10-speed crank and 11 speed drive train
Bikes: Masi, Giant TCR, Eisentraut (retired), Jamis Aurora Elite, Zullo, Cannondale, 84 & 93 Stumpjumpers, Waterford, Tern D8, Bianchi, Gunner Roadie, Serotta, Serotta Duette, was gifted a Diamond Back
Quoted: 305 Post(s)
Liked 2,038 Times
Will a 10-speed campy crank work with the campy 11 speed drive train?
Quoted: 305 Post(s)
Liked 2,038 Times
So a 11 speed chain won't be too narrow for the chainring teeth?
Many people have reported success with using 10 speed cranks with the 11 speed chain. I've done it with a Campy 10 crank. FWIW, the teeth of the 11 speed rings are only .1mm or .004 inch thinner. That's about the thickness of a sheet of paper.
the steel chain will wear the faces of the aluminum chainring a little .. till there is plenty of clearance..
Quoted: 305 Post(s)
Liked 2,038 Times
thanks, you guys are a wealth of knowledge.
rpenmanparker
Bicycle Mechanics
10
12-05-14 11:57 AM
kraftwerk
Road Cycling
5
08-17-12 10:53 AM
