What is the schedule for TLC on a bike?
I have 4 bikes; 2 hybrids, 1 road and 1 mtb.
Most of my rides are 30k(5 mi) on pavement 4-6 days a week. The MTB sees gravel and sometimes muddy wet trails.
How often should I clean and lube the chain? ( I use dry lube and wet lube on the MTB )
Should it be based on mileage or just a seasonal thing.
Seasonally, but not every year, I clean and grease wheel bearings, give the bikes a good cleaning, adjust brakes and derailers and check chain wear.
I never use a pressure washer to wash my bikes. The MTB is the only one that sees a lot of dirt.
I check air pressure before every ride. (45 psi for 26 x 1.95 tires, 80 psi for 700 x 35c and 110 psi for 700 x 23c)
I just wipe the bikes down with Spray Nine or soapy water usually mid season.
I let the MTB if muddy, dry and than use a brush to get most of the loose dirt off before I wipe down.
I like to use a leaf blower if the bike gets wet from a cleaning or I was out for a ride in the rain.
So give me the good, the bad or the ugly on what you think TLC should be on a bike?
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
First, 30k is not 5mi...it's 18.
Lube your chain when it needs it. You'll know...probably 100ish with dry lube, maybe 2 or 3 times that w/ wet lube...if your dry lube means thin and wet is thick. When the chain starts looking dirty w/ the wet lube at worst. I clean and lube the chain on my mtb every ride. I clean my mtb every ride, that includes suds and a hose. I think that letting the mtb dry after a muddy ride is the absolute worst thing you can do. Wash it as soon as you get home, it's much easier. Leaf blower is fine, or wipe dry w/ a towel. If it's cold and the bike won't really air dry quickly the leaf blower is great.
If I were riding my road bike 3-5 times a week in the dry I'd probably wash it once a week. The less you let them get dirty the easier it is to clean them. I have a bit of bike washing experience having been a pro team mechanic from '04 to '17.
Likes For cxwrench:
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,220 Times
Stuart Black
Stuart Black
Likes For cyccommute:
Quoted: 668 Post(s)
Liked 529 Times
Have to agree with everything cyccocommute said.
Likes For Pop N Wood:
You are right 30k is 18 miles. Most people overstate their distance. I probably was including the seniors discount on the mileage.
At 70 yrs of age I bike and also do 8K (5Mi) runs 2-3 times a week.
I just tell everyone that I am 21 with 49 yrs of experience.
Thanks
Thanks
Likes For msdumo:
Bikes: 2012 Specialized Elite Disc, 1983 Trek 520
Quoted: 676 Post(s)
Liked 741 Times
You're doing more and better than I do for routine care. In addition to what you're doing, to me it's all about paying attention to the bike and being proactive. I often ride long days with fellow volunteer mechanics, and a quiet bike is a point of pride for all of us. Check the chain every 1000 miles and replace when indicated. Don't neglect the slightest changes in shifting and braking. If you're adjusting a barrel adjuster frequently, find out why. I should service my road bike headset more frequently than I do (every couple of years), but I pay frequent attention to its adjustment. I service the cup and cone hubs every year (3 to 5,000 miles), and check for play and free rotation every time I add air.
Quoted: 6196 Post(s)
Liked 4,810 Times
Nice thing is that you can be a finicky as you want. If fiddling with things and spending more time with your bike disassembled soothes you more than time you spend riding, then that is actually okay with me. I'm more the other way though. I generally wait for something to actually cause problems or break. And I think it's cheaper than getting too wrapped up in preventative maintenance.
Quoted: 1572 Post(s)
Liked 643 Times
Every time that I ride I make myself aware of any maintenance that I think should be done to that bike. Then I make an effort to get it done before I it again. That's pretty much all that I do.
How much preventive maintenance do you do on your car? For me it's every 5 to 7 thousand miles. That's a whole year of bicycling for most riders and a car is a much more complicated machine than a bicycle.
Likes For Retro Grouch:
Quoted: 676 Post(s)
Liked 741 Times
I notice you didn't say the car is more expensive than the bike, because for many of us that's not the case.
I have worked on bikes in a volunteer shop alongside auto and truck mechanics, and it's funny to see them get frustrated over some small adjustment they're not used to making. One diesel guy said, "You'd think this would be easier."
Bikes: Bianchi Ti Megatube; Colnago Competition; Planet-X EC-130E; Klein Pulse; Amp Research B4; Litespeed Catalyst; Trek Y11
Quoted: 605 Post(s)
Liked 480 Times
Great advice that I consistently try to relate to people who ask me to "sort out" their bikes. Quite often, they're just overly filthy (and need new brake pads).
I've found multi-purpose cleaning wipes (like you'd use in the kitchen) to be very good at giving a cleaned bike a nice final wipe-down, especially if you have to use a lot of WD-40 to clean road grime and ****e off your bike after a week's worth (or more) of cycling.
Likes For ridelikeaturtle:
Bikes: 2016 Masi strada vita due, 2019 Kona Dew Plus
Quoted: 268 Post(s)
Liked 80 Times
I dont think anybody mentioned brakes. Every ride, I blow out dust with compressed air, then wipe disc with alcohol pad. Also every ride, I clean the chain with rag and/or toothbrush. I hardly ever wipe down frame
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
Clean = quiet. Plus, when it comes time for repairs and adjustments you don’t have to deal with months-old road or trail sludge.
Like cleaning your bathroom, if you do it on the regular, it only takes a few minutes. If you let go for a couple of months, it’s a project.
Likes For Rolla:
howdy old Calabogie feller (boy, havent been there in decades)
the most important thing is to keep on top of maintaining the drivetrain clean. Lubing the chain with whatever you lube you want, but wiping down the chain for excess lube is the ticket. Depending on the lube you use, and if you ride in wet or very dusty, wiping the chain after a ride or three with a rag takes maybe 10 seconds?
Totally worth it, while you're at it, use same rag to wipe the rear derailleur jockey wheels on both sides, and a quick wipe of the chainrings too--bingo, in less time that it took me to type all this out, you will stop gunk from accumulating, and like someone said with the bathroom analogy (I use the kitchen analogy clean up myself ) if you do it regularly, its fast and easy and less work.
once in a while, I use a rag to "floss the cassette", wheel on bike, chain in smallest cog, and you pull rag upwards to clean a section, down to turn cassette a bit, up again to clearn all around---easy peasy and fast. Again, do it once in a while and its fast easy and you dont have a hard job of accumulated sticky crud gunk
if you want to clean frame etc all the time, go for it, I'm too lazy and concentrate on drivetrain and keeping rims and brake pads clean after wet riding right away upon return, keeps braking at most efficient.
happy fall riding
happy fall riding
Quoted: 3352 Post(s)
Liked 1,056 Times
As my whole working life was a mechanical/electronics tech, I can assure you that preventative maintenance will prevent you from having to walk home.
Before every ride I wipe down the chain. I use Mobil One oil, and oil as needed. I always top off the tire pressure before every ride. That way by checking the tire pressure I can determine if I have an unexpected slow leak I had better check out before a ride. And a quick check is performed on the whole bike.
Every Feb, I live in the snow belt, I do a complete go over of my bike and trike. EVERYTHING is checked for tightness and lubed. I simply do not want to walk home, and I never had. BTW I also have a mini bike shop in my trunk pack for any unforeseen emergency. It is rather amazing how many times I have stopped to helped other cyclist that simply were not prepared.
Liked 4,220 Times
I don’t have to wipe the chain before, during, or after a ride. I am often told here on the Forums that I’m damaging my bike by doing this but my chains and drivetrain last as long as other people report. I just don’t have to deal with the mess.
Stuart Black
Stuart Black
happy fall riding
happy fall riding
Like the idea of a fast wipe down on the chain after every ride.
I just did my first floss on the cassette. I did allow too much buildup on the cassette which only made the chain get dirtier.
The regime of cleaning bike and chains is a new thing for me.
I added quick links to 3 of my bikes making chain removal easy and better for cleaning and checking chain wear.
Quoted: 569 Post(s)
Liked 584 Times
With way too many C&V bikes to keep track of milage this is the key for me, and like Rolla said I value a clean quit ride and get after any issue immediately.
While I agree, I take a very different approach from most people. I keep the drivetrain clean by using a lubricant that doesn't make the drivetrain dirty. Both of the pictures below were taken of bikes that have been ridden many miles just prior to the picture (the Moots was in the middle of a 30 mile mostly trail ride and the Specialized was in the middle of a 20 mile dirt road ride). Both bikes have not been “cleaned” in a few thousand miles. I can go out and rub my hands over the chain and come away with nearly clean hands. The chains are cleaned before installation and they aren’t cleaned again because they don’t need it.
I half-ass lubed my chain once and replaced it at 4,000, and I rode it in rain, dirt roads, and once in the snow. I have never washed my bike, but have wiped off some excess dirt and mud. I get dressed, hop on the bike and ride. If the tires seem low I check them and add air. Other than that I ride the heck out of it and while riding think of what I will do with all my free time not spent obsessing over my bike's cleanliness, or lack thereof.
Likes For Sal Bandini:
