Michelin Carbon
Michelin Carbon
It came time to replace the rear tire on my Univega. I did a little research and went with the Michelin Carbon. Seemed to be just what I was looking for. Fair weight, good rolling resistance, excellent puncture resistance and long wear.
I had the tire for less than one month. Yesterday the weather was so nice we decided to do a Metric Century. The tire had other ideas. At mile 52, the tire blew out. I never had that happen before. Before you guys ask, the pressure was 115. I check my tires before every ride.
The LBS recommended I switch to Conti Gatorbacks.
Opinions?
Opinions?
Hoosier Pedaler
Using heavier, more puncture resistant tires, is a way of reducing the number of flats you encounter but it isn't a way to react to a single flat. Flats happen and they happen more to people who ride on roads with debris that causes punctures. I never get flats but I ride on country roads that have nothing on them but pavement.
Bikes: 2014 Trek Domane 5.2, 1985 Pinarello Treviso, 1990 Gardin Shred, 2006 Bianchi San Jose
Quoted: 62 Post(s)
Liked 28 Times
I had a tire blow off the rim after hitting a huge chunk of asphalt. The tire seemed okay but on a later ride it would not stay on the rim so I replaced it with a Michelin Carbon.
200 miles later I've had no problems. 120 psi everyday.
Earlier I had problems with my wheels; pinch flats, blown tubes. Turned out to be the crappy rim tape installed at the factory.
You didn't say so I've gotta ask; did you hit anything to make it blow? How old was the tube? It blew off the rim, blew out a sidewall, etc?
I installed a new tube with the tire. I blew out a sidewall.
The LBS said if I installed the tube wrong and that was the cause. He said if was crimped,
that would blow out the sidewall. With all the good things I hear about the tire I was surprised. I just have never had that happen before. I guess it could have been me.
I have been riding a Michelin Carbon on my rear rim for 1-1.5K now, with no problems. I don't like it particularly, however. I know this is anecdotal and not scientific, but: I initially had it on my front rim but felt that it seemed to make the steering heavy and clunky. I put an Avocet back on the front and the Mich in the rear, where I don't especially notice its apparent characteristics.
Bikes: '04 Trek 1200
I rode them for about 1200 miles. My friend has put an additional 1200 miles on the same tires. They are still in great condition and have had 0 flats to date. I would definitely buy them again as a training tire.
Faith-Vigilance-Service
Bikes: Trinity, Paradisus, Centurion, Mongoose, Trek
I have Michelan Pro race tire on my racing bike, I have only had one flat due to a very large sharp object which sliced the tire wide open requiring replacement.
I also put Conti Gator Skins on my commuter. In the last 3 months, I have had three flats on my commute. The tires are tougher, but it all has to do with the roads I ride and the debris I encounter.
Gator skins are great if your know the route you ride is not very well maintained.
Considsering the amount of glass and sharp metal on my commute, I'll stick with the gatorskins. I rode my commute a few times with a set of Vittorias, and it was disasterous.
President, OCP
--"Will you have some tea... at the theatre with me?"--
President, OCP
Originally Posted by samp02
I ride the hell out of a pair of carbons. No problems here...
Quoted: 2952 Post(s)
Liked 3,106 Times
I've had very good luck with the Carbons. They're a bit heavier and stiffer than the Pro Races but much, much tougher. Bomb-proof if you add liners.
Bikes: Giant TCR CF, Raleigh Fixie, Bridgestone Radac, Specialized Rockhopper
Another happy Carbon user here.
Hey, FWIW I was getting more than my fair share of flats early in the season, and after a few posters here boasted that they never get flats, I have tried to be a little more careful, watching for debris and such.
Haven't had a flat since - obviously, no guarantee, but one flat doesn't mean the tires are bad and you should look for another brand.
Bikes: 1999 Seven Sola, 2004 Bianchi Axis, 2005 Trek Madone 5.2 SL, 2006 Merlin Works CR 3/2.5, 2009 Kona Ute, Spot Acme, 2017 Raleigh Roker Comp, 2016 Specialized Camber Expert 29
Same here, love my carbons. 700x25s btw, but I'm 240lbs so the x23s seem to be asking for trouble...
OK, I get it. What you guys are telling me is it was me. I am 51. Guess how many tubes I have installed? Guess I blew this one! (literally)
Caffeinated.
Bikes: Waterford 1900, Quintana Roo Borrego, Trek 8700zx, Bianchi Pista Concept
Originally Posted by Univega
...Guess how many tubes I have installed?...
83.
What do I win?
Sorry Camel, even I don't know.
I just wanted to follow up on this. I had to buy another tire. I stuck with the Michelin Carbons. I could not find anyone who would say a bad thing about them.
Plus when I wrote Michelin to let them know I was unhappy that a tire blew after only a few weeks of riding. They said to return the tire and "We will replace the tire if it exhibits a workmanship or material problem or as a courtesy if inspection confirms low usage.". I returned it today.
You have to admire and support a company that stands behind its product.
Thanks to all who replied
