Am I making a mistake with getting a mid-step radmission?
Quoted: 15 Post(s)
I'm about 5'10 without shoes with an inseam around 34.5 inches with shoes on. I have a wingspan of 68.5 inches, so long legs and short arms.
after a lot of research, i've pretty much decided that the mid-step radmission is better for me due to my longer legs and little bit shorter arms. I know nothing about bikes though, so part of me is still feeling like its a mistake to get the mid-step, and that it will be too cramped. I am at the max recommended inseam for the mid-step version too.
I have no way of testing it out before I buy it either.
Am I making a mistake by going with the mid-step? Does anyone have similar measurements for your proportions and ride the mid-step? Everything I read says i'd be better with more of a medium frame and not a large, but I just worry it will feel too small and i will regret not getting the bigger one.
Bikes: 2022 Priority Coast, 2022 Priority Current
Quoted: 175 Post(s)
Liked 137 Times
Get the bike try it out if it doesn't work return the bike. That's the method to D2C bikes. Keep all the packaging. If it works keep the bike. Good luck.
Ride more, eat less
Quoted: 715 Post(s)
Liked 737 Times
What kind of riding do you plan on doing on this Radmission?
What kind of bike are you used to riding?
What are the measurements on the bike that you are used to riding?
What is the reach, what is the standover height? what is the geometry of the bike that you are used to riding?
Quoted: 883 Post(s)
Liked 824 Times
It's possible to adjust the cockpit of a bike with a different stem, bars and/or seatpost if it's necessary. Alternately, go to a bike shop and find a similarly sized pedal bike and try it out (or possibly a used bike on Craigslist etc). Sounds like you might be in analysis paralysis.
Quoted: 341 Post(s)
Liked 276 Times
If you gave me one, I would probably crush the Rad Mission after scavenging all the useful pieces. Why? It's only one speed. They are catering to uneducated customers or clueless hipsters.
Ride more, eat less
Quoted: 715 Post(s)
Liked 737 Times
Maybe that's why nobody is giving you a Rad Mission?
Single speed e-bike may not suit your purpose, but plenty of other people can use it without the complication of shifting gears while cycling.
Calling people who might need a single speed e-bike "uneducated customers or clueless hipsters" is the same type of mentality that drive people from bike shop employees that think every customer is buying a $5k bike when they walk through the door.
Likes For cat0020:
Quoted: 2497 Post(s)
Liked 741 Times
Given the o.p.'s dimensions the choice between mid-step or high step come down to functionality. Women that wear dresses or skirts find mid-step (or stagger, or mixte) designs easier to use than high step designs. Most will have ample inseam to straddle a 'mans frame' but culturally will be biased to the mid-step. I personally choose the 'large' frame of a S,M,L size offering. I compensate for the added 'reach' of the larger frame with a shorter stem. It is absolutely the o.p.'s choice which to try.
Likes For Leisesturm:
Liked 741 Times
Quoted: 883 Post(s)
Liked 824 Times
Not to argue, but speaking as one who rode a single speed mountain bike off road in nasty terrain for 20 years before age took it's toll and I resorted to gears, the SS e-bike would make sense (to me) unless the terrain was hilly. The important aspect is being able to maintain half of the bike's top speed when ascending in order to avoid a significant portion of the battery's output being absorbed as heat by the motor.
If you dont mind replacing main harnesses, displays and controllers, then by all means get a rad!
Just my experience making repairs when they quit.
-SP
-SP
Likes For speedy25:
It comes down to comfort level and how you plan to use the bike. A standard frame can be difficult to manage when making a quick stop and having to straddel the top tube of the frame and more of a concern for men than for women. In a city where one may have someone all of a sudden come in front of you, a step through is helpful. Same goes for putting anything on the rear of the bike like a rack with some groceries or other items. Tough to get the leg all the way over the rear to dismount quickly. If you plan on wearing long pants and conventional shoes than a step through is easier to manage as compared to someone in shorts and or bicycling shoes.
Step through frames are heavier and so with non motorized bikes, the standard triangle frame has been more popular. The first really popular trail motorbike was the Honda Trail 90 introduced in 1964 and it had a step through frame. With e-bikes we are going back to the small ICE trail bikes of this era.
I had a RAD Mini, it functioned fine, electronics worker flawlessly. I used it to get me back in shape for a few months and my friend still has it. The Mission looks like a nice bike, the mid step may be more convenient for getting on/off easier.
Or people who live in towns where there are few hills. Much like the 2WD pickups and cars that are sold to people who will never leave the pavement and never encounter snow and so have no need for 4WD or even AWD. I have come across many posts by people who bought an e-bike and have not had a bicycle of any type for more than 30 years and now are having trouble with adjusting the derailleurs on their new very heavy bikes.
Aventon Pace 500
https://www.aventon.com/products/ave...-complete-bike
Liked 5 Times
I would definitely consider a DIY bike, then you get the best of all worlds (quality frame, components and more performance from the electrical system). You could probably find a nice used mid-range touring/hybrid bike and do a conversion!
Likes For senatorsca:
I really like mine, does what they say it will, simple operation and for a bike with no suspension the tires give a pretty good ride. The single speed doesn't bother me at all, with the assist, it climbs all the hills I ride. On the flats it will happily breeze along at 18-20 mph. The thing is built pretty stout, welds were good etc. The red color is almost a day glow dark orange (the pics don't really capture the tone) and is very visible far off. I had their Mini 4 and it functioned great, but to me it was more of a scooter/moped and was a lot heavier to move around, my friend still has it with a lot of miles racked on it. For $1100 IMO this is a nice e-bike,
