Not sure how to remove this cassette
The bike is around a '93 Specialized 7 speed. I'm trying to remove this cassette but not sure how. The removal tool does not fully drop into the cassette due to a lip or something just beneath the locking ring. With only about a 2mm drop into the locking ring the tool is very loose. Do I need a different tool or is there another way to remove this cassette?
Quoted: 384 Post(s)
Liked 6 Times
Bikes: 2016 Fuji Tread, 1983 Trek 520
Quoted: 669 Post(s)
Liked 725 Times
Yes, the right tool has a protruding rod that will insert into the quick release axle hole.
SE Wis
Quoted: 2731 Post(s)
Liked 3,361 Times
Yeah they look the same but the diameters are slightly different. I wish they were all made the same...
SE Wis
Liked 3,361 Times
https://www.bikeforums.net/classic-v...-removers.html
FREEWHEEL REMOVERS
Quoted: 6100 Post(s)
Liked 4,732 Times
Unless you are going to do it often, a bike shop might loosen it for you cheaper than getting a new tool or even free. Buy a pair of socks or something there to help them out.
You don't need a tool to put a freewheel on. The pedaling will tighten it plenty.
Bikes: '84 Peugeot PH10LE
Quoted: 397 Post(s)
Liked 55 Times
Jon
working on my sandal tan
Quoted: 3868 Post(s)
Liked 2,560 Times
OP has a cassette. It won't tighten itself on with riding.
Master Sarcaster
Bikes: 2018 Allez Sprint, 2016 Trek Crockett Canti
Quoted: 190 Post(s)
Liked 4,732 Times
Likewise go back and let them tighten the new cassette...... maybe you need more socks or new cup holder.
Liked 2,560 Times
Okay.....
If your local bike store is not cool (or you don't need socks) a chain whip and cassette removal tool is about $13 shipped on ebay. Good tools to have in your collection as cassettes are still used on all bikes today.
Here's an alternative to the chain whip that I find easier to use:
One more quick question... can I use any of the new 7-speed cassettes? Are they all interchangeable on my hub? Its a tri-color Shimano 600 with 127mm spacing. Thanks again...
Insane Bicycle Mechanic
Quoted: 788 Post(s)
Liked 688 Times
(There are several gotchas if you want to make other modifications, such as 8 or 9-speed. 7-speed to 7-speed is no problem.)
Jeff Wills
Jeff Wills
Made in Taiwan
Bikes: Camerotti ti roadbike, Old Sears Free Spirit Tange Hi-Ten Single Speed built from a 12 speed, 1997 Cannondale CAD3 r500 with Shimano 6400 groupset
Quoted: 35 Post(s)
Liked 11 Times
RockiesDad,
Not sure, if you have managed to change out your cassette yet already. But, I encountered the exact issue the other day in the shop. In the end, to help the customer, I removed the axle from the non-drive side so that I could seat the removal tool deep enough. Your drive side cone/lock nut basically has a washer in place that is too large of a diameter to allow your cassette removal tool to sit deep enough. Once you have the axle out, you can swap out that over sized washer with one that has a smaller outer diameter that won't prevent the tool sitting at the correct depth.
You can kind of just see the edges of the washer that I am talking about in your second picture. It is a ring behind the edges of the lock nut. If you do replace that washer, just make sure the outer diameter is small enough for the edges of the removal tool to pass by freely and that the thickness of the replacement washer is the same.
You might have luck if you put in a quick release skewer to hold the cassette removal tool in place. My customer's lock ring had a lot of corrosion and was not budging at all with that trick. Had to use a liberal application of penetrating oil even after the removal of his axle and having the removal tool seated all the way.
All dogs want to be lap dogs doesn't matter the size
-Animal loving friend
Made in Taiwan
Quoted: 35 Post(s)
Liked 11 Times
In the shop, freewheel/cassette removal tools are one and the same. There are loads of different designs and types of interfaces. For example, what if a customer came into the shop with a lower end bike that has a freehub but solid axle, if I only had the removal tool that has the protrusion to fit into the hollow axle, it actually means I won't be able to help them, unless I take the axle out of the hub.
RockiesDad,
Looking more into different tools I think there might be two different diameters for these locking rings. One size is Park Tool FR-5.2 which is 23.4mm and FR-1.3 which is 22.6mm. Both sizes are for Shimano. Got figure...
https://www.parktool.com/product/cas...ng-tool-fr-5-2
https://www.parktool.com/product/fre...remover-fr-1-3
I'm liking my LBS more and more. There is an old-school shop around here that might have this particular size tool. I might just go there and see what he says. I'll ever get the new cassette from him if he as one...
Quoted: 384 Post(s)
Liked 6 Times
Hi Ghrumpy and andrewclaus,
There are two cassette lock ring "standards" of which I'm familiar. Shimano's and Campagnolo's. Shimano's cassette lock ring pattern is also used for some of their brake disc lock rings. Campagnolo's lock ring tool is also used to install and remover some of their square taper bottom brackets.
The lock ring tool with the hollow axle guide pin (Park FR-5.2G) has the same spline pattern as the one without (Park FR-5.2). I have both, and any decent shop should too. They only cost a few bucks. That being said, IME there are precious few solid axle hubs that use a freehub/cassette.
@RockiesDad , you need the Park FR-5.2, which as it says in the product description, is for cassette lock rings. It will not fit freewheels. As previously noted, you will also need a chain whip to hold the freehub from turning while you remove the lock ring.
The Park FR-1.3, as it says in the product description, is for freewheels. It will not fit cassette lock rings. You do not need that for this situation. Ignore the fact that they are both Shimano. Shimano have used three different multiple-freewheel removal interfaces over the years, and a different one for single-cog freewheels. None of them are compatible with their cassette lock ring interface.
Liked 2,560 Times
The axle has nothing to do with it @*Scuba. OP was trying to use the freewheel tool on a cassette lockring, and they're not compatible with each other. The FR-5 is the correct one for cassettes.
Quoted: 788 Post(s)
Liked 688 Times
Jeff Wills
Jeff Wills
Liked 2,560 Times
Hmm, I went down into the basement to double-check my statement. I can't get my FR-5 into the splines of an MF-Z012 or MZ-TZ20 freewheel, nor can I get the FR-1 into any of my HG50 or HG70 (7-speed in all cases) lockrings. Did Park used to make these tools a little looser fit in the past or something?
Quoted: 384 Post(s)
Liked 6 Times
True! But not compatible with Shimano's freewheels or cassette lock rings. Might look like it, but you might end up sorry you tried it. They're easy to distinguish: The Campagnolo tool has a hole big enough to go over a BB spindle. The Shimano does not.
