Studded winter tires a bear to mount - don't think I could fix a flat
Bikes: 2022 Salsa Beargrease Carbon Deore 11, 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 4389 Post(s)
Liked 3,016 Times
I've got a fantastic set of Nokian W106s that are just perfect for winter riding on my cx, except that they are an absolute bear to mount. They have super-thick sidewalls and even with a tire jack in my basement, putting them on at the beginning of winter is a major undertaking, and taking them off in the spring is not a picnic either.
Maybe there's somebody out there with superior finger strength, but it ain't me. Particularly in the cold wearing thick gloves (lobster claws) and reduced dexterity, I am certain I would not be able to change a flat on the road. The odds of a puncture seem very low, but a pinch flat doesn't seem out of the question - thankfully it's not happened yet.
I've decided that rather than carry a tube and pump, I'll instead carry a small cable lock. In the event of a flat, I'll lock up the bike, call an Uber, hope I don't freeze while I wait for it, and pick up the bike later.
Is anybody else vexed by this challenge?
Likes For MinnMan:
Bikes: Trek 730 (quad), 720 & 830, Bike Friday NWT, Brompton M36R & M6R, Dahon HAT060 & HT060, ...
Quoted: 840 Post(s)
Liked 336 Times
For one it is very hard to get a flat with a studded tire. Second, if you struggle this is because you are presumably not very effective working with tires. There is nothing to be ashamed - we all learn. This video
shows how to get a tire off without any tools. There may be other similar instruction materials around. I would start with regular tires for the sake of training. From time to time I do it with studded tires for practice. In everyday life I am usually lazy and use the levers for speed, but just a little. You may say that rims vary and I presumably have the easy ones. OK, I do it with 16" tires too. On a small wheel you have far less margin than on large. Take your time, be patient, hands alone are actually sufficient.
It helps to work your way around the tire pushing the beads in towards the center of the rim. That said I wouldn't bother trying to fix a flat out in the cold if I didn't have to. Fortunately winter flats have been quite rare for me, most of them were when my Marathon Winter tires reached the end of their life.
Worst studded tire I've had to deal with so far are Ice Spiker Pro TLR. Don't buy that tire in tubeless if you don't have to because they are a super tight fit. I can barely get it on the rim even though the sidewalls are far more flexible than most studded tires.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
The bike I ride in winter has single-wall rims. That helps a ton in mounting and dismounting my Suomi W160 Mount & Grounds by hand.
Quoted: 4227 Post(s)
Liked 2,488 Times
How to get tire off without tools
Quoted: 840 Post(s)
Liked 336 Times
I do not invoke the video as a proof or call for abandoning the levers. I advocate training with bare hands when under comfortable conditions, without pressure of time. Experience gained turns out to be invaluable when challenges mount. With the experience the number of easy rim-tire combinations dramatically widens and of the impossible shrinks. I just went out to count and we have 11 bicycles and gazillions of rims and tires and I there is not a single combination for any bike that I cannot do with bare hands. Is it normal for me to work with bare hands? No, but it is not a big deal either. Do the gloves matter? Not really, if you know what you are doing. Does being cold, frustrated, wet, tired, not being able to see well what is going on matter? Sure, but you take care of what you can take care ahead of time.
Likes For 2_i:
Quoted: 5224 Post(s)
Liked 3,581 Times
sounds like a plan if you're on the road, near civilization. just don't wander off into the woods ...
while I agree, the usual type of flats are less likely with beefy studded tires, I had 2 flats with studded tires one day. & I was alone out in the woods. it happens. but wasn't from road debris.
when mounting 1 set recently, I feel like getting old tires off is easier than getting them back on. my tire jack isn't big enough to use on my current 2 sets of studded tires 40mm & 2.25". I carry 2 toe straps cuz they help keep one side compressed down in the channel, w/o popping off (maddening) & allowing a bit more slack on the other side. learned that tip here & it really helps. I also carry 3 types of levers including a speedier lever which, when combined with traditional levers helps enough to keep carrying it
the toe strap thing works with road tires too, of course
Likes For rumrunn6:
Those sound like sweet winter tires!
In three years of winter riding, I've been caught with a flat only once (knock on wood). I called Uber, they picked up me and the bike and the next day I walked it over to the mechanic.
I detached the front tire and loaded the bike frame first, then the detached wheel second
Liked 3,016 Times
Liked 3,016 Times
Liked 3,016 Times
Bikes: Novara Safari, CAAD9, WABI Classic, WABI Thunder
Quoted: 366 Post(s)
Liked 457 Times
I've not gotten a flat on my Marathon Winters but haven't tripping thousands of miles on them either. I always use New tubes and mounting them hoping to keep Flats away. Fortunately they mount easily on the Weinmann rims I normally put them on.
I have a set of brand new 700x35c Marathon Winter Plus' in the for sale thread. $60 each shipped to the lower 47 (no California) if you buy 2.
Be watchful, stand firm in the faith, act like men, be strong. Let all that you do be done in love.
Quoted: 840 Post(s)
Liked 336 Times
I had flats tied to the seating of a tire. In one case I got already down to such a low pressure that the tire walked off the rim and the debris was freely getting inside. In another case I pinched the tube while seating the tire, the tube crept out and was rubbing against the brake, but I though it was ice accumulation. Interestingly, even though the tube outside was already rubbed through, the tire kept the air for as long as the tube was pressed to the rim. I just released the brake, pumped up the tire and made it somehow to my destination in time.
Liked 3,581 Times
Likes For HerrKaLeun:
Quoted: 366 Post(s)
Liked 457 Times
Yup, but add in the $20 shipping and waiting to clear customs will put you further out. These took 3 weeks, most of which was to clear customs.
Even if one only orders one tire, it already is cheaper. Most bicycles require 2 tires and they also sell other bicycle related items. So the flat shipping rate becomes less per item.
I'm not telling anyone how to order, I'm just putting the information out. sure, if you found out about winter today and you need to go to work tomorrow, paying twice the cost to an LBS who has them in stock may be worth it and be cheaper than an emergency room visit.
Quidam Bike Super Hero
Bikes: 1995 Trek 800 Sport, aka, "CamelTrek"
Quoted: 331 Post(s)
Liked 415 Times
Saw a bike hack vid where tie wraps, square tab to the ice, made supposedly adequate snow/ice tires out of your everyday fare....
Bikes: ...a few.
Quoted: 2012 Post(s)
Liked 409 Times
You just gave me an idea. I'll just take you along on all of my rides. I'm glad you are so skilled and able. I'm not a slouch when it comes to changing tires, but this particular combination is beyond my ability without a tire jack. Your wisdom, though inspiring, doesn't really change my predicament.
Like others have said, flats rare with studded tires. Though end of life tires, beware of them. The studs will puncture through to the tube and give you a flat. Both my Schwalbe winters went the same way, in the same week.
It really depends the tire size and the rim. My 45 mm W106s are a breeze to mount and unmount.
Likes For mcours2006:
Quoted: 1364 Post(s)
Liked 1,677 Times
I will echo what mcours2006 said. My Nokian w106 tires are relatively easy to mount and dismount my old mountain bike. But I have had other tires on my other bikes that seem like they are the wrong size they are so hard to get on and off. At the moment, all three bikes are shod with tires that go on easily, and that's two pairs for the old mountain bike summer and winter.
Liked 3,581 Times
yeah 26er tires are cake
Liked 2,488 Times
Using smaller tubes makes the job easier. For example if you have 2 inch tires , use tubes that are made for 1.5 inch tires... If you have 700x35 tires, use tubes which are made for 700x28 tires. This is especially important if you have narrow rims which are tight and don't have a lot of room. One of the reasons why I prefer wider rims is because it makes tire install/removal easier.
Quoted: 800 Post(s)
Liked 218 Times
To the best of my knowledge after at least 10 years of using studded tires think I have never changed them.
About three years ago I bought a beater road bike that accepts 30C Marathon Winter studded tires, the narrowest I know of since I ride mostly well tended roads, for hardpack snow and ice. They look malleable enough, should the occasion arise to change them on the road.
.”Who is getting a snow storm right now?"
...This Saturday prompted by the forecast I took my beater bike in to the shop to have the studded tires put on, kept on for the entire winter.
"How long does it take you to fix a flat?"
I carry two new tubes on a long ride, and I never seem to get around to patching flats though I do carry a patch kit for the worst circumstances.
As a year-round cycle commuter, time to fix is often critical, especially in the Winter
"Emergency Winter Cycling Kit?"
I too ride on urban / suburban routes with similar measures, but early, before 6 AM. I envision going to an indoor ATM machine to fix a flat, so I carry a bank card too... I don’t carry a lock and wouldn’t want to abandon my bike, with hassle of picking up later.
In my decades of commuting... I haven’t used Uber yet, so I don’t know how long wait (and inactive) times would be, especially in the early AM,so I would prefer to keep moving in the cold.
Since I have excellent Commuter Rail as an alternative commute, even on which to take my bike, I have frankly disdained busses, which are more accesible and frequent on my routes. Last week I did take a bus with my bike, and was pleased with the service, and carrying capacity, so now that looks like a primary emergency measure.
PS: I also use Kevlar tire liners year round, even on my fair weather carbon fiber road bike, to hopefully forestall flats.
