Converting a single speed to a fixie.
I have a Murray three speed bike that has a single speed freewheel for some reason. I got it for free and the tires would need to be replace. It’s worth less that 50 dollars. I want to convert it to a fixed gear but don’t want to buy a new wheel so I was thinking of just crippling the free wheel by soldering it. Is there a way that this should be done? Is there a different way to cripple the freewheel so I can ride backwards?
Veteran Racer
Bikes: 32 frames + 80 wheels
Quoted: 1337 Post(s)
Liked 765 Times
What, Me Worry? - Alfred E. Neuman
I see the light at the end of the tunnel, but the tunnel keeps getting longer - me
Clark W. Griswold
Quoted: 4368 Post(s)
Liked 4,008 Times
I would not recommend trying to convert a freewheel to a fixed gear with a non-fixed gear hub. As TejanoTrackie suggested you could do some sketchy stuff with welding and a heavy threadlocking compound but it is not a good safe option and should be understood as a do at your own risk and know it is not really worth it.
I would just ride the bike as is and save your money and time for a proper fixed gear you want.
Old fart
Quoted: 3591 Post(s)
Liked 3,401 Times
I suspect that in order to convert to a fixed gear, you will need a different wheel.
Likes For JohnDThompson:
Super-duper Genius
Quoted: 768 Post(s)
Liked 984 Times
There are hubs threaded on only one side. Some have fixed gear threads, and some have single speed threads. A fixed gear thread has the same diameter and pitch as the single speed, but with a second set of threads, outboard, slightly smaller diameter, and the reverse direction (counter-clockwise to tighten). This is where the lock ring goes. The primary or inboard threads are the same on both types. So you can put a single speed freewheel cog on a fixed gear hub with no issues. To put a fixed cog on a single speed hub, where there is no second set of (reverse) threads, you have no good way to keep it from coming loose, which is dangerous. It is easy to do, but it's usually a very bad idea.
Some hubs, called a flip-flop, have both sides threaded. They might be fixed threads on both sides, to allow for two different cog sizes, or fixed on one side and single speed on the other, giving you a choice of drivetrain types. I don't know if anyone makes a flip-flop with single speed on both sides.
If you don't have a flip-flop hub (or fixed gear hub) and you want to ride both types from time to time, you don't need two bikes. You can get two rear wheels. The wheel is easy to change according to your preference for a particular ride.
