Wheel bearings
Wheel bearings
Old 05-06-15, 04:01 PM
tgod288
Wheel bearings
I have a 2009 Scott speedster s50 that I want to replace the wheel bearings on. How do I know what size I will need? Where is a good place to order from?
tgod288 is offline
Old 05-06-15, 04:18 PM
alcjphil
alcjphil's Avatar
Quoted: 971 Post(s)
Liked 318 Times in 211 Posts
You start not with the make and model of the bike but rather with the make and model of the wheels, more specifically the hubs of those wheels. Bike manufacturers change component specs all the time. There is not even a guarantee that your bike has the original equipment wheels
alcjphil is offline
Old 05-06-15, 04:23 PM
FBinNY
Quoted: 4361 Post(s)
Liked 17 Times in 17 Posts
Are you talking about replacing press in cartridge (aka sealed) bearings? Or just new balls and grease in traditional cup/cone hubs?
Grade 25 balls are easy to find and better than you need, yet not much more costly than lower grades (lower grades have larger numbers). Hubs typically (but not exclusively) take 1/4" balls for the rear, and 3/16" in front. They don't make all kinds of in between sizes, so a simple eyeball/ruler measurement is OK to determine which.
Bearings themselves are a different story and you need to find the right spec.
FB
Chain-L site
“Never argue with an idiot. He will only bring you down to his level and beat you with experience.”, George Carlin
FBinNY is offline
Old 05-06-15, 04:37 PM
Duo
Bikes: classic & vintage road bikes, some newer stuff, tandems, and a few mtb's
Quoted: 80 Post(s)
I like keeping a variety of bearings in my tools available for bicycles. Amazon seems to have a variety pack, not sure what the odd ball sizes are for?
https://www.amazon.com/Piece-Bicycle-...9S7XGDRYGKQP5E
Duo is offline
Old 05-06-15, 04:46 PM
ThermionicScott
7-speed cultist
ThermionicScott's Avatar
Quoted: 2779 Post(s)
Liked 699 Times in 491 Posts
There's a helpful chart about halfway down this page: Harris Cyclery Bicycle Ball Bearings
1/8" are used in Shimano freehubs and some pedals.
Originally Posted by noglider
RUSA #7498
ThermionicScott is offline
Old 05-07-15, 08:09 AM
HillRider
Bikes: '''96 Litespeed Catalyst, '05 Litespeed Firenze, '06 Litespeed Tuscany, '12 Surly Pacer, All are 3x8,9 or 10. It is hilly around here!
Quoted: 1438 Post(s)
Liked 260 Times in 209 Posts
And 5/32" balls are used in Campy hubs.
HillRider is offline
Old 05-07-15, 10:23 AM
rmfnla
rmfnla's Avatar
Bikes: Gilmour road, Curtlo road; both steel (of course)
Quoted: 271 Post(s)
If they are cartridge bearings there should be a number etched into the side of the metal case or molded into the plastic grease seal.
Try Googling that; often replacements can be found in industrial supply stores at surprisingly low prices...
Today, I believe my jurisdiction ends here...
rmfnla is offline
migrantwing
Bicycle Mechanics
25
11-18-18 11:31 AM
WGB
Bicycle Mechanics
16
10-25-17 12:49 PM
Danielle
Bicycle Mechanics
18
09-20-13 08:10 AM
Maguvemi
Bicycle Mechanics
4
05-28-11 04:27 PM
finsfree
Road Cycling
8
03-15-11 07:50 PM
