ISO and for trade thread part 5
#2526
Quoted: 206 Post(s)
Liked 102 Times
Thanks, people! I got two responses for the above cable guide. Should be good.
Some days, it's not even worth gnawing through the restraints.
#2527
After waiting more than a month for a new crown race and bottom cup for my mercier 300 to fix my either too lose or binding headset woes it appears the upper cups are the problem.
ISO: french threaded headset, excellent mechanical condition. Stack height of 35mm, plus or minus a mm. Currently there is a stronglight p3 on there.
#2529
I'm looking for two purple anodized water bottle cages. Can't believe these aren't commonly available any more! Does anyone have a couple kicking around?
#2530
Quoted: 1199 Post(s)
Liked 1,354 Times
#2531
verktyg
Quoted: 1036 Post(s)
Liked 1,238 Times
Peugeot Blue & Yellow Frame On OfferUp
verktyg I know its not your size but just for kicks thought I'd post it. Check out this Peugeot PLX 10 1955-58 Reynolds for $1200 on OfferUp https://offerup.co/lAgJ4xCqM6
It's awfully "spendy". I'm looking for a complete bike because piecing together all the vintage parts can more than double the cost.
I've seen whole bikes like this for only a little more $$$$. It just a Peugeot!
Who ever said that C&Vers aren't cheap!
verktyg
Chas. ;-)
Chas. ;-)
#2533
Looking for a 24.0 seatpost for a Peugeot HLE frame. I'm trying to get a budget build together, so condition is not an issue so long as the post is usable.
#2534
Looking for a French threaded fork w/ 140mm steerer to fit Motobecane Mirage. Not sure what year it was manufactured.
#2535
Bikes: Raleigh Classic 15, 84; Miyata 912, 85; Miyata Ridge Runner SE, 85; Miyata 610, 86; Miyata 100M, 86; Miyata Valley Runner, 88; Miyata Triple Cross, 89; GT Karakoram, 90; Miyata Elevation 300, 91; Marinoni Touring, 95; Long Haul Trucker, 2013
Quoted: 159 Post(s)
Liked 133 Times
#2536
Bikes: yes
Quoted: 512 Post(s)
Liked 409 Times
I've got two of those Lezyne cages in purple. I got them for a purple Trek 760, but they didn't quite match, so I went with silver.
Anyway, they're off the package cardboard, but unused. PM me if interested.
#2537
Quoted: 3810 Post(s)
Liked 6,690 Times
Likes For nlerner:
#2538
Liked 1,354 Times
@eeuuugh I'd jump on those cages from vintage cyclist. It'll be a few hours before I can check for you.
Ride safe
Update: No dice on the cages from Pats605. They have limited stock these days.
Ride safe
Likes For malcala622:
#2539
Bikes: Indeed!
Quoted: 1507 Post(s)
Liked 3,473 Times
5 Complete Links of Regina Chain Wanted. Found! Thanks to Mad Honk.
Yep, just 5 links to extend a chain that is too short for my Olmo project.
The chain I have is the black "Super Corsa," marked "Regina SC," but I would be happy with any older Non-oro Regina chain.
I have a multitude of small trade items of similar vintage to the chain I seek; Campy crank bolts, dropout adjuster screws, cable clips, chainring bolts, Regina cogs, etc.
Brent
Brent
#2540
www.theheadbadge.com
Quoted: 2422 Post(s)
Liked 4,392 Times
Putting these ISOs out for a friend and also so I can finish up some pending projects:
Got something? Send me a PM.
-Kurt
- For the Velo Yellow kids ex-track bikes that I'm building for work:
- Three 26.8mm seatposts. Must NOT be fluted. Can be on the short side. Nothing fancy - just something stuff that'll do the job.
- Three 110BCD chainrings - can be any combination of 38t, 39, or 40t.
- Three decent-enough rear axle mount kickstands. Must work, but length unimportant, as I'll be cutting them down.
- For a friend of mine who just found a nice 28h White Industries hub and is looking to lace something into it:
- Some sort of interesting, 1980's/90s era 700C clincher rim, 28h. Knowing him, I think something polished would be ideal - and I think something like a mid-V Campagnolo Lambda or Vento would be right up his alley.
-Kurt
#2541
WGB
Bikes: Panasonic PT-4500
Quoted: 1800 Post(s)
Liked 2,334 Times
74BCD
Seeking a 38/39/40 tooth chainwheel
(also seeking a 24/26 tooth chainwheel same BCD
Will pay for chainwheel(s) and the shipping as I live in Canada and prohibitive with shipping to trade
#2542
You're looking for a 74BCM 40 tooth chainwheel? Wow, I didn't know those existed. I can help with the smaller rings but assuming this is going on a triple crankset I would assume the bigger rings would be 110 BCD or something.
#2543
Quoted: 1106 Post(s)
Liked 1,327 Times
What I'd REALLY LIKE (is everyone listening?) is a left side 170mm Triomphe crank.
Send me your postal address. You can have the ring. I get karma.
Get me a crank and you get karma too.
#2544
WGB
Liked 2,334 Times
oneclick
Pm sent for the 24 tooth.,
Thank you!!
Iowegian
I have an SR Apex small bolt circle crankset that is 50/44/30 rings and with a 74 BCD. I can put the 44 on the outside and the 30 on the inside with the 24 on the inner which will be 44/30/24. It may not look like much but since I usually ride my doubles on the small tooth (usually 39 tooth) except on downhills, I can't see having a large chainwheel, especially with a heavy load. I'd prefer a 38/39/40 tooth large ring instead of the 44 tooth but a 44 is still slightly better than a 48, especially for shifting. Still, I'll keep looking for a 38/39/40 tooth.
Thank you!!
Iowegian
#2545
aka: Dr. Cannondale
Quoted: 2155 Post(s)
Liked 3,403 Times
Wow, SR Apex also came in an all-74 BCD configuration? Who knew?
I have the 86 BCD triple version, and it’s great. Have seen the larger BCD version, but never one that was all 74.
Could you post a few pics?
#2546
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
#2547
WGB
Liked 2,334 Times
#2548
Liked 1,327 Times
Sheldon say only 74, no 76. You're good.
Wait a sec, that's not BCD you're measuring.
You're measuring the diagonal of a pentagon. If it *is* 74mm, you've got a bolt circle diameter of 2x 38.904, or just under 78mm. That makes no sense either.
Measure one-hole-to-the-next, and use his chart:
https://www.sheldonbrown.com/cribsheet-bcd.html
It may be that the ring I sent you will not fit; oh well.
#2549
Liked 4,392 Times
#2550
aka: Dr. Cannondale
Liked 3,403 Times
I’ma gonna guessa thatsa 86 bcd cranka setta.
