Frame Choices: Surly LHT / Soma Saga / Salsa Vaya / Bruce Gordon BLT?
Sasquatch Crossing
I'm looking for a new frame, and am considering either a Surly LHT, Soma Saga, Salsa Vaya, or Bruce Gordon BLT. I mostly tour on my tandem, so I'd be using it for relaxed riding, commuting, and the occasional tour.
The frames are similar in price (Ok, the Vaya is a little more expensive and the BG is on sale w/ racks for $750 so they're not exactly the same, but close enough to make no difference to me) and offer similar features. The LHT is ubiquitous (and will soon offer disk brakes, too), the Saga is a nicer tubeset and powdercoated (more durable finish0, the Vaya offers disk brakes (good for winter commuting here in Portland), and Bruce Gordon has a lot of experience designing a touring frame so I assume the BLT is an excellent bike and his racks are great, too.
I can find a built-up Vaya and LHT locally to test-ride, but not the Soma or the BG, so I'd be interested in hearing your thoughts on how these frames compare? How do they handle loaded and unloaded, and pros/cons I should consider?
HomeBrew Master!
Bikes: Aegis Aro Svelte, Surly LHT, Cannondal R3000 tandem, Santana Triplet.
Be aware (you might be already) that if you take a 54cm or smaller frame, the Surly only comes with 26" wheels. I like mine. At first I was not sure of them (26" wheels), but over time I have found there are more pros to them than cons. The only "con" being the wheels don't seem to hold downhill momentum as long as 700 wheels.
Not mentioned is the Kona Sutra.
Sasquatch Crossing
Thanks Gus. I can't tell whether the Sutra is available as a frame only or just as a full build. Do you know?
I should probably mention that I'm looking for a frameset only because I will be swapping parts from my current frame. Also, I'm looking at ~56cm and already have a 700c wheelset I will be using for the build.
sniffin' glue
Bikes: Surly crosscheck ssfg, Custom vintage french racing bike, Bruce Gordon Rock & Road
You said you won't really be using the bike for touring, so why pay for front and rear racks with the BG? I mean, don't get me wrong, it is likely a great bike, but seems silly to pay for something you will rarely use.
I like the ride of my BG, it rides nicely both unloaded and loaded, however,i have no experience with the BLT...
HomeBrew Master!
sniffin' glue
I've seen the Sutra in the shops and it looks like a damn fine machine...
DisMember
Bikes: 2010 Fuji Roubaix, 1984 Schwinn World Sport
You know, that $750 BG is the imported frame. Not that that's a bad thing - it's just not an American-made BG.
Bikes: Salsa Vaya, Specialized Roubaix Team Saxo, Fisher HiFi29er
I can only speak for the Vaya, but I can't think of a reason to not go with it.
The geometry is awesome. It is super comfortable. You can run up fo 700X42c (at least) tires which would come in handy in the bad weather. It has rack mounts front and back. It has disk brake tabs. Not to mention the charcoal metalflake color is just amazing.
Compared to the Trucker, it is a bit more compact with a shorter wheelbase and chainstays. I think the Trucker is a touring bike first, while the Vaya is more of a do everything bike that can handle some touring. If you do decide to tour on it, it does really well loaded down with front/rear panniers.
I am sure they are all great bikes. Deciding which one is a good problem to have.
Love mine
Love mine
Bikes: Waterford RST-22, Bob Jackson World Tour, Ritchey Breakaway Cross, Soma Saga, De Bernardi SL, Specialized Sequoia
Quoted: 196 Post(s)
Liked 6 Times
geometry?
Seems to me that the geometry varies quite a bit between these models because I considered several of them when shopping for a touring frame. Your number consideration should be to buy the one that fits you best. In my case, the LHT was out of the question because the top tubes are too long and head tubes too short. The Saga would have been my first choice but it was not available when I was in the market, so I ended up buying a Bob Jackson World Tour from England.
Have you considered a sport touring or cyclo crossframe. If you don't really plan to tour on it, a touring frame is not ideal for general riding, in my view, because it would be stiffer, heavier and slower than a sport tourer like the Gunnar Sport, Soma ES or Salsa Casseroll.
Older than dirt
Bikes: Too darn many.. latest count is 11
My BG racks are approaching 25 years old, and still fine..
BLT Kit includes the similar racks, they are made in house by Bruce.
frame is priced lower by doing like all the others that you listed,
specs sent to Taiwan based contract factories.
the Soma Saga anticipated and fit a solid kickstand mount on the frame ..
a good thing..
For your use a Redline conquest classic is a good pick, too, a disc-commuter of steel,
you can tour on, some.....
a good thing..
One of my friends has a Vaya, it is one fine bike. If I was looking for a touring bike, the Vaya would be top of my list to start.
Love mine
Love mine
old and in the way
Bikes: Icicle Cycles..custom touring bike, Fargo 1st gen
Nice line up to choose from, I chose the LHT when I bought, might do different today. I chose the LHT to get the most upright riding position, highest handlebar height. That was my main criteria.
I have bought a Fargo rev.1, from Salsa, for an even more upright position. Runs larger tires than the LHT. More of a varied terrain touring bike, bigger, softer, tires.
we be rollin'
There's a thread in the mechanics forum with many people saying the biggest change you can make is to use wider tires if you want a more comfortable ride. So, is there really a reason to go with a steel frame rather than a cheaper aluminium frame like the Nashbar touring frame?
Tarwheel, I agree 100%; the geometry of these frames vary quite a bit and fit is most important. I've poured over geometry charts for the last couple years and still would not trust my judgement regarding how a frame would fit without actually sitting on an assembled bike. And as most touring aficionados know, this severely limits one's choices. I know it comes down to effective top tube length, head tube length, and the angles of the seat and head tubes, but I still think I'm missing something. Does anybody have a proven method?
How do you compare two bikes with the following geometry:
Bike 1:
22" effective top tube
5.5" head tube length
71.8 head angle
73.5 seat tube angle
Bike 2:
23" effective top tube
7.9" head tube length
72 head angle
72.5 seat tube angle
Is there a mathematical equation?
Quoted: 137 Post(s)
Liked 81 Times
I suppose to further explain my lack of ability to understand is:
Bike 1:
71.8 head angle
Bike 2:
72 head angle
Bike 1:
71.8 head angle
Bike 2:
72 head angle
Quoted: 137 Post(s)
Liked 81 Times
With no direct knowledge of the Bruce Gordon other than knowing that he's been making bikes for decades my suspicion is that his touring bike has more neutral handling and less wheel flop than the LHT.
Bikes: Hollands Touring Bike, Schwinn mountain bike, folding bike, tandem and triple
I went with the Vaya. I needed the long top tube and I wanted to play with disk brakes. It has worked very well. I run Conti Avenue Semislicks, 700x40c with fenders.
The problem is that nobody around here stocks the Salsa's, Soma's, or any other touring bike for that matter. I managed to track down one Trek 520 and there is a Surly dealer 50 miles away, but it is very difficult to test ride the various offerings. I have to agree with you though, my arm-chair-quarterback impression of what a particular geometry should ride/fit like is rarely what I expected.
Quoted: 196 Post(s)
Liked 6 Times
Bike 1:
71.8 head angle
Bike 2:
72 head angle
Bike 1:
71.8 head angle
Bike 2:
72 head angle
In my case, head tube length is one of the most important variables because I run my handlebars high, about even in height with the saddle. So between these two frames, I would definitely pick Bike 2.
BTW, there is a mathematical formula for determining effective top tube length, taking into account seat tube angle, but I'm not good enough at math to tell you about it. I know that it involves some trigonometry.
Finally, Gunnar bikes has a fantastic fit calculator on their website that is very useful if considering one of their frames or a bike with similar measurements. Basically, you just pick the size frame, stem angle and reach, number of spacers, and it tells you what the reach will be and how much saddle to bar drop.
https://gunnarbikes.com/site/my-gunnar/gunnar-fit-tool/
I recently bought a used Waterford frame and was able to determine that it would fit me perfectly using the Gunnar fit tool.
Old. Slow. Happy.
Quoted: 5 Post(s)
I own/ride a Salsa Vaya and a SOMA Saga. The quality and fit/finish is nicer on the Vaya. I use the Saga for commuting, and the Vaya is my "fun" ride (dirt/gravel/pavement). The Vaya is an extremely versatile bike. In fact, if I had to relegate myself to a single bike, the Vaya would be the one.
Take SOMA's geometry chart with a grain of salt. The seat tube angle on my 58cm Saga is almost one degree steeper than claimed. Also, I wish that SOMA would have paid more attention to the brake boss spacing, as there's very little clearance if you run wide rims (ex: 24mm). Lastly, the Saga's seat cluster isn't very beefy. I had a hard time keeping the seatpost from slipping, and had to resort to Tacx carbon assembly paste and Loctite.
The most important dimension for most people is the top tube length because that determines your reach. However, seat tube angle has a big effect on the effective top tube length. A steeper STA shortens the effect top tube because you have to move the saddle back to achieve the same knee-over-pedal position. Likewise, a more relaxed STA angle effectively shortens the top tube.
I did a bit of googling and discovered a relatively new method of comparing modern frames from different manufacturers. It's called Stack and Reach. Trek and Salsa actually include them in their geometry charts. Does anybody have any practical experience with this? Opiniions?
