38c tires on 15c rims?
Bikes: yes
Quoted: 1281 Post(s)
Liked 643 Times
Are you referring to the fact that 700 x 38c should be written 700c x38mm? Specifically, the "C" refers to the French 700 C rim system, which is 622 mm BSD per ISO? And that the tire width is in mm? Don ksryder, consider the Wizard your Sancho Panza in this matter.
As a counterargument, I had an argument via email with the Philly Inquirer's excellent food writer, Craig Laban. He used the work decadent to describe a meal, meaning indulgently and overly rich. I consider the root of that word to relate to decay. So a decadent meal is a disgustingly decaying meal. He argued that words mean what the populace has come to understand them to mean. Bah. You might as well use "gender" when you mean "sex". Wait.. hmmm.
Anyway, numbers, units, and specifications mean something. So it IS 700c x 38mm.
I suppose this seems incongruous with my insistence on using proper units of measurement, but to me there's a difference because a unit such as "mm" has a concrete, unchangeable meaning, whereas "38c" means precisely nothing.
Back to the OP, I have no idea what caused his failure, but my personal opinion is that concerns about wide tires and narrow rims are overstated but not completely without merit, and 15mm seems like a very narrow rim for that tire.
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,218 Times
Under the old French system, tires were meant to remain the same height so they changed the rim size to fit the height of a tire. A skinny tire was put on a larger rim to maintain the same height as a wider tire put on a smaller diameter rim. The "C" was meant for wider tires so it had a smaller diameter. The system was kind of silly in that you'd have to adjust rim brakes all the time if you wanted to swap out tires for some reason.
Stuart Black
Stuart Black
Bikes: yes
Liked 643 Times
I don't know how any of the Jan Heine bashing follows in this thread. He's skeptical of *road* tubeless involving ~25mm tires, but he's pretty content to run larger tires tubeless on gravel. Retro-grouches sometimes come around on new technology, they're just not early adopters.
My opinion is that it's because he fails to acknowledge that gravel is different everywhere, and that the gravel in the midwest is a lot chunkier and pointier than the gravel I assume he must encounter on a daily basis.
As someone who lives in the midwest, we're used to people on the coasts coming in and telling us what we should be doing and how we're wrong, despite not living here nor having rode bicycles here. It's arrogant.
There is a reason you don't see anyone in the midwest, who is not sponsored, riding Rene Compass Hearse tires on gravel.
(Ted King ran those tires at Dirty Kanza this year and I have it on good authority that he had some punctures even though he never said anything publicly about it.)
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
If you are going to tilt at windmill, make sure you are tilting at real ones. It's 622mm x 38mm. Even the "700C" part is wrong. The "C" part is often thought to mean centimeters but a 700cm tire would be 7 meters (22 feet for the metrically challenged). And it would take a very, very wide tire on a 622mm rim to get to 700 mm...78mm to be exact. That's 3" or what a 29er would use.
And it only takes a 39mm tire to get up to 700mm. That seems pretty reasonable to me.
RUSA #7498
Liked 4,218 Times
Most people probably don't know what the "C" stands for. It's a left over from an old, defunct system that is no longer used and hasn't been for decades. The way that we size bicycle tires is an entire mess anyway. Why size them by the size of the tire? It's a dumb system. We should size them by bead diameter and worry about the height and width separately.
Stuart Black
Stuart Black
Last edited by Homebrew01; 08-19-19 at 02:37 PM. Reason: Edited quoted OT content.
Liked 2,568 Times
Liked 4,218 Times
That said, "gravel" roads in the mountainous portions of the west are a lot rougher and aren't really "gravel" so much as rocks. Even there flats due to actual punctures of the rock itself are relatively rare.
Stuart Black
Stuart Black
Generally bewildered
Quoted: 1152 Post(s)
Liked 341 Times
cyccommute point in saying that the French system assumed a 700mm (nominally, I think) OD of the wheel, and then adjusted the rim BSD to accommodate different tire widths, is consistent with my understanding. That Nobel Laureate of cycling, Sir Sheldon (here), has curated this info, see below. Note that unless you have a hankerin' for rare stuff, you're talking 700 C and 650 C. I wouldn't say that 700 C hasn't been used for decades. It's (per ksryder's comment) the common tongue way of saying "ISO 622". I suspect it always will be....
Now, if you say ISO 622, are you referring to tubular or clincher tires?
I think that clarity and correctness is the point. So 700 C x 38mm is clear, if not per ISO. But my old 24 inch frame, with the chain at 1 link/inch, is not ISO either and everyone probably understands the terms mean. All sorts of idiosyncracies remain. My favorite is Lowenhertz magneto threads (flank angle of 53°8', not 60°, with flats at top and bottom with width equal to 0.125 times the pitch, and with thread height equal to 0.75 times the pitch - I think Lowenhertz came up with this just to drive the Ultra-rationalist metric Nazis up the wall...).
Francais ISO Size (BSD) Purpose in Life
700 A 642 mm Obsolete
700 B 635 Rod-brake roadsters.
700 C 622 Road bikes, hybrids, "29 inch" MTBs.
700 D 583 Oddball size formerly used on some GT models. 650B tire (584 mm) is slose enough, maybe with wide rim tape.
650 A 590 French version of 26 x 1 3/8; Italian high-performance bikes for smaller riders
650 B 584 French utility bikes, tandems, and loaded-touring bikes; some older Raleigh and Schwinn mountain bikes
650 C 571 Triathlon, time trial, high performance road bikes for smaller riders
Liked 4,218 Times
My point is that understanding tires would be a whole lot easier if we used the bead diameter. There would be far less confusion. Your list is only the French side of the equation. There are a lot of other sizes from other countries.
Two notes. The 635mm rim is also the mostly obsolete 27" wheel used on 1980s American road bikes. Curiously (and confusingly) the 622mm rim is called a 28" rim in England and Europe.
The 584mm rim is what is being used for 27.5er (a worse moniker for a class of bikes can't be found).
Stuart Black
Stuart Black
Bikes: More bikes than riders
Quoted: 1446 Post(s)
Liked 762 Times
I totally agree with referring to this stuff by BSD (622mm, etc.). Ironically, more people know what a "700c" wheel is than a "622mm" wheel. It's sort of a self-perpetuating problem.
Liked 4,218 Times
The 29er craze has caused all kinds of puzzled looks at my co-op when I tell even experienced volunteers that they have the same wheel diameter as a "700c". Oddly, the 29er tubes keep ending up in the 700C/27" used tube bin.
Stuart Black
Stuart Black
Liked 341 Times
So, I'll raise a glass of Gevrey-Chambertin and think of your point the next time I put a new 27 and a half-er on a wheel...
Liked 341 Times
PS I believe that the 27 inch wheel is an ISO 630, and not 635mm. Or is ISO 635 a 630mm BSD?
Bikes: 2014 Bruce Gordon Rock&Road, 1995 Santana Visa Tandem, 1990 Trek 520, 2012 Surly LHT
Quoted: 211 Post(s)
Liked 43 Times
Maybe the OP has gone down the rabbit hole of historic tire size and no longer cares why they crashed. But in case they haven't then Lennard Zinn (before any one piles on I will admit he may not be a reliable source of information) just addressed one potential failure mode for tubeless road. See https://www.velonews.com/2019/07/tec...e-power_495710 . I quote "This last week I awoke in a helicopter ride to a hospital. Nobody was around when I crashed, and I have no memory of the crash. Only worrisome part is the front tire [road tubels] was flat with no punctures."
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
Liked 2,568 Times
All this talk of tire sizing reminds me of foreign languages. Some people get really upset that not everyone will speak "their" language, others simply make an effort to be conversant with everyone.
