Trek 660 - 1984 - Upgrade Questions
mollusk
Quoted: 7 Post(s)
I'm planning to upgrade a 1984 Trek 660, and I'm looking for some advice on what components to use. Previous rebuilds I've done have been with mostly Sram components, but I'm leaning toward Campy. Any specific suggestions? Planning to replace pretty much everything.
(I can't post images or links apparently. Otherwise I'd link to the specs for this bike on vintagetrek)
Questions:
Is it safe to assume the bottom bracket is English?
I can measure soon, but does anyone know the bottom bracket shell size? 68mm or 70mm?
Anything I should keep in mind regarding spacing for the wheelset?
Front derailleur clamp should be 28.6mm right? Should I just get a shim and use a new 31.8mm clamp?
Thanks
Questions:
Thanks
The dropped
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold) : 1966 Schwinn Deluxe Racer (sold)
Quoted: 1739 Post(s)
Liked 1,014 Times
Try Vintage Trek
Since you have a Trek that's more than 30 years old, try looking up the catalog on Vintage Trek. You should be able to find the components and geometry, at least, and from there figure out your questions, including answers to questions you haven't asked yet. You should still measure all the parts you plan on replacing, regardless of information in a catalog.
Why upgrade when you can restore it? Other threads indicate that the bike was equipped with Campy components. The good news is that you might not need to do much. The bad news is that the Campagnolo name will carry a premium for NOS or used components that are still out there.
You might get more advice on the Classic and Vintage forum. Of course most people will advise you to restore.
mollusk
Quoted: 7 Post(s)
Quoted: 2026 Post(s)
Liked 1,096 Times
BTW, as recommended, look up the 1984 Trek catalog on the Vintage Trek web site. All the OEM specs are there.
Yes, the BB is English threaded and 68 mm. Rear spacing is 126 mm (6/7-speed) and it came with 700c wheels. The original components were Campy New Record. It was one of Treks higher line bikes at the time but of course the components are very dated by now. If the one you get is in good shape and the frame is sound, you have the base for a fine ride.
mollusk
Quoted: 7 Post(s)
Don't. You can't be sure what you are getting and you may be (pleasantly or unpleasantly) surprised. Wait until you have the actual bike.
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
mollusk
Quoted: 7 Post(s)
No Trek of that era used anything other than a 68mm shell and English thread.
Assuming no previous owner has cold-set the frame otherwise, it should have 126mm OLD spacing.
The seat tube is 1-1/8" or 28.6mm. If you want to use a 31.8mm derailleur, you will need a shim.
Liked 1,096 Times
Once again, wait until you have the actual bike before you order any new parts. It's possible a former owner installed a new fork with a JIS crown race seat. Not likely but possible so wait.
Old fart
Liked 3,400 Times
mollusk
Quoted: 7 Post(s)
Thanks for the help. I'm still trying to wrap my head around the exact Shimano/Sram external bottom bracket that'll be compatible with a 68mm shell/english thread. Any rules to follow here?
SE Wis
Quoted: 2746 Post(s)
Liked 3,390 Times
https://www.bikeforums.net/classic-v...i-s-ergos.html
Quoted: 2952 Post(s)
Liked 3,106 Times
Any standard English BB, including Sram GXP or Shimano Hollowtech II, will fit.
mollusk
Quoted: 7 Post(s)
Hi HillRider,
This groupset just went up for sale on Craigslist, and I'm wondering if I can find a bottom bracket (168mm English) that's compatible with it. Thoughts?
https://losangeles.craigslist.org/sg...018577664.html
Liked 1,096 Times
Hi HillRider,
Once again, do you now have the frame and fork? Assuming the frame is original, the rear dropout spacing is 126 mm and that group will require a 130 mm rear wheel. You will either have to force the wheel into place each time, which is not that difficult, or have the frame "cold set" (read bent) to 130 mm.
I don't understand why you would buy a vintage bike if you want a (semi) modern set of components on it. If you wanted a restored vintage bike with original components I understand, or if you already have a bike/frame that you want to upgrade I understand. But to buy an old bike and then upgrade everything? You could have just bought something newer that already worked with these components. Chorus 10 is already 15+ years old and as I have that on my bike, I can tell you new cassettes get expensive, although just about everything else can be bought used. And one other note, if you want a 50/34 crank instead of the 53/39, you'll be looking around for a while. Campy wasn't big on compact cranks.
Another thing to consider are the bars. If this bike has old style bars vs. newer ones contoured for brifters, you'll never get things positioned correctly. I have a modern brake lever on an old style bar and it is awkward, but that doesn't include the shifter. It'll work it just won't be optimal.
And don't get me wrong, I upgraded an old Trek MTB to 10sp myself so I know how tempting it is, but it wasn't the intent to do this. I just wanted better brakes (canti to v-brakes), which led to new levers, which led to new shifters, which led to new derailleur, which led to going to 10sp, which led to new cassette and chain, which led to new wheels. It was my commuter bike and was used a lot, the 10sp wasn't really necessary but the system works really well, I could stop on a dime, and I also added dynamo lighting on the new front wheel. It looks like crap so it won't get stolen so readily but rides like a modern bike.
DigitalN
Road Cycling
33
06-24-11 01:30 PM
Chziime
General Cycling Discussion
5
04-25-10 10:39 PM
