Track Racing Frames and Complete Bikes
#227
Bikes: T1, S2, P3
Quoted: 5 Post(s)
From Dixie:
"Unfortunately, since we are a very small company it is taking some time to make our "big boy" frames.
We are hoping for late winter to early spring to have both the 60 and 62 frames."
F' it Im selling my stuff and playing basketball instead.
Seriously, where do I get a big frame? Im on a 58 cervelo and its too small. Im 6'4, I need a big bike. BMC, Argon, Cervelo, all out. Felt says its a 60 but their stem is odd, Im not sure it would fit right either. Fuji makes an XL 595mm but its unavailable until next spring. Even chinese frames I can't find anything 60cm
Im at a loss, other than just waiting for a Fuji (although 'next year' often means 'mmm maybe never')
#229
Specialized Bicycle Components
Cannondale makes a 60 track frame and I was just examining one - it appears to be a modified road bike.
Both frames are aluminum alloy.
#230
Elitist
Quoted: 1386 Post(s)
Liked 92 Times
Specialized makes a 61 frame and at at my local track this frame is a popular choice including by some national master champions.
#231
Bikes: T1, S2, P3
Quoted: 5 Post(s)
What is the deal on the TK1 sizing? The L says its 60 but the propriety stems are crazy short. Can you run a regular stem (120) with those?
#232
Elitist
Liked 92 Times
Also, the short stems don't take into account the length bayonet thingy. They come out to be a max of 110 or 120mm.
#233
You are correct - I measured a 61 bike and the TT was around 58.5. But I have found reach is more important than TT length.
#234
aka mattio
the bayonette fork steerer tube is short; the stem doesn't attach to the steerer tube, it has a proprietary interface with the stem topper thingy. so, if they have shorter than usual stems, it's because they attach much further forward than on ordinary systems. capisce?
#235
From Dixie:
All-City makes their Thunderdome in a 61cm. Have a look, it might suit your sizing needs. I just ordered a 58 and it's dead on with sizing compared to my 58cm All-City road bike. The 61cm would be too big, the 55 too small.
#236
I thought I'd throw in here the dimensions for the BT Edge 59cm frame. After a conversation I had last night via FB, it was eluded the the dimensions for the BT frames are quite elusive. I emailed BT last year and they got back to me within a day. I have recently contacted them for the 61cm dimensions, but as yet I don't have an answer.
So for the BT Edge 59cm frame:
Top Tube C-C 59CM
Seat Tube C-T 53CM
Head Tube Angle 74deg
Seat Tube Angle 74 deg.
Head tube height/length 130mm
Bottom Bracket drop 50mm
Top Tube C-C 59CM
Seat Tube C-T 53CM
#237
Bikes: Planet X Pro Carbon, Dolan FXE, Fuji Transonic
Quoted: 5 Post(s)
Boardman bikes are coming out with a new track machine. Thoughts? I'm not keen on the looks myself.
https://www.boardmanbikes.com/produc...te-tk-9.8.html
#238
Bikes: T1, S2, P3
Quoted: 5 Post(s)
#240
aka mattio
#241
My BB knowledge isn't up to date with the many types these days, but that will only allow you to use cranks that run external BB's? Excluding ISIS, Octalink etc?
Quick comparison with the track frame and their ATT aerodynamic road frame - geometry is identical in the large (didn't check the other sizes) so appears they have just added horizontal drop outs to a road frame.
#244
Lapped 3x
I also never understood why Boardman and UKSI didn't just partner up commercially and slap "Boardman" on the downtube of the UKSI bikes. Make a cheap generic clone and you're all set to play within the UCI's commercial rules.
#248
Elitist
Liked 92 Times
Not to mention the 43mm offset road fork.
Also, the longest top tube is 57cm. Really? REALLY? In 2016, the longest top tube on the £1,400/$2,000 flagship frame is 57cm.
That frame is probably worth $500-700...retail.
But, but it's carbon. So it must be really good, right?
#249
Elitist
Liked 92 Times
Oh, and the handlebars are from the road line, so 40, 42, or 44cm based on the size of the frame.
What the heck?
So, when all of the leading bikes in the world use 74 degree seat tube, they choose 76-79 degrees?
Upright seat tube, short top tube, 73 degree head tube, low bottom bracket for a £1,400/$2,000 "C10" (not sure what that means) carbon fiber frame that bears the name of one of the greatest and most meticulous track racers ever.
I find it hard to believe that he had much to do with the decisions that went into this bike.
This is a road TT frame with a road fork (instead of a TT fork) and track ends slapped on the back.
Compare this with the Hoy. A man of similar laurels who also started a bike company. The Hoy track bike is affordable, strong, and has the same geometry as the bikes you've seen in world-level competition, all for a fraction of the price.
According to wikipedia:
That might explain a lot.
The TRK 9.8 also benefits from Boardman’s 4-point seat post to allow the riding position to be dialed from 76º-79º to suit your riding style.
In 2014 the UK bicycle and car parts retailer Halfords acquired Boardman Bikes for an undisclosed sum.
#250
aka mattio
