How do i remove a confort grip?
How do I remove this comfort FUJI grip?
https://picasaweb.google.com/lh/phot...eat=directlink
I tried the usual, remove the end cap, pull the hell out of it while twisting.
It didn't move at all.
Bianchi Goddess
Quoted: 2930 Post(s)
Liked 2,926 Times
if the end is open, work a small screwdriver under it and spray some hairspray or rubbing alcohol under it.
Sugar "Kane" Kowalczyk
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
Compressed air is what we used in the shop.
Bikes: Specialized Sirrus, Univega Activa ST Hybrid, 70's Schwinn Traveler, Giant Innova, Nishiki Mixte
Compressed air +2
The air or screwdriver and a spray bottle with soapy water to squirt in next to the screw driver.
Bikes: 1995 GT Arrette
Lover of Old Chrome Moly
Quoted: 143 Post(s)
Liked 23 Times
I'm not familiar with this grip, but some comfort grips have a small set hex screw (Ergon grips among others have this feature) that must be loosened. Then any standard grip removal procedure will work. I discourage the use of WD40 or other non-water soluable lubes if you are planning to reuse the grips as some grip materials can absorb enough lube to make it difficult to remount them later. I use my cleaner/degreaser which is half Simple Green, half water and just a bit of Dawn dish soap.
The air compressor trick works a treat. I tried it on a 1950s vintage Schwinn because I didn't want to risk damaging the grips. It took a couple of short blasts to get the first one loose, but the second grip shot off instantly.
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,218 Times
If you don't have an air compressor, the screwdriver works but the best way is to get a basting syringe and inject water through the grip. Slides right off. Use hairspray to put them back on.
Stuart Black
Stuart Black
You guys are a resourceful bunch!
about the screwdriver... that would scratch the handlebars wouldn't it?
i will try to inject some soapy water under them...
...what's "hairspray" exactly? Wife has some 20 kinds around...
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12776 Post(s)
Liked 7,693 Times
Screwdrivers can scratch bars, but it's in an area that never sees the light of day. If you want to keep your bars unscathed you can use thicker bamboo skewers. The thin ones don't open up enough room to spray into and can break easier if you pry up to make room.
For grip removal, my favorite liquid in a spray bottle found in most homes is window cleaner. I keep a spray bottle of Isopropyl personally, though. It's a bit better for re-installation lube as it dries just a bit faster than window cleaner. A good clean grip put on a good clean bar with Isopropyl or Window cleaner usually stays in place quite well after a few hours dry time.
Soap and WD-40 both require thorough cleaning afterwards or your grips will never stay in place after re-install. I'd advise against using either.
Hairspray is usually best reserved for re-installing grips that twist on the bar too much. For keeping grips in place, Aqua Net Extra Super Hold is best. Some desperate MTBers have been known to resort to spray paint on installation to keep grips in place. Remember that using hairspray will make subsequent grip removal a bit more difficult. Grips slid on with spraypaint will usually have to be cut off with a razor blade.
Hairspray is usually best for re-installing grips that twist on the bar too much. For keeping grips in place, Aqua Net Extra Super Hold is best. Some desperate MTBers have been known to resort to spray paint on installation to keep grips in place.
I am with you on the hairspray though. I prefer the water based spritzer type over the aerosol though.
Quoted: 143 Post(s)
Liked 23 Times
Aquanet hairspray in the pump. Great stuff for grip installation. If you use enough on a Bouffant hairdo, you no longer need a helmet.
Bikes: Bianchi, Miyata, Dahon, Rossin
Liked 5 Times
I just spray in some fabreze.
smells way better and does dry out, unlike WD40.
Food for thought: if you aren't dead by 2050, you and your entire family will be within a few years from starvation. Now that is a cruel gift to leave for your offspring. ;)
https://sanfrancisco.ibtimes.com/arti...ger-photos.htm
Map maker
Bikes: Ventana El Ciclon, Walt Works 29er, Specialized Enduro (fixed up for my son).
WD-40 is the stuff
it actually works great for grip installation as well - pry up the ends and stick the little red spray tube as far as it will go. spray and twist.
for installation: spay just a tiny bit* of WD-40 slide the grip on and leave it for a few hours the WD-40 will evaporate out and the kerosene in the spray makes the rubber grip even better.
I've used it for years and it always works.
(*If you use too much you might have to remove the grip and wipe it out and try again.)
Used a bamboo skewers to remove (had to lube one of them in wd-40)
to insert one went in without anything, just reused the skewers trick in reverse... one needed some lubrication, used 90proof rubbing alchool. a lot of it. then just worked the skewers to help it evaporate on all sides.
thanks for all the tips everyone!
I like the screwdriver method and silicone spray. The silicone spray does dry out although it will leave some film. Wash with soap and water before reinstalling and you're good.
wernst
Bicycle Mechanics
70
11-12-19 10:25 PM
stickmangumby
Bicycle Mechanics
6
02-18-10 03:52 PM
