Mafac racer bushing upgrade
French threaded
Bikes: many
CAN IT BE DONE
Apparently the bronze sleeve bearing is supposed to be 10mmOD 8mmID and 9.8mm length
the plastic thrust washer is supposed to be 15mmOD 8mmID and 1/16in thick
Mcmaster has the bearing for $2.17 ea and the washer $0.40 in bronze, over 1$ in plastic.
A. Should I go for it?
B. Is it worth it or only appreciable to the snooty retrogrouch?
C. Plastic or Bronze on the thrust washer?
And before you tell me to spend $12 on better brakes.... NO.
Quoted: 413 Post(s)
Liked 109 Times
Its only money....go for it.
I have 4 sets of titanium crank bolts and titanium Campy threaded axles sitting in a box.....it was only money.
Bikes: Many
Quoted: 5 Post(s)
Liked 10 Times
I would just make sure it's not the bore that is worn. I say go for it. If the parts don't work, send them to me. I have a huge stash of odd bearings/bushings.
Bianchi Goddess
Quoted: 2930 Post(s)
Liked 2,924 Times
I say try it and while your at it order me a set too.
Sugar "Kane" Kowalczyk
Quoted: 7348 Post(s)
Liked 2,470 Times
Now that's clever!
I'm curious to hear how they work in your brakes. I'm glad we have so many Mafac fans here!
Likes For noglider:
is just a real cool dude
Quoted: 31 Post(s)
Liked 32 Times
I just pulled the pair that I had apart that looked like they were on Davy Jones' bike(no not the Monkees' Davy Jones either). Got some aluminum polish and steel wood and went to town. Then just lightly sanded and greased the studs and bushings and they were smooth as butter. What about trying delrin instead of brass bushings?
aka: Mike J.
Do the Racers have the same dimensions as the Competitions?
Bookmarking this thread in case I have a need when I get to that point.
Randomhead
Liked 3,698 Times
I thought that racers had a plastic bushing?
Randomhead
Liked 3,698 Times
the bronze bushings are not a bad idea. I think I might go for a flanged bearing. 5448T3 has a 16mm flange, although the outside of the bushing area is 12mm. You could cut that down on a lathe or ream the arms.
French threaded
Bikes: many
Some racers had bronze bushings. There are a lot of racers out there in a lot of iterations.
To clarify, the brakes I have are the red plastic sleeve.
I pulled them and cleaned them but just got to thinking about how much of a difference bronze would make. Target bike is a 69 PX10 and that predates the mafac competition brakes, but still, Racers were some of the best brakes anywhere in the 60s.
Also brazed pivots (a la PY10) are not out of the question but I can't find them for the life of me.
Likes For PDXaero:
Randomhead
Liked 3,698 Times
I never saw a Peugeot with brazed pivots before. There was a framebuilder making them a while back, I don't think he has them any more. I am part way through making some, but I'm a little conflicted about permanently sticking racers on a frame; they are unique and you are stuck with them once you put the bosses on.
The ones on the PY10 pictures I saw look very much like Mafac cantilever bosses. The issue with using cantilever bosses is that they are longer, but it seems like they could be modified.
Liked 6 Times
SP
Bend, OR
Likes For bobbycorno:
Ha! You know, maybe I have them set up totally wrong. Also, maybe the problem is with the brake levers (Tektro inverted). Lastly, maybe the problem is with the pads (VO salmon). They just feel very mushy, and don't have the best stopping power. They're also prone to squealing. I can try shortening the straddle wire to decrease the mechanical advantage.
What??? Only 2 wheels?
Quoted: 1222 Post(s)
Liked 645 Times
I've posted this before but I'll say it again. The MAFACs on my UO8 will stop a freight train. They are better than the Weinmanns on my Raleigh. But then, I don't usually go as fast as a freight train.
Real cyclists use toe clips.
jimmuller
jimmuller
Liked 2,470 Times
If they're mushy, the straddle cable is likely to be too short, from too much leverage. If they're stiff but don't stop, the straddle cable is too long.
Set them up right and you'll love them. It takes time and patience, but they're easier than cantilevers to set up.
Likes For noglider:
Really? too short? I thought it's when the straddle cable is too long (yoke is high) that you get mushiness, and when the cable is too short (yoke is low) they feel stiff. Do I have it backwards? Mine are definitely mushy, like something is flexing a lot.
Here are pics, tell me if you think they're too long/short:
French threaded
Bikes: many
In the left frame you can see the actual centerpull bosses, almost straight bosses for the front and slightly inside for the rear, also as you mentioned, shorter.
the plastic (delrin) bushings are the same size as the bornze bushings that were in some models.
The flanged bushing you mention would require me to thin the OD, flange thickness, and flange width.
The ones I have found thus far would only require me to overbore the ID of the thrust bearing, easy enough to do with a drill press.
I really need to get some parts shipped out today but assuming I order parts this week I will buy two full sets, firstly in case of some failure of adaptation, but also, if it works I will send the second set to another member (bianchiGirl already voiced interest) for an impartial review.
Hopefully its not just hype. There has to be some reason that bronze bushings were installed on nicer models.
But is the canti stud that you have propped on the fork leg inverted 180 degrees? The spring retainer hole should be facing in. Would flipping it change the position of the post?
French threaded
Bikes: many
Not mounted, just balanced with the use of one of the rear pivots underneath... :sneaky:
Liked 2,470 Times
I'm not sure what's ideal. I could be wrong but I'm pretty sure longer decreases leverage. When I shortened mine. I got more stopping power.
Bikes: Many
Quoted: 5 Post(s)
Liked 10 Times
If the straddle wire is too short, the caliper arm will flex first. If the straddle wire is too long, the brake wire will flex first. You are correct Tom.
Another thing to consider is the amount of cable movement for blade movement. If it pulls less wire, it pulls with greater force.
