Wahoo system, first ride
Bought a kickr a month back. At first just loaded the Wahoo app on my phone and watched you tube. I'm now signed up for a free trial of the Wahoo System, btw they now give you 2 months, Anyway, did my first virtual ride today in the Pyrenees. Something was wrong as it was much too easy. Ride screen had my speed in the high teens, but phone app had me in the 30's, even while climbing. I was spinning out frquently. Is it because of when I loaded my profile I was honest about not exercising much for the last month and that I'm 68? Will it adjust on its own? Went back to try and adjust profile, but could only do weight/height/age. Wish I could claim that I'm that good of a cyclist, but I'm no better than avg, even for my age. Thanks in advance
Kamen Rider
Bikes: Fuji Transonic Elite, Marechal Soul Ultimate, Dahon Dash Altena
Quoted: 351 Post(s)
Liked 277 Times
You mean Wahoo SYSTM? If it feels too easy then your FTP is probably set too low. You may want to try running one of their fitness tests to gauge your actual power stats (Full Frontal is best but may be too brutal, Half Monty is easier to complete but less accurate and only generates two out of the four 4DP values).
Thanks for the reply,
Spent some time this afternoon trying to decipher info from Wahoo Systm. You're right about doing a fitness test, will do one tomorrow. Also read that the ride I did was just that, a ride and not a race. You're supposed to ride at the cadence on the screen. A higher cadence gives the results that I had, too easy. Lower cadence increases the resistance. I'm new to this having had a dumb trainer in years past so there's a learning curve. Sorry that I asked a question before doing research, but it doesn't seem a user friendly site for a newbie like me. Think I'll head over to youtube, I'll bet there's some info there. Thanks again.
Quoted: 4416 Post(s)
Liked 4,872 Times
Just make sure your trainer is actually connected to SYSTM in the ride settings (top right of the ride screen) and set speed to virtual. You don't need the Wahoo app running at all and in fact it would be better to close that down completely when using SYSTM.
Once you get it all set up properly it will not be too easy unless you are doing a low power recovery ride.
