Frame identification please
hey guys,
ive gotten a frame from a friend collector, he said it was a real Faema frame but no Masi or Pela signs on the frame.
it has been poorly resprayed allso...
italian threading i think and rear spacing of 120mm
giepieme dropouts
dot lug cut-outs (allmost the same as in the Cinelli "supercorsa")
frameset wheigs around 1.7kg
if you need more info i can mesure or check other specs u van use
you can check the pics on my profile cause this is my first post i cant insert links
giepieme dropouts
Quoted: 4722 Post(s)
Liked 3,036 Times
Link to OP's picture gallery: https://www.bikeforums.net/g/user/511098
While it exhibits nice workmanship, the features suggest a mid-range frame. First, it uses Gipiemme dropouts, instead of Campagnolo. Second, it does not appear to use a Columbus steerer tube, suggesting either a lower tier Columbus set or a tubeset from another manufacturer. Furthermore there are no reinforcing tangs on the blades or bridges. I'm also surprised to see a flat top seat lug. Finally, there appears to be a fairly long serial number under the heavy paint, suggesting a mid-sized or large, mass volume manufacturer.
What size seat post does it take? Are the tubes mitred? An overall picture and one of the rear dropout would be appreciated. With that collection, I'm surprised you can't provide a definitive answer on the threading standard.
What size seat post does it take? Are the tubes mitred? An overall picture and one of the rear dropout would be appreciated. With that collection, I'm surprised you can't provide a definitive answer on the threading standard.[/QUOTE]
the frame is still at my friends, he sent me those pictures this morning, i can provide more info when i get the frame tonight
Quoted: 3810 Post(s)
Liked 3,335 Times
Lenman -
The FAEMA company went through two or three restructurings.
They had to give up the cycling team in one of them.
They were closed for about one and one half years around 1977.
Suspect that suspension of team may predate creation of GIPIEMME products.
Perhaps T-Mar will know a launch date for GIPIEMME.
Lenman -
Lenman -
Lenman -
Likes For Lenman:
Stop reading my posts!
Quoted: 1443 Post(s)
Liked 1,060 Times
Did Mr. Weymans tell you what tubing he employed to build this frame in 1970?
Any guess as to the replacement fork (why used and what brand)?
tubing is Reynolds 531, as it were the only light tubing used by Belgian builders at that time for top frames.
no clue on the forks, allso reynolds with campagnolo dropouts
atm the son of the original builder is making me a new flatcrownfork as how the original would be
i will display my collection in june and the eventorganisers have invited Eddy to open the revenue so hopefully he will identify it, it has the exact size as eddy's 1972 Colnago Molteni frame for timetrial, 58CC seattube, 54,5cc toptube
original seller of the big stock of frames and parts i bought was close family of Charles Terryn, eddy's mechanic in those late 60's and early 70's
Shifting is fun!
Bikes: Yes, please.
Quoted: 2197 Post(s)
Liked 4,599 Times
That is an interesting frame you've got there, Lenman ! Could you tell us what it says on the bottom bracket shell? I can't quite make it out from the picture:
EDIT: the reason I ask is that it looks like it could be "PS" and "4180", which would be a Plume Sport serial number from ~May 1970. The cutouts in the lugs and BB shell also match the Plume Sport bikes from that period I have seen.
