Is Ultegra the top notch Shimano groupset ?
Thinking of buying an S-WORKS frameset and building a bike.
Not a SRAM fan.
Not a SRAM fan.
Should Be More Popular
Quoted: 22609 Post(s)
Liked 8,930 Times
ah so ...
On Your Left
Quoted: 3004 Post(s)
Liked 2,434 Times
DEADBEEF
Location: Catching his breath alongside a road near Seattle, WA USA
Bikes: 1999 K2 OzM, 2001 Aegis Aro Svelte
Liked 6 Times
It depends. Dura-Ace is the flagship Shimano group but there are sometimes reasons one would pick Ultegra or parts of Ultegra over Dura-Ace. The main difference is actually found in weight. Dura-Ace components are lighter. But sometimes that translates into less durable. In the past (don't know about current), the D-A bottom brackets had a shorter average lifespan than Ultegra. It used to be that Dura-Ace shifted noticeably better than Ultegra but in recent years and with the latest incarnations, pretty much everyone (including myself) will claim that their shifting performance is on par. Also, there are certain things you can get in Ultegra that you can't with Dura-Ace. For instance, if you want to run really low gearing, you have to go with an Ultegra RD (GS) and cassette since D-A stops at 28T whereas Ultegra will go to 34T.
I recently upgraded my bike from 2001 9-speed Dura-Ace with FSA cranks to a primarily 11-speed Ultegra Di2 group with Dura-Ace shifters and an FSA crank/BB combo. Even though I "stepped down" a notch, my bike with Ultegra actually weighs less than it did with the 9-speed D-A group due to advancements in technology, material and design.
1999 K2 OzM 2001 Aegis Aro Svelte
"Be liberal in what you accept, and conservative in what you send." -- Jon Postel, RFC1122
DEADBEEF
Liked 6 Times
Seconded... unless you have some deep-down aversion towards electronics....
Just as something to consider... Ultegra Di2 costs about the same as Dura-Ace Mechanical.
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
Granted almost all gadget companies make decent hardware these days and screw up the software....But Shimano really f'd up their firmware support toolset.
Quoted: 45 Post(s)
From reading a previous thread the OP stated he has been going to the same LBS for over ten years and now he is asking the forum is Ultegra the top Shimano groupset. Am I the only one that finds that odd? I researched groupsets before I ever bought my first bike.
DEADBEEF
Liked 6 Times
Just so long as you make sure to spend a good day reading on compatibility issues....and you're prepared to need a few graduate degrees in order to mess with the firmware in the future.
Emondafied
Bikes: See sig
Quoted: 63 Post(s)
Honestly I'd be happy with Ultegra on a new bike in any form. Decades ago when I built my bike, there was a noticeable shifting difference between DA and Ultegra, but even with my 9-speed stuff, the 105 on my spare bike and the DA on my main bike are very similar. Probably better to put that money into a decent pair of wheels.
my bike page - my journal
Current Stable: Trek Emonda SL - Trek Top Fuel 8 - Scattante XRL - Jamis Dakar Expert - Trek 9700 -AlpineStars Al Mega
Quoted: 2432 Post(s)
Liked 641 Times
He also rides 200 miles a week as a *cough* "Clydesdale", all the mileage he racks up has given him a "longer stroke", does MMA training, has a gymnast girlfriend, has a masseuse, a saddle nose down 10 degrees, raised his saddle multiple times but says he was fitted at the shop, a pump mounted on the right side, flipped his stem for a more aggressive position at 40+mph, flipping his stem put him in a "runners starting line position", says flipping his stem soaked up road vibrations.........
Quoted: 5888 Post(s)
Liked 3,472 Times
I ride Ultegra Di2 and love it, sure DA is the top line stuff but unless you're bleeding $$$ out of your pockets and need the lightest bike the shifting performance will be pretty much the same. I would only consider DA components if I found them on sale and only after my Ultegra components decide to wear out.
I have 10 speed Dura-Ace and 10 speed Ultegra on two different bikes. Not delighted with either although not horrible. Ultegra is heavy and the reliability is questionable from my experience with it.
Put SRAM Red 22 on two bikes. Quicker shifting and much more intuitive shifting and the FD on the Red requires no trimming.
If you're doing a greenfield build and update everything to the latest firmware then there shouldn't be any issues. Granted the firmware situation gets muddier if you're going from 10-sp to 11-sp and you're mixing 6770 and 6870 series components. Still, it's not all that complicated.
Not true. Pretty straightforward.
Bikes: 2021 Trek Checkpoint SL (GRX Di2), 2020 Domane SLR 9 (very green), 2016 Trek Emonda SL, 2009 Bianchi 928, 1972 Atala Record Pro
Quoted: 85 Post(s)
Liked 143 Times
Bikes: BH, Cervelo, Cube, Canyon
Quoted: 212 Post(s)
Liked 6 Times
Bikes: 2013 CAAD10 Black Inc.
Rather than buy another factory bike i will prolly buy an S-works frame set and have my tech build me a bike.
Basically because i need beefier components.
Ive already talked with him about it.
Quoted: 63 Post(s)
Your "Master Tech"?
