How small chain wheel fits on a 144bcd crankset?
MIKE is my name!
Bikes: hans lutz, , puch mistral ultima,2x Austro Daimler Smoked chrome Ultima,Austro Daimler Mixte,Austro Daimler 531 mixte, flying arrow,F Moser,
Quoted: 7 Post(s)
Liked 20 Times
I got a 42-52 and I swear I saw a 39 somewhere,
Is this correct?
Trying to do something to get me arse up the hill after photogravity.
(Now how long will it take to see that funny picture with the mounting points outside the cogs?!)
Is this correct?
Quoted: 3464 Post(s)
Liked 2,829 Times
Super Moderator
Quoted: 1173 Post(s)
Liked 927 Times
Put on a compact and off you go. Sell the 52/42 on Ebay
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
The 39T you saw was probably a Shimano 130 bcd 39-52 crank, like an Ultegra or something.
I have seen photos of some interesting workarounds where people have drilled new holes in a smaller ring, getting alarmingly close to the teeth. It looks like a lot of work for very little benefit. Making your freewheel bigger by one or two teeth makes a bigger difference in your gearing than reducing your chain wheel by the same amount.
Cisalpinist
Bikes: blue ones.
Quoted: 5 Post(s)
Liked 16 Times
Anyway, Sheldon got us all covered.
https://sheldonbrown.com/cribsheet-bcd.html
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
I imagine the worst part was getting beat up the hill by a guy with an IGH.
Bikes: many
Quoted: 1444 Post(s)
Liked 1,392 Times
I thought someone on CR manufactured a 40T ring for 144BCD. Wasn't a lot of spare meat as I recall. Ah yes, here it is:
https://groups.google.com/d/topic/cl...6Wo/discussion
I suspect you will have to subscribe to view it. I've attached the one image that Google Groups will show at the moment.
Hopelessly addicted...
Bikes: 1949 Hercules Kestrel, 1950 Norman Rapide, 1970 Schwinn Collegiate, 1972 Peugeot UE-8, 1976 Raleigh Sports, 1977 Raleigh Sports, 1977 Jack Taylor Tandem, 1984 Davidson Tandem, 2010 Bilenky "BQ" 650B Constructeur Tandem, 2011 Linus Mixte
Liked 10 Times
I thought there was someone that would drill and tap a NR crank for an inner 74BCD or something like that ring?
Liked 10 Times
www.theheadbadge.com
Quoted: 2422 Post(s)
Liked 4,395 Times
-Kurt
Liked 2,829 Times
For a triple. Campagnolo made some specifically this way and others just machined the spider arms. One can tell a "factory" part from an aftermarket modification by the milled flutes in each arm, on the Campagnolo issued part the flutes stop short of the fastening hole, on the aftermarket efforts the threaded hole stops in the flutes. Campagnolo, Galli and probably a few others made the extension bolts to mount the inner ring. I forgot what was the smallest Campagnolo offered, 36 comes to mind. Aftermarket work could be different of course. Bob Freeman of Elliot Bay Cycles in Seattle was known to have done or sourced a number of modifications.
Quoted: 786 Post(s)
Liked 520 Times
^ Looks like he still does?
https://www.flickr.com/photos/8379107...7622574585267/
Hence the ? Was kinda expensive then also ($160?). Including chainring (TA).
