Wheels on a 1984 Trek 720
I just acquired this bicycle and I’m going through it for the first time. I have the rear wheel on the trueing stand. From the 84 catalog I see the wheels have been changed from 27” to 700c. The rims say Mavic made in France, the hub has 7 cogs and 36 spokes, the hub center is very skinny with Shimano and a spring clip sleeve covering a small hole in the center of the hub.
The front wheel and hub look the same so it’s a matching set. I hear what might be a bearing sound in the rear wheel and the rim is not perfect. I can true the rim and live with the slight dip in the roundness.
I notice that the hub measures 126mm and the dropouts measure ~123mm. I’m obviously not a wheel expert so...
Are these wheels ones I should service and use for touring? Should I splay open the dropouts for a newer wheel?
This bike is in very nice shape and components seem correct except the derailleurs and wheels. I’m not a flipper and plan to ride this bike.
Any thoughts or advice?
Thanks.
Thanks.
Quoted: 4195 Post(s)
Liked 3,837 Times
The wheels are not OEM in my experience. Also likely done because of the French hub/cog system used as the spec one on that bike, the heilocomatic system was unique and not supported by any other company.
Whether they are touring grade and in good condition will wait till I see them in person Andy
AndrewRStewart
AndrewRStewart
I just removed the QR from the axle and gave the axle a spin. The axle is bent, bent enough to grab hold of the QR. Now I’m reading posts about bent axles with seven speed free wheels. I need to get the right free wheel removal tool so I can disassemble or do I opt for another wheelset. I’m 230lbs and plan to tour with this bike.
I guess I’ll check for bearing damage and install a new axle.
Expired Member
Quoted: 3656 Post(s)
Liked 5,392 Times
Touring vs riding around might guide you. If I was planning to tour, and especially at your weight, I'd get a current freehub wheelset.
Likes For shelbyfv:
SE Wis
Quoted: 2741 Post(s)
Liked 3,388 Times
There should be a model number on the hub. I suspect it's a freehub not a freewheel
Liked 3,837 Times
I doubt this. The hub description sure seems to be a Shimano 105 or 600. But we'll all find out soon. At the OP's weight and then adding a touring load I would not run a freewheel hub on a tour if I could help it. Andy
AndrewRStewart
AndrewRStewart
Quoted: 836 Post(s)
Liked 1,058 Times
SE Wis
Liked 3,388 Times
They are definitely not the original wheels which came with Maillard Helicomatic hubs. Hard to tell from the pics, but the hubs look like black Shimano freewheel compatible hubs and the freewheel looks very tight for touring. If you could take closer pics of the hubs and rear freewheel we could all give you some more info. By the way, gorgeous bike ! I just built up a complete bike from a 720 frameset.
The dropouts measure 123, so maybe it was a transition model from 120 to 126 where either could fit? My Cannondale measures 128 and was specifically done for that. Putting a 130 wheel on is literally a stretch, putting a 135 on it would be too much without cold setting it. And also, if the wheel does not completely true up without a hop, give up on it completely. Don't try to reuse a rim that is bent. You are already replacing a bent axle. The Shimano FH1055 hubs I believe are 7sp freehub with 126 spacing and would fit easily. Any 130 freehub could be used too if you spread it, and could go up to 10sp, except I think the 10sp is specific to some models. 7/8/9 was older, then they came out with 10, then 11 is even wider at 131.
Modern cassettes with ramps will shift a lot better even without indexing, and the more speeds the easier it gets as the cable pull gets shorter. And because the spacing is tighter you don't find yourself between gears as much. It becomes very natural to shift with friction (I'm assuming those bar ends are friction). And if you are touring you might appreciate all the gears with 10sp.
