[Brompton] Difference between Ridea calipers?
Quoted: 573 Post(s)
Liked 118 Times
Hello,
I read that the brake calipers + levers from Ridea offer much improved braking power compared to the stock Brompton brakes.
I have a couple of questions:
- What is the difference between the three models, "21F Dual-Pivot Caliper Brakes W/ mudguard", "Dual-Pivot Caliper Brakes W/ mudguard", and " 3D Dual-Pivot Ti Bolts Caliper Brakes"?
- As a way to save a bit of money since a caliper + lever already cost ~ €200… is there a retailer in Europe that sells just the front brake + front lever?
Hello,
I'd assume that in terms of money saving the easiest thing is to stay away. There's sometimes a lot of magic mystery around tuning parts for people to justify their choices and spending. Personally, I am happy with the Brompton stock brakes and do not feel the need for more break power. If I felt that need I'd spend my money on brakes that are actually different and provenly offer more brake power like Magura Hydraulic brakes, V-brakes or disc-brakes (with the latter needing modifications on frame and fork). I cannot imagine that the Rideas offer additional break-power that would be worth 200€ per piece. It seems basically to be a bit of bling, mainly adding to the optics and indiviualization of the bike and maybe a tiny bit in weight but less - if at all - in objectively better break power. Better break power seems btw. not on the list of what Ridea promises for these breaks - which makes me even more suspicious that forum posts you found may be buyers trying to justify their (totally legitimate) buy with some fake objective reasons...
Quoted: 573 Post(s)
Liked 118 Times
Thanks for the infos.
Considering I'd probably have to buy the whole thing at a total cost of 250+150=€400… it's worth thinking about it.
OTOH, a 100mm custom fork + disk brake is even more expensive, and makes for a bigger fold.
Quoted: 573 Post(s)
Liked 118 Times
I had the opportunity of riding a barely used Brompton from 2014, ie. from the same year as my own, and felt the brakes were smoother and stronger.
FWIW, I replaced the original cable + cable housing on mine with no-name equivalents, but noticed no difference.
Is it just an impression, or do brake calipers and/or levers wear out and lose a bit of power? Would some maintenance make a difference? Should I get new calipers + levers from Brompton?
Thank you.
Thank you.
I to like the stock Brompton brakes. First step I would give a good cleaning to the brake surface of the rims with some alcohol and then lightly sand the brake pads where they come in contact with the rims. If you still don’t like the brakes second step I lightly sand the brake surface of the rims and replace the brake pads. Sometimes when you ride in the rain road oil and dirt will get on the brake surfaces and need to be to be clean off.
Quoted: 573 Post(s)
Liked 118 Times
Thanks for the tips.
It's also that the levers don't feel as smooth as new ones. Would taking the calipers apart and greasing every point of contact make a difference?
BTW, do we know which company actually makes the Brompton's calipers?
Quoted: 105 Post(s)
Liked 38 Times
1. They DO NOT offer better braking power. They have exactly the same geometry as the stock brake, which means they have exactly the same mechanical advantage.
2. They should have better pads than stock ones (ANYTHING is better than stock pads) but you can just get pads separately. Get quality pads (Shimano or SwissStop).
3. If you want to shave some grams, get titanium bolt kit (only $30~40) is the best bang for buck.
Likes For Raxel:
