Is this normal?...Campagnolo Corsa RD
Quoted: 1192 Post(s)
Liked 1,325 Times
The jockey wheels were seized so I disassembled and cleaned them. Years of caked dry grease inside. Still stiff to turn them so most likely new ball bearings are needed.
My question, is it normal for the RD to remain stretched out like this? When compressed it springs out again. Thanks in advance.
Quoted: 2588 Post(s)
Liked 4,823 Times
You're missing a part. Round up the cage-stop screw, rotate the cage ccw about 180 degrees and install the cage-stop screw. It goes in the threaded collar, seen below the lower pivot bolt in your photo.
Voila - sorted
DD
Voila - sorted
DD
Likes For Drillium Dude:
Liked 1,325 Times
I'll have to perform surgery when I'm calm and have more patience.
Liked 4,823 Times
That's rather strange the screw is broken off - the derailleur looks nearly NOS. I hope you can get out the broken-off bit and find a reasonably-priced replacement.
DD
DD
Quoted: 4719 Post(s)
Liked 3,034 Times
The cage stop screw is not required for the proper functioning of the derailleur. Its sole purpose is to keep the cage in a position to facilitate installation and removal of the chain and the derailleur itself.
Likes For T-Mar:
www.theheadbadge.com
Quoted: 2401 Post(s)
Liked 4,350 Times
-Kurt
Liked 4,823 Times
DD
