26.4 extra set back seat post
Hey everyone!!
First off I’m not sure if this is the correct place to post this. If not I’ll remove it and post it in the correct forum.
I own a early 80’s Bianchi which came with a 26.4 seat post. I am trying to source a new seat post with extra set back to mount my brooks saddle. I’ve looked on eBay but no one ever posts the actual setback so have no real clue what to look for. Does anyone have any suggestions for a specific brand of seat post to look for?
My other thought was purchasing a Velo Orange 27.2 extra setback seat post and then having a machine shop mill it down to 26.4. Not sure if that is the safest solution though!
OTOH, 27.2 minus 26.4. is 0.8mm difference.. a hand reamer, used in the seat tube,
can shave out the 0.4mm of tube wall thickness from the seat tube ID
ro fit a 27, 2 seatpost into..
seat tube if 28,6 diameter outside , is having a 1.1mm tube wall , leaves 0.7 mm tube wall
reinforced with the seat post itself..
this is the common wall thickness of butted seat tubes, butt being the thicker, bottom end
where its brazed/welded onto the BB shell..
you have a frame using un butted seat tubing.. same top to bottom..
years ago I did a lesser amount of cutting, reamed from 27.0 to 27.2,
and I had the seat post in hand, stopped cutting as soon as it fit.
as a result its the best fitting of the fleet..
Old fart
Quoted: 3590 Post(s)
Liked 3,400 Times
I have a 26.4mm Sakae Ringyo MTE-100 post. PM if interested and we can work something out.
Bikes: 80's Schwinn High Plains, Motobecane Ti Cyclocross
Quoted: 108 Post(s)
Liked 30 Times
The Velo Orange seat tube is ovaled on the inside to reduce weight.
You would be asking for a catastrophic failure if you took 0.8mm off of the OD!
Quoted: 4806 Post(s)
Liked 3,931 Times
Avocet made posts of much less setback, but more than most. Stay clear! They break. (I've had mid-ride failures 3 times on the two post I've owned. (Edit: those are probably all 27.2 and not a possibility for you anyway.)
Ben
Mother Nature's Son
Quoted: 853 Post(s)
Liked 1,437 Times
I have an old, 1991, steel frame bike that takes a 26.4 seat post and have been looking for another. The original snapped off just below the seat clamp 2 years ago. I have been using an Uno and it is heavy and does not look good on my bike. It is hard to find a quality 26.4 seat post. I have been looking for quite awhile on alot of different sites. I just purchased a low cost 25.4 carbon fiber post off e-bay and mounted it in the seat tube using shims and electric tape. It took a couple of tries to get it set up in a way that it would fit into the tube and stay put with the seat tube clamp tightened down. At this point I am not sure if I would do that change again. If I was to do it again I would try to get a post closer in size, like a 25.8 or 26.0/26.2.
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
Thanks Everyone!! I appreciate all the replies!
The Ticycle seatpost are crazy expensive!! I know you warned me but WOW!! I won't be heading down that avenue anytime soon, as a new frame would be less expensive.
I'm gonna try a few other options first and then maybe PM John!
How about the Kalloy UNO 602 on eBay. It has 24mm setback, vs the Velo’s 30mm. Should be enough though?
https://www.ebay.com/itm/Kalloy-Uno-...cAAOSwDOlbmTCV
Quoted: 913 Post(s)
Liked 515 Times
Another possibility:
https://www.amazon.com/Kalloy-26-4-X...2JL&ref=plSrch
Quoted: 1163 Post(s)
Liked 442 Times
GT makes a chromoly one that is curved for setback with a very secure micro adjusting head. This come up fairly often on eBay for ~ 35$ or less. They are heavy but if durability and adjustability trump light weight - this one would be a good choice.
Cycleway town
I formed this lay-back seat-post at work, for my Hercules, but it means using a candle type seat clamp...
By GT are you meaning a BMX seat post, like the one shown in the picture below? If so how would that translate over to an 80's road bike? I'm also thinking that maybe a double bolted Campagnolo seat post may have a bit more setback than my current seat post so may look at picking up a used one of those.
Liked 442 Times
Not quite like the Hercules in post #13 . But yeah, it might have been for BMX originally. It is made out of thin steel so it probably weighs about 500 grams. But I do think the GT would work for a utility road bike. I bought it for a Trek Multitrack 720 that I’m fixing up. Turns out it takes a 26.8, not a 26.4.
