Knife-thin 9mm open-end wrench
Is there a 9mm open-end wrench that's only ~2mm thick? I have a set of wrenches that are 3mm thick but they're too thick. You might be able to slip a butter-knife into the slot that gives me access to the wrench flats.
novis rebus studentem
Bikes: Orbea Alma 2018, Specialized Allez comp triple 2007, 1977 Raleigh 3sp, 1984 Raleigh 531 Campy road
Quoted: 7 Post(s)
Break out a belt sander and take one down to what you need. Be careful and don't go too fast and ruin the temper and don't shoot the thing into a wall or worse - yourself - ask me how I know. I don't know of any wrenches that thin. If you don't have a belt sander a piece of 150 grit sandpaper on a board and rub a millimeter off one of your wrenches. Take your time and do both sides to keep it equal. If you want to keep it nice looking polish it out with 220 then 400. You can put a nice finish on most tool steels and it can even look "factory" if you take a little time and do it right. If you use wet/dry emery paper a little oil won't hurt and I bet the entire job wouldn't take more than 20 minutes.
Quoted: 2026 Post(s)
Liked 1,096 Times
My Park and Campy cone wrenches measure 2 mm (0.082") thick but I've never seen one with an open end smaller than 13 mm.
it would be cut out of sheet steel , (or sacrifice a butter knife)
you can go DIY on some 1/16th thick steel sheet ,
with a sharp file, that has a toothed edge,
(or stack a few hacksaw blades in the saw, for a wider cut)
and bench vise, to hold it.
... if no one does a web search for you, and finds something.
Old fart
Quoted: 3590 Post(s)
Liked 3,401 Times
My Park brake caliper wrenches (BCW-n; 8mm/10mm, 9mm/11mm) are 3mm thick, which apparently is too thick. I do have an old, long out-of-production 8mm/9mm Artisan Tool & Die brake caliper wrench that is only 2.5mm thick. Might be tough finding one, though. Grinding down a thicker open end wrench is probably your best bet.
on grinding..
Have a pot of water handy , (old school) as grinding heat
can soften tempered steels ,
so dunk the work in the water frequently and that won/t happen
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,220 Times
Stuart Black
Stuart Black
Liked 1,096 Times
Park CBW-4 or Park OBW-4 should do the trick.
like we used to say
Ignition wrenches come in 9mm and are slim profile like that.
Quoted: 608 Post(s)
Liked 352 Times
One thing to consider is to step back and think...why would a designer make something that requires so thin a tool when servicing? When such a rare tool is almost non existence.
One thing is that it is quite possible that you are doing something wrong in your assemly/disassembly of somehting.
I had similar situation working on a internal gear hub. At first, I thought I needed a wierd shaped thin wrench. But working on it and wrecking my brain for a while, I realized I didn't need such a wrench. It's not designed to be needed for remove. I was not doing the proper way of assembling it. Once, I figure out the proper way...the special wrench was not needed.
Shimano Certified
X2 on the ignition wrenches. I use them all the time and a set of them can be had from a car parts store for less than $20.
Liked 4,220 Times
timo888 said about 2mm. The difference between 3.2mm (1/8" or 8/64") and 2mm is 3/64" (5/64"). It depends on the application but that should fit into the "about" category. A millimeter is pretty tiny.
Stuart Black
Stuart Black
Liked 1,096 Times
Cone wrench?
Old fart
Liked 3,401 Times
Non omnino gravis
Capri Tools makes an 8x9 combo open-end wrench that is 2.6mm thick. Pretty much every other "thin" wrench I found is 1/8" (3.2mm) thick. I think if you're looking for 2mm, might have to make it.
Liked 4,220 Times
Stuart Black
Stuart Black
Quoted: 2483 Post(s)
Liked 2,955 Times
Quoted: 5224 Post(s)
Liked 3,584 Times
Bikes: 1978 Bruce Gordon, 1977 Lippy, 199? Lippy tandem, Bike Friday NWT, 1982 Trek 720, 2012 Rivendell Atlantis, 1983 Bianchi Specialissima?
Quoted: 346 Post(s)
Liked 175 Times
I measured my vintage Mafac tool kit wrenches as 2mm thick. Trouble is the 9mm is closed but I suppose one could cut it open? There are several sets up on Ebay most any time.
aka: Dr. Cannondale
Quoted: 2155 Post(s)
Liked 3,406 Times
I would source a piece of thin strap metal and cut a nine mm wrench out of one end, unless the application requires something harder.
