Fun with Metric Taps
Old 07-20-18, 10:52 AM
Aubergine
Bad example
Quoted: 804 Post(s)
Liked 159 Times in 74 Posts
I have had an old Campy rear derailleur - a 980 I think - in my stash for some time, and I also had a Soma long cage replacement for a Nuovo Record RD. I just could not bring myself to modify a Nuovo Record rear (it is just so gorgeous) but the plain lines of the Soma long cage mated up pretty well with the squarish 980. When I tried to bolt the Soma cage to the 980, though, I discovered that it used an M7 bolt rather than the M6 of the NR. So I tapped out the cage, and voila! Now to find a bike to use it on.
Aubergine is offline
Old 07-20-18, 11:30 AM
squirtdad
squirtdad's Avatar
Quoted: 2336 Post(s)
Liked 2,802 Times in 1,531 Posts
nice
squirtdad is offline
Old 07-20-18, 12:05 PM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
That guy that bought the Italian Bianchi Touring bike needs to try that..
fietsbob is offline
Old 07-20-18, 12:10 PM
masi61
masi61's Avatar
Quoted: 1163 Post(s)
Liked 441 Times in 314 Posts
Did the M7 tap self center as you enlarged the hole? Or did you have to fixture up a holding device of some sort and drill first to enlarge the M6 hole? Just curious.
BTW - what gear range are you going to be shifting with the long cage?
masi61 is offline
Old 07-20-18, 12:31 PM
Aubergine
Bad example
Quoted: 804 Post(s)
The tap did not self center. For this, I simply eyeballed my work carefully and it went in straight.
I have no idea yet what bike I will use it on. All of my old bikes use triples, though, so I will find a place for it!
Old 07-20-18, 12:59 PM
leob1
Quoted: 292 Post(s)
Liked 106 Times in 69 Posts
It does look elegant. Post pics when it's on a bike.
leob1 is offline
Old 07-20-18, 03:04 PM
Aubergine
Bad example
Quoted: 804 Post(s)
Thank you. I will do that!
Heatherbikes
Classic & Vintage
53
01-30-21 09:19 AM
embankmentlb
Classic & Vintage
31
01-18-19 06:43 PM
long john
Bicycle Mechanics
7
10-08-18 02:44 PM
Heatherbikes
Classic & Vintage
13
07-07-14 12:40 AM
Johnonaschwinn
Bicycle Mechanics
5
11-05-12 09:41 PM
