Thread for Specialized Sirrus
#1251
if you are in the San Francisco area, there are several shops that appear to have the Sirrus 4.0 in medium available:
Tam Bikes in Mill Valley 415-389-1900
Cyclepath in Hayward 510-314-8656
https://www.specialized.com/us/en/si...ext=90920-5003
#1252
Quoted: 9653 Post(s)
Liked 6,365 Times
At least it's a pretty drive to Mill Valley!
#1254
I like it alot. I have just under 500 miles on it from my early June purchase. Very pleased!
#1256
Liked 6,365 Times
#1257
I don't believe I would want to bike up to the top of Mt. Scott myself, but I could handle the descent :-) Thanks for your reply. I am starting to see bikes trickle in the shops in OKC now.
#1258
Liked 6,365 Times
#1259
Liked 6,365 Times
I like them as well. An allen wrench fits into the bar ends so you have your "tool" all the time.
#1261
TigerG I have the same bike as you and wanting to put a rear rack on. Thanks for the advise just checking before I go ahead that it all still works and would you do anything different? Also do you know how tight you attached to the seat post on Nm and can you just clarify where you the washers? Appreciate it thanks.
#1262
Bikes: 2019 Specialized Sirrus Elite Carbon
Quoted: 20 Post(s)
Liked 11 Times
Still lovin my 2019 Sirrus carbon elite. It is by far the best bike for long treks for me. I will always own a Specialized Sirrus. Its the only bike I have owned that I did not have to swap out the seat. Very comfortable ride on long treks. I am a huge fan of the bar ends.
#1263
Picked this up Saturday night! Went out for a quick spin and after a couple times around the block I felt some clicking through the pedals with noise coming from the bottom bracket. I didn't want to make matters worse so I stopped riding and took the bike back to the LBS yesterday. Long story short, I ended up returning the bike. I was bummed because this silver flake in person is an awesome color, the bike is so light 22.3 lbs and those R9 shifters with ball bearing gave great feedback. Oh well, wasn't meant to be...
#1264
Quoted: 1581 Post(s)
Liked 1,189 Times
#1265
#1266
I made a purchase before with an immediate issue and turned out to be a can of worms. So I made myself a promise, if there was something wrong immediately exchange or return it. In this case, couldn't exchange so I returned it.
#1267
I'm enjoying the bike now and the BB seems to be holding tight after almost 400 miles. The only complaint at this point is that the shifting is noisy and clunky at times and I don't care for the front shifter micro adjustment feature where a small click supposedly moves the front derailleur a tiny bit to stop the chain noise. It doesn't always work as advertised - causing accidental shifting at times.
#1268
Liked 6,365 Times
#1269
Liked 6,365 Times
I had the same issue with the Sirrus 3.0 I purchased recently. I brought it back and they tightened the BB so it sounds like a common problem. The bike mechanic told me that they've "been seeing this lately" so I guess that Specialized isn't doing very good quality control. Since they'd "been seeing this lately" I would hope that the shop would know to check for the problem and correct it before sending us home with them - only having to return 2 days later.
#1270
Liked 6,365 Times
Just joined the chain waxing group. What’s next, my legs?
#1271
Liked 1,189 Times
Bicycles (human-powered ones) are essentially very simple machines. Bikes from the large-scale manufacturers such as Specialized sometimes just arrive on the shop floor with improperly-installed/adjusted components, or a defective component or two. A factory b/b issue is a common one; others are things like inadequately-greased headsets, loose crank bolts -- stuff like that. That's why all the good manufacturers offer at least a one-year warranty on such things, and why good shops will ensure that they are corrected, if they miss them during final assembly/checking on the shop floor.
#1273
Good to hear. I'm guessing that mine needs an adjustment. I had to bring mine in the day after purchase because the front shifter stopped working and just flopped back and forth. They said that the cable came loose in the shifter assembly and they reconnected it. 2 days later I found the loose BB issue when trying to find the source of an annoying intermittent clicking noise and had to bring it back again (it's an hour each way so a pain). I'll ask them to check the shifting issues when I bring it in for the free checkup/tuning they give with new bikes and hopefully they get it running smoothly and quietly - like my Crosstrail Sport always was...
#1274
Fair enough, and understandable, but still too bad.
#1275
