How do I ride up seemingly impossible hills?
Old 01-30-08, 06:55 PM
prhey404
prhey404's Avatar
Bikes: Specialized FSR xc
So I am just getting into mountain biking... I bought a fsr xc from my local bike shop, didn't add anything, so it's still stock. I went riding yesterday and had the most fun in my life at Oleta park. I was getting used to the hills and getting enough confidence to start riding faster. I was doing good, zooming tree roots and zooming up hills, when I saw another hill coming up, and FAST. I was building momentum and riding up it when I saw a huge tree root at the top, how the heck was I supposed to jump that at the top of a 5 foot hill??? I slammed into it, of course, and almost fell backwards (thank GOD for my front brake)!!! How should I approach it next time? Also... I got lost on another trail, and again, was doing well with turns and jumps until there came another hill, this one, literally IMPOSSIBLE, it seemed! But must not be if it's there. Pretty much it was like, (im guessing) about a 70 degree angle upwards, almost straight up!!! I'm in pretty good shape so I know I can do it if I keep practicing...
HOW DO I RIDE UP THOSE STEEP ASS HILLS???
prhey404 is offline
Old 01-30-08, 07:02 PM
M_S
You don't jump it per-say, instead you just want to pop the front wheel over...like a slow motion bunny hop but both wheels do not leave the ground, at least not at the same time. Once the front wheel is over pop the back one over as well. Clipless pedals help a lot with the back wheel IMO but aren't necessary. It should help a bit that you have rear suspension, but don't rely on it to do all of the work. Getting the front wheel over is a balance between unweighting the front end enough to pop it up and not faling over. Practice. Momentum helps.
As for steep hills non-technical hills, anticipate them and build up speed, then power up them. A good set of legs helps. Again I like clipless pedals because I can pull up for short bursts but again, they aren't necessary.
Finally, not all climbs are rideable. If you 'aint hiking, you 'aint mountain biking. [/tired phrase]
M_S is offline
Old 01-30-08, 07:09 PM
prhey404
prhey404's Avatar
thanks! I saw a few threads about clip-less pedals, got to check those out. might get some once I get more experience. So are you saying full speed ahead, but when I get to the top of the hill with that tree root, I have to do that part slower, and concentrate about getting the front wheel first, then the back one? In my mind I was thinking (funny, I know) that I would have to go really fast and jump over the whole thing on momentum. I guess not! I have so much to learn. Thanks for the advice! I'll keep this in mind when I confront it again this weekend!
prhey404 is offline
Old 01-30-08, 07:47 PM
c_m_shooter
c_m_shooter's Avatar
Bikes: Soma Pescadero, Surly Pugsley, Salsa Fargo, Schwinn Klunker, Gravity SS 27.5, Monocog 29er
Quoted: 186 Post(s)
Liked 234 Times in 166 Posts
On short hills make sure you are in the gear that you are going to need before you start the climb. Even if you end up spinning like mad at the bottom, your drive train will hold up much better. After a few times out you will start to know what gear you need to be in, and those short climbs will be easy.
For the roots, you need to practice on level ground first just picking up the front and rear wheels seperately. After you can cross logs and roots with one wheel at a time, then you can start trying to clear with one jump.
c_m_shooter is offline
Old 01-30-08, 07:52 PM
Cheeto
Bikes: Trek 3900
Do like a horsehop type thing./
Front tire, then back tire.
Cheeto is offline
Old 01-30-08, 08:40 PM
prhey404
prhey404's Avatar
I have been reading my manuals, have to make sure I know what the drive train is... I can go over roots, but not a log yet, so far I have been avoiding them. The gears as well, the guy who worked at the park told me so far to only use the right (or back) brakes mostly, and front brake only in emergencies. There is a practice obstacle course separate from the trails to practice on, there are logs there, and a narrow bridge too, which I have to practice on, too. I'm so glad I found this forum, so much good advice and inspiration and knowledge on here. Thanks for all the responses! I'll repost here about how I do this weekend, after I confront the beast again... Thanks!
prhey404 is offline
Old 01-30-08, 08:43 PM
Cyclist30907654
Proper usage of the front brakes is fundamental to braking technique. A large portion of your braking power comes from your front brakes. Don't worry about getting thrown over the bars. As long as your weight is back, it is difficult to get thrown over the bars by sheer braking force along (on flat terrain at least)
Cyclist30907654 is offline
Old 01-30-08, 08:50 PM
Cheeto
Bikes: Trek 3900
Your suspension will also help you from going head over heels.
Cheeto is offline
Old 01-30-08, 08:54 PM
ProFail
Generic Title
ProFail's Avatar
Bikes: 2008 Trek Fuel EX7, 2007 Trek 1600, 2007 Eastern Warthog
Not necessarily. You can easily bottom out poorly adjusted suspension, which could result in frame failure. Also, if you bring your bike over a log, but don't lift weight off the rear wheel, then you could easily hit the suspension in such a way that the force is applied laterally versus vertically, which would mean that the bike would not go over the log and the suspension would not compress... Which will end up in a very, very sudden stop.
</past experience>
ProFail is offline
Old 01-30-08, 08:56 PM
prhey404
prhey404's Avatar
I can see that one of the most important things I need to learn is how to brake and use my gears correctly. With more practice I know I will learn. The thing is, I see that if I fall in these trails, could be pretty nasty. especially on hills, and drops, that if I make the wrong move, well, (don't want to think about that right now). I am BIG on safety, don't want to get too excited and break anything on my bike (or myself). It's just that it's so much fun, I know I want to compete eventually. Also I see that from shifting my weight during turns and leaning back from the saddle and letting it flow over hills turns is big too. Pretty much I come from a runner, basketball background, mtb is totally new to me. I'm comfortable, but don't want to get too excited and hurt myself.
prhey404 is offline
Old 01-30-08, 08:57 PM
prhey404
prhey404's Avatar
what is bottom out?
prhey404 is offline
Old 01-30-08, 08:58 PM
ProFail
Generic Title
ProFail's Avatar
Getting hurt and breaking gear is part of the sport.
EDIT- Bottoming out your suspension is when the suspension has no more travel left, IE it's compressed fully. At this point, any more stress will be applied to the wheels and frame. A very hard landing could bottom out your suspension, potentially bending a wheel, cracking a fork, smashing your linkage or compromising your frame.
ProFail is offline
Old 01-30-08, 09:07 PM
Cyclist30907654
Uh, you don't want your fork to dive under braking. It's indicative of too much weight in the front.
Old 01-30-08, 09:16 PM
prhey404
prhey404's Avatar
My dealer at my LBS pumped air into the shock (I think), which somehow does something for the back wheel, rear suspension, pretty sure of that. I'm trying to read the manuals but when I go over roots and big rocks I can feel the suspension, how it helps. I felt kind of bad when there would be at least a 4 foot drop and I would slam down and keep riding. See, I just bought this bike and I'm new to this... And when riding street (when I don't have time during the week to hit a trail) ride over street curbs and everything... What I'm trying to say, what is the timeframe that I have when I beat up the bike on the trails, before I can expect damage to a new bike? I would hate to just start and break something. But like ProFail said, damage is part of the sport. I think really I just need to keep learning and go with the flow... Practice makes my curiosity perfect! Bottom line, I'm HOOKED!!!
prhey404 is offline
Old 01-31-08, 06:52 AM
douglas1
douglas1's Avatar
theres no way you can make it up a 70 degree hill.
douglas1 is offline
Old 01-31-08, 08:21 AM
junkyard
Fourth Degree Legend
junkyard's Avatar
Bikes: 2005 Kona Cinder Cone & 2010 Cannondale SuperSix
God damn. You think too much. Just ride your bike. With time and experience, you'll find what works for you.
junkyard is offline
Old 01-31-08, 10:59 AM
Fat Boy
Wheelsuck
Fat Boy's Avatar
Use your front brake _a lot_. Just not to the point of locking the tire. It'll be 'hello trail' if you do. When you're on the brakes, all the weight is coming off the rear and it makes it easy to lock the rear tire and skid. Locking the rear is no big deal, it just tears up the trail for the next guy and it doesn't slow you down much.
As far as the log at the top goes, Pop a wheelie and get your front over it. When your chainring touches it, you can drive forward on the ring, then pop the rear over it. If this is the technique that many people have used, the top of the log will be seriously chewed up by all the chainrings. You only have to be careful to not slam the chainring into the log too hard. They can take a pretty good shot, but doing this wrong will bend stuff up.
Fat Boy is offline
Old 01-31-08, 11:58 AM
No Mojo
Bikes: Emonda SL7
Liked 32 Times in 12 Posts
Best damn advice I’ve heard all week.
No Mojo is offline
Old 01-31-08, 12:03 PM
C Law
Too Much Crazy
Bikes: Eriksen 29er, Gunnar Roadie, Niner RLT, Niner RIP 9
Quoted: 116 Post(s)
Liked 3 Times in 2 Posts
it sounds like you need to make a few upgrades to your bike.
C Law is offline
Old 01-31-08, 12:05 PM
born2bahick
Official Website Waterboy
born2bahick's Avatar
Bikes: a lot
Junkyard is known far and wide for his "cut to the chase" type wisdom!
born2bahick is offline
Old 01-31-08, 12:13 PM
junkyard
junkyard's Avatar
I do what I can. But, that is the first time someone has referred to my posts as "wisdom". I'm flattered.
junkyard is offline
Old 01-31-08, 12:29 PM
probable556
pedal head
Learn to ignore burning quads and lungs & urge to puke.
probable556 is offline
Old 01-31-08, 12:31 PM
markjenn
Quoted: 154 Post(s)
Liked 14 Times in 11 Posts
My thought is that for someone who is just getting started, you're rushing into tackling some pretty hard things. I'd work up to it more - let your skills grow to the task a bit. You can get hurt out there.
- Mark
markjenn is offline
Old 01-31-08, 12:32 PM
junkyard
junkyard's Avatar
Same advice that I give to most of the women that I date.
junkyard is offline
Old 01-31-08, 12:36 PM
Cypress
Globo Gym lifetime member
Cypress's Avatar
Bikes: Fast ones
Quoted: 410 Post(s)
Liked 614 Times in 306 Posts
LOL
Feed me a stray cat.
Cypress is offline
