Convert BB30A to 24mm for Shimano
Canadian eh?
Bikes: 2020 Specialized Roubaix Expert
Quoted: 131 Post(s)
Liked 96 Times
Convert Cannondale BB30A to 24mm for Shimano
Hey All,
I'm riding a Cannondale Synapse Carbon. As you know, Cannondale uses the BB30A BB standard. My crankset is currently FSA SL-K Light.
I am looking to change over to a Shimano Ultegra crankset, utilizing the 24mm standard.
Is this BB my best option to ensure compatibility?
Appreciate the feedback!
Yeah, that WheelsMFG BB is very nice and would be what I'd typically use.
Canadian eh?
Quoted: 131 Post(s)
Liked 96 Times
I also want to make sure nothing else is required (other than installation). Basically get the BB, get the Shimano cranks, remove what's currently installed, install the new BB / Cranks, ride away.
Hambini makes https://www.hambini.com/product/bb30...ottom-bracket/, which may have slightly better bearings and thus run with slightly less friction, but were it me I'd just do the WheelsMFG.
Bikes: Canyon, Bowman & Colnago
Quoted: 132 Post(s)
Liked 39 Times
That should be fine. I installed that same BB on a friend's CAAD12 with Shimano Ultegra cranks. It's been about a year now and he's had no problems or complaints.
Canadian eh?
Quoted: 131 Post(s)
Liked 96 Times
So again, back to my original question. No other parts required with these hubs? Just buy the hub, cranks, and install away?
Quoted: 132 Post(s)
Liked 39 Times
Yes, it was a very simple install. However, the cups didn't take much effort to press into the frame. As a matter of fact, we didn't even need to use a press. We did make sure we screwed the cups together as tight as possible. My friend contacted Wheels Manufacturing asking if this was correct. Wheels Manufacturing assured him that in some cases a press wouldn't be necessary and as long as the cups were screwed together tight enough he shouldn't have any issues.
Like I said, it's been a year, maybe longer, and he's had no problems.
Good luck!
Good luck!
Likes For mrblue:
Likes For mrblue:
Likes For davidad:
Likes For davidad:
Canadian eh?
Quoted: 131 Post(s)
Liked 96 Times
Thanks everyone. Will likely go the WheelsMfg route. At nearly double the price, I don't think I can justify the extra cost with the Hambini.
