2WD Folding Recumbent Tandem
Old 02-04-17, 09:30 AM
cplager
The Recumbent Quant
cplager's Avatar
Bikes: 2012 Cruzbike Sofrider, 2013 Cruzigami Mantis, 2016 Folding CruziTandem
Quoted: 28 Post(s)
Liked 8 Times in 6 Posts
Hi,
Got bored so I did it again.
This started as a folding tandem
and I added a full Cruzbike kit up front and a seat from a second Cruzbike kit in the back. (I had brought this to this years Tour de Bronx, but due to a bad tire, we only rode a few miles).
Because it is so long, it rides really smoothly. But at the same time, it feels like any other Cruzbike (with a slightly more cramped cockpit for me). On it's maiden voyage, I accidentally found myself riding with no hands.
Because it folds, it fits nicely inside my minivan. I'm quite pleased so far.
cplager is offline
Old 02-04-17, 02:10 PM
downtube
downtube's Avatar
Bikes: Many Downtube Folders :)
Quoted: 282 Post(s)
Liked 24 Times in 17 Posts
Nice!!!
Thanks
Yan
Designer of Downtube Folding Bike
Ph.D. Temple University ( Math )
Biked across the USA twice
Semi-active chess player ( two time Bahamas National Champion )
Sivananda ( Bahamas ) Trained Yoga instructor ( 2013 ) and ThetaHealer since 2013
Bicycle delivery worker for Jimmy John's. Delivering is the best workout I have ever had.
downtube is offline
Old 02-04-17, 04:11 PM
jur
Quoted: 321 Post(s)
Liked 7 Times in 6 Posts
How do you change gears on the rear?
jur is offline
Old 02-05-17, 08:43 AM
cplager
The Recumbent Quant
cplager's Avatar
Quoted: 28 Post(s)
The stoker has a twist shifter (that I'll probably replace with a lever). Both of my kids have folding 16" bikes with gears, so they're (kind of) used to them now.
So I choose my gear and they choose theirs.
cplager is offline
Old 02-05-17, 09:02 AM
blakcloud
blakcloud's Avatar
Quoted: 608 Post(s)
Liked 352 Times in 225 Posts
That is impressive.
blakcloud is offline
Old 02-05-17, 10:39 AM
cat0020
Ride more, eat less
cat0020's Avatar
Quoted: 713 Post(s)
Liked 733 Times in 450 Posts
Looks like fun, very neat conversion.
For the life of me, I cannot get used to the front drive-train connected the steering, seems to me that every pedal stroke affect steering input... and climbing hills... well..
cat0020 is offline
Old 02-05-17, 03:21 PM
cplager
The Recumbent Quant
cplager's Avatar
Quoted: 28 Post(s)
It turns out that what starts out as a weakness becomes a strength. Because of this linkage, they are a bit weird to learn how to ride. But once used to them, these bikes are the easiest to ride no-handed of any bicycle I've ever ridden (when taking this out for it's maiden test drive, I suddenly realized that I was riding with no hands without thinking about it).
And they allow you to "put your back into it" when climbing (like DFs do but not most recumbents).
cplager is offline
Old 02-05-17, 03:51 PM
cat0020
Ride more, eat less
cat0020's Avatar
Quoted: 713 Post(s)
After riding bicycles for nearly three decades, I have no problem riding no-handed on bikes that donnot have steering input affected by each pedal stroke, even on a set of rollers.
Most recumbents have low-back support on seat that allow rider to "put your back into it", unlike DF bicycles that do not offer any low-back support.
Imagine a seating squat machine, that's similar to most recumbent riding position.
cat0020 is offline
Old 02-05-17, 05:42 PM
cplager
The Recumbent Quant
cplager's Avatar
Quoted: 28 Post(s)
Bad choice of phrase on my part.
You can very much use your arms with MBB (moving bottom bracket) bikes (like you can on DF bikes). But, yes, "regular" recumbent bikes let you brace your back against the seat and really push (which you can't easily do on a DF).
cplager is offline
Old 02-06-17, 10:37 AM
invisiblehand
Part-time epistemologist
invisiblehand's Avatar
Bikes: Jamis Nova, Bike Friday triplet, Bike Friday NWT, STRIDA, Austro Daimler Vent Noir, Hollands Tourer
Quoted: 122 Post(s)
Liked 3 Times in 3 Posts
Sweet! The independent gears/coasting is a nice feature for riding with kids.
A narrative on bicycle driving.
invisiblehand is offline
Old 08-07-22, 04:44 PM
cat0020
Ride more, eat less
cat0020's Avatar
Quoted: 713 Post(s)
I saw this interesting gem:
Comments below are not mine, but from the article I found.
"Hey Folks. I've ridden the new tandem enough to commit to the powder coaters.
I'm convinced the 2WD system is better for us than a linked timing-chain RWD like our previous tandems.
Bron, the stoker, is much happier being in control of her cadence and I don't feel like I'm pulling her legs around.
The jiggling from out-of-synch pedaling is novel but not a problem. It will get better as we pedal smoother.
I have not noticed any pedal-steering tendencies & the bike is quite manageable even in granny-gear (19 gear-inches).
FWD bikes draw some criticism for their potential to lose control when the front wheel slips (on gravel for instance).
Under our 140kg weight I don't think it will be a problem and seems to be an advantage when piloting solo.
The limits of steering due to the twist-chain FWD set up are not an issue when riding, even in a U-turn.
It is a small pain when we use a tight rail-crossing chicane on our commute.
The short sections of chain-tube are crucial when using a mudguard & or fat tires.
The chain will rub OK on a bare tire, but it snags on the edge of the mudguard.
The tubes make this a non-issue although they do lay against the mudguard when using the inner-most cassette rings.
Under this condition some chain-noise is transmitted to the mudguard.
Despite the stronger frame and more efficient drive-train the bike is not order-of-magnitude faster like I hoped.
It is noticeably easier to push but we don't seem to go much faster yet, maybe we'll get fitter with the resumption of our regular commuting.
The stiffer frame makes the bike noticeably steadier going fast downhill.
I think I did a better job with the steering geometry on this bike; it's lighter to steer, maybe the offset in the forks contributes here.
I didn't calculate rake and trail, there doesn't really seem to be hard & fast rules as far as I can see.
The SRAM dual drive hubs are great, 27 gears each & all under our right hands.
They are great for the 20" wheels, I'd have to use big (expensive) chain-rings if I used a regular front derailleur set-up.
The just-as-expensive Dual Drives look neater and are nicer to use and maintain.
The other big improvement is the BB7 disc brakes, they are amazing especially compared to the V-brakes we had on the previous tandem.
I went for the 203mm discs in case we decide to tour with this bike.
cat0020 is offline
WhatsMyColnago
Classic & Vintage
7
03-08-18 01:56 PM
cplager
Recumbent
5
04-18-17 06:53 AM
cplager
Tandem Cycling
1
02-07-17 06:14 PM
GLA
Folding Bikes
109
03-20-11 03:01 AM
kingfish254
Tandem Cycling
1
04-14-10 05:26 PM
