Has anyone found a lever-type shifter that works with Nexus 8?
Old Boy
Quoted: 984 Post(s)
Liked 1,715 Times
I've been told that there are a lot of Internal Geared Hub riders on this forum, and that I may find the answer to my dilemma over here.
Having just finished my Eurasian-Nexus Path Racer project, first rides have revealed that the indexed, 8-speed, Sunrace shift lever I am using does not have the correct pull for the Nexus 8 hub. After researching this a bit, it looks like this has been an ongoing complaint from people who try to convert derailleur-equipped bikes to IGH.
Here is the bike in question:
[IMG][/IMG]
... and as you can see, it wouldn't wear a Twist-Shift or Rapid Fire gracefully at all. I've mounted my lever on the stem, and it looks right on there. I have seen where Rivendell have utilized an indexed lever with 13 detents; it goes 1-click for each of the first 3 gears, and then 2-clicks for each gear higher than that. It's a possibility, certainly, but I can't believe nobody has come up with a better solution.
I found something called a "Microshift CNC thumb shifter for Alfine/Nexus Inter-8" on the Bikeman website, but there isn't any photo, so I don't know what I would be buying. Has anyone here used this device? Does anyone have a better idea?
[IMG][/IMG]
Senior member
Quoted: 943 Post(s)
Liked 658 Times
The only one I have direct experience with is the Jtek bar end shifter.
Jtek Bar end Shifter for Internal Hubs | Jtek Engineering
I am aware of the Microshift option, although have not seen one. probably has more mounting options than the Jtek.
Old Boy
Quoted: 984 Post(s)
Liked 1,715 Times
Okay, is this what you are talking about?
The cable routing would be problematic, for a start. But then I looked further into the site, and found this:
That would allow me to mount it right where I have the current lever. I like that!
I'm not thrilled that these are black anodized instead of silver, but there are ways...
Their dealer list is pretty sparse, here in the `states, though. Where is the best place to get them from?
Oh, and how much do these engineering wonders cost?
Senior member
Quoted: 943 Post(s)
Liked 658 Times
Thanks, Dan!
Freewheel Medic
Quoted: 1452 Post(s)
Liked 2,195 Times
Beautiful bike. First class all around!
microShift makes some nice products and I've seen their thumb shifters for 9-11 speed set ups so I was hopeful for you that this style might work. But alas when I narrowed the search on ebay to "microShift thumb Nexus" the result was less than appealing. Too modern MTB style and not vintage MTB as I had hoped.
This is what I found, albeit in the 7 speed version and we can assume the 8 speed is the same.
Was hoping they looked more like this.
Have you tried shifting in friction mode?
Bob
Bob
Quoted: 18376 Post(s)
Liked 4,511 Times
Looking at the Sheldon Brown Page,
Sheldon Brown's Internal Gear Hub Cable Pull Crib Sheet
The cable pull or each gear is different.
The Sturmey Archer 8 is somewhat close to the Shimano 8, so the shifter would be worth a try.
Sturmey Archer | SLS80
Of course, you could also go with a Sturmey Archer wheel.
DQ- Nice looking rig you've got there!
If I may ask, what type/brand of stem shifter mount are you using there? From where did you buy it?
I am patiently awaiting the (eventual) restocking of the IRD stem shifter mount for my VO Polyvalent build. It will be used with a 10-speed Ultegra system. IRD says by the end of this moth, or so, but it would be nice to have a backup source.
And it looks like you're also a MC rider. All good things only need 2 wheels. Yamaha and Moto Guzzi for me. But I digress...
Thanks from a fellow Minnesotan.
Steve.
Steve.
Senior member
Quoted: 943 Post(s)
Liked 658 Times
Bikes: 199? Landshark Roadshark, 198? Mondonico Diamond, 1987 Panasonic DX-5000, 1987 Bianchi Limited, Univega... Chrome..., 1989 Schwinn Woodlands, Motobecane USA Record, Raleigh Tokul 2
Quoted: 1131 Post(s)
Old Boy
Quoted: 984 Post(s)
Liked 1,715 Times
...And the Winner is: Microshift SL-N08
Steve.
Steve.
First, thanks to everyone who has answered my request for help. My own searches came up with similar results, but I have exactly zero experience with any of them. I am going to visit Mr. Burkhart's site later today, after work - that looks interesting.
Steve, to answer your question, I am using the "Sunrace M96 Thumb Shifter Rear Indexed-8 spd" which says "SA" on the mounting ring. This is a standard MTB handlebar mount that just happens to fit the O.D. of the Nitto Stem I'm using. Since the Microshift SL-N08 is made specifically for the Nexus Inter-8, and has the same kind of mounting bracket, I ordered that from Bikeman, once I saw the image on the Microshift site: microSHIFT -The best control system
Of course, this was before Corrado33 posted that they don't make it. I guess I'll find out soon...
P.S. Oh, and Steve? You might say I was into motorbikes, just a bit. My columns "Diary of a Cafe Racer" and later "Backroads Diary" ran in Minnesota Motorcycle Monthly from 1997 to 2005, after which I started my blogs "The Baron in Winter" and "Rush Hour Rambling". This all started with the experience of roadracing my Ducati 900SS, but you're right, I digress too...
DQ, MN MC Monthly? Small world! I'll have to go back and search your columns. I've had submissions published by them a few times. My greatest work, telling the story of re-opening the I-35W bridge in Mpls in the Oct 2008 issue, "Motorcycles and Civil Disobedience". Just did a book review for them this past fall. Anyway, good luck with your project.
Steve.
Steve.
feros ferio
Quoted: 1393 Post(s)
Liked 1,325 Times
In the "products wanted" column: a modern version of the old Sturmey-Archer top tube mounted 3-speed "quadrant" shift, in updated versions for the various 3-to-14-speed IGHs out there.
Old Boy
Quoted: 984 Post(s)
Liked 1,715 Times
Bikes: 1960 Raleigh Sports, 1973 Schwinn Deluxe Twinn, 2007 Bianchi Volpe, 1973 Raleigh Sports
Hello all,
After doing research of my own on this very question, I stumbled across this thread and I'm now curious about whether DQRider found the MicroShift SL-N08 to be a suitable option for his Nexus 8. Any updates to offer? I've just put a nexus 8 on a vintage tandem and can't find a shifter option that is both aesthetically pleasing and will actually fit comfortably on the bars without interfering with the brake. From the pics on the manufacturer page, this looks like what I've been looking for.
Old Boy
Quoted: 984 Post(s)
Liked 1,715 Times
Hello all,
Yes, the Microshift SL-N08 works perfectly on my... I'm not going to call it a "path racer" anymore. It's too fancy for that now. It's more of a French Cafe Racer of the bicycle persuasion.
The only caveat is that I had to use some inline barrel adjusters (from Jagwire) up near the mounting point, so I can keep the shifter accurately dialed-in. You can see those in the downtube section of the cable housing in the photo, below:
The bike rides beautifully now, and I love having all 8 gears answering the helm.
EDIT: Posted at the same time as you.
Glad it worked! I'd love to use it, but my nexus is on my winter bike. I'd hate to have to remove my hand from my pogie every time I wanted to shift. Although my bike does have braze on downtube shifter mounts, so that shifter would work... easily...
If you don't mind me asking, I see that you ran just the cable under the BB instead of a full housing. What did you do for a housing stop on the drive side chainstay? (Since the nexus has a housing stop on it's body, you need a housing to feed into it, so you'd have to change the bare cable after the BB to a cable that's housed, that'll feed to the nexus... right?) Do you have any close up pictures of the drive side chainstay?
Thank you for the update - your bike looks really great with that setup. Also, thanks for the tip about the barrel adjuster. Are you finding yourself needing to adjust it often to keep the shifter in line? I'm fairly new to bike maintenance/upgrades in general and have not used inline adjusters before so I'm trying to decide if the extra faff is worth it (I suspect yes).
Old Boy
Quoted: 984 Post(s)
Liked 1,715 Times
Awesome, thanks. I also wish for a chrome version.. oh well. I assumed the shifter itself had a barrel adjuster which is why I was initially confused as to the need for the inline adjusters. Makes sense.
Honestly, it's been tricky finding any sort of info, images, reviews, etc for the SL-N08. The only US supplier I can find is Bikeman, and when I called them they informed me it's on backorder until April 1 (or somewhere thereabouts) but nevertheless I'm probably going to just order one when it's available and see how I like it! I suppose another option would be bar end shifters + Paul Thumbies but it looks like the more expensive option.
Just a brief update in case anyone doing a similar conversion in the future finds my info useful... I bought the Microshift SL-N08 and installed it on a Schwinn Twinn tandem, and it works well so far with the Nexus 8 hub. This setup has allowed us to retain the original schwinn grips and brake levers, which was not really possible with the RevoShift or Alfine shifter since both were too large and cumbersome, and there was not enough room on the bars. I wish the SL-N08 came in chrome but it is nevertheless pleasingly unobtrusive. Took it for a couple test rides and all seems to work well; we'll see how it holds up over time!
Bikes: Working on replacing my stolen Soma Buena Vista Mixte
Quoted: 417 Post(s)
Liked 95 Times
Hi all,
I have an alfine 8 on my bike and the trigger shifter. My shifter is no longer displaying gears and I found this thread.
Do you think I (read my LBS) could do something similar for my bike? (Soma Buena vista mixte + upright bars)
Old Boy
Quoted: 984 Post(s)
Liked 1,715 Times
Does anyone know if the Nexus and Alfine cable pulls are the same?
Quoted: 417 Post(s)
Liked 95 Times
I am pretty sure I have seen somewhere that that nexus 8/afline 8 can use the same shifter. So it seems like a reasonable bet, so I should try it! It is way cheaper than the jtek bar end anyway! I'll post here if I get it done!
Team Sohoku
Bikes: BMC, Cannondale, '87 Nishiki Modulus, 3Rensho Keirin
Quoted: 13 Post(s)
Beautiful bike. I realize this isn't exactly what you're looking for based upon your bike's aesthetic, but Gevenalle has a brake lver/shifter combo for Shimano IGH.
UX ? Compatible with Shimano Internally Geared Hubs | Gevenalle
