What's with fat patches, anyway?
Old 12-07-15, 08:39 PM
FedericoMena
FedericoMena's Avatar
Bikes: Viruela, Piccola
When I started biking I bought a box of tube patches; I think it came with 50 or so round ones that are maybe 5 cm in diameter, and they feel a good 1.5mm thick. I haven't used them all up yet. I carry a few in my toolkit, along with sandpaper and rubber cement.
One day my LBS owner, an old and cranky ex-racer, looked and my toolkit and complained at those ugly patches. Too big, too fat, he said. So he gave me a 10x10 cm square of a thin rubber patch sheet. Cut up a little bit each time you need it, he said.
I love it. I can make patches that are about 1 cm square, and they are thin and pretty. I've been going through the sheet, one little bit at a time, and it's just so nice. I don't have skinny tyres or anything, but these work so well!
Why do patch kits come with huge and fat patches, anyway?
FedericoMena is offline
Old 12-07-15, 09:03 PM
DrIsotope
Non omnino gravis
DrIsotope's Avatar
Quoted: 4905 Post(s)
Liked 1,731 Times in 958 Posts
The patches in my kit are about the size of a US dime-- 18mm or so. I've not personally seen larger.
DrIsotope is offline
Old 12-07-15, 09:18 PM
Plimogz
Global Warming Witness
I have on occasion used a large patch out of one of the kits I had purchased to repair both punctures on a snake bite. I have also used a larger than usual size to patch a centimeter-long gash from a particularly nasty road debris. However, for the majority of flats, when the puncture is basically a pinprick, the smallest patches get the job done just fine.
As to thickness, I have come across thicker, less compliant patches in some cheaper kits; these tended to deform the tube more after repairs. But I have not had any problems using patches similar to the one sold by Rema -- similar in thickness, not necessarily with the nice feathered edges.
Whatever works well for you and reliably gets you back on the road
Plimogz is offline
Old 12-07-15, 10:50 PM
Andrew R Stewart
Andrew R Stewart's Avatar
Quoted: 4191 Post(s)
Liked 3,834 Times in 2,293 Posts
Could the thick patches be from the auto world. Years ago I watched an old time mechanic patch my auto's tire using a similar patch. He used a wire wheel on a hand drill to buff the inside of the tire casing before layering glue then the patch. I suspect he could have taught me a few things if I hung around more. Andy.
Andrew R Stewart is offline
Old 12-07-15, 11:06 PM
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds. 2019 Giant Explore E+3
Quoted: 1785 Post(s)
Liked 1,259 Times in 868 Posts
The feathered edges of REMA patches allow you to overlap patches easily. You can't do that with thick edges.
I'll pay a bit more for a patch that has always worked for me.
Bill Kapaun is offline
Old 12-08-15, 08:20 PM
noglider
noglider's Avatar
Quoted: 7333 Post(s)
Liked 2,430 Times in 1,419 Posts
I don't know for sure, but I assume they make patches thick in the middle not because we need them to be thick but so that they can be thin at the edges. I suspect this tapered edge helps keep the patch in place.
noglider is offline
seanspotatobiz
General Cycling Discussion
10
07-11-18 12:38 PM
bikebike3
Bicycle Mechanics
13
07-01-18 12:03 PM
waverider627
Bicycle Mechanics
31
11-06-17 08:44 AM
dgk02
Commuting
51
10-29-12 07:09 AM
work4bike
Bicycle Mechanics
19
09-19-11 08:03 AM
