and never though about it, until I got a bike (same model) with 165mm cranks realized how much faster and more comfortable I was. My foldy still has 170mm cranks on it, and I often KT tape my knee when I'm on it all day, but other than that its 165mm all day for me. I'm 5ft 10 with a standover height of 31.5 inches and ride 21 inch 53-54cm frames. I ride mostly flat ground city riding.
Cheers! - John
Cheers! - John
