Poor man's load cell
Bikes: Bambu bike with Bafang Hub kit
Had my battery in pieces on the bench and no safe way to consume the 43V and test if the BMS repair was working.
So I hooked up some household electrical wire to some metal bits and dangled it in a ceramic pot with some salted water.
Worked like a charm, frothy nasty looking stuff formed on the container and boiling type action not much heat, considerable rapid corrosion on the end bits and 5-15 amps of load depending on how far into the mix. Enough for a monitored test.
Just in case you are stuck for a load source.
