Do you really like fixed gear bikes?
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,869 Times
I was just reading the "Should I Buy This Frame?" thread, which is just the latest of many threads I've seen here where there was a large contingent of people expressing the sentiment that really nice frames should be built up with gears. This puzzles me.
Allow me to opine....
It seems to me that there are several possible reasons that a person would want a fixed gear bike:
1. You want a bike for track racing
2. You want a cheap bike
3. You want a simple bike
4. You want a low maintenance bike
5. You want to do tricks
6. You think fixed gear bikes are fun to ride
7. You think it will make a good project to learn basic mechanical skills
8. You want to improve your pedaling form
9. You want to work on your spinning and/or mashing abilities
10. You've heard that a lot of people like them and want to try it to see what the appeal is
I'm sure there are other reasons, but those were the ones I could think of off the top of my head.
Now assuming you more or less accept this list, it seems to me that if a person wants a fixed gear bike because of some combination of 3, 4, 6, 8 and 9 (and arguably even 7), there is no reason that any frame with horizontal dropouts should be deemed as "too nice" to build up as a fixed gear bike.
In my mind, the only difference between a bike "designed to be a fixed gear bike" and a bike that was designed to be a road bike but has horizontal dropouts is geometry, and in many of the cases I listed above road geometry is desirable.
So what's the deal?
So what's the deal?
Live without dead time
Don't get me wrong here, I don't care what you do with your frame (although I always recommend against hacking off cable stops because after a few months when you're not a moron, you might regret having made your bike less functional) but it's worth keeping in mind that a geared road bike is always going to be faster, climb better, descend better, sprint better and generally be better given two identical frames, one set up fixed, one set up geared. So if you have a truly beautiful bike that is going to handle buttery smooth and feel all lively and such, you'll get more out of it by making it into a geared bike.
Now again, I don't care either way, but to me the logic makes sense if you really want to get into it. Fixed gears are less good from a purely performance perspective.
Bikes: Yes
Liked 3,869 Times
I definitely agree about not hacking things off, though.
Metal Maniac
Bikes: 1973 Fuji Finest fully restored, touring setup. Bianchi Classica with silver lilac powdercoat, fixed gear commuter bike.
So what's the deal?
So what's the deal?
i ride a aluminum road bike with vertical dropputs.
Bikes: Yes
Liked 3,869 Times
So, I guess what I'm saying is, maybe the Colnago (for instance) would be better in some abstract sense as a geared bike, but for $400, you're probably not going to find a better frame for fixed gear road riding. If you had posted an old mid-level Schwinn, there would have been a whole bunch of people (hopefully different people) telling you that it wasn't worth converting.
That is funny.
i hope he gets that thing and builds it up as a ssfg with campy components.
Elitest Murray Owner
Bikes: 1972 Columbia Tourist Expert III, Columbia Roadster
There are also really nice frames that were made with no consideration for the use of derailleurs, and it would be stupid to put derailleurs on them.
It's really not that puzzling.
There are really nice frames that were meant to be used with derailleurs. I think it is the use of those really nice frames that people are talking about.
i also find a lot of fixed gear frames overpriced. you can get 7000 series aluminum and Reynolds 853 road bike frames much cheaper than a fixed gear versions.
Bikes: team miyata, '73 p-14, MB-3, centurion lemans, Mystery TT, mongoose atb '85
The OP is confusing, what is he trying to understand? Is this a search for a combination of reasons that equates "really like"?
allow me to add one more "reason" to the list:
0. because you want a fixed gear bicycle
this makes my "reason" for riding a fixed gear bicycle more "complete":
8-6-7-5-3-0-9-ee-ah-yee
most horizontal frames also come with braze-ons, etc for brakes, cables, whathaveyou. i don't like these things, and track-type frames made for the 'fixie crowd' don't have these things and tend to try to be as simple as possible.
clearly, with the last couple of threads, like the fgss people being mean, and this one too, that clearly this crowd is a little different than the others. we like design, we like hands-on, and we like our bikes.
i, personally, don't care as much about road bike vs. track bike, but i do like a comfortable bike that has the things i need, and leaves out the things i don't want. that's why i ride fgss, in addition to some of your points.
FNG
Bikes: Raleigh Special * Nishiki MTN Winter Commuter * Trek Soho 3 * Specialized Langster Seattle
K2ProFlex baby!
Location: My response would have been something along the lines of: "Does your bike have computer controlled suspension? Then shut your piehole, this baby is from the future!"
Bikes: to many to list
Quoted: 16 Post(s)
Liked 56 Times
I can't stand riding fixed gear bikes, but thats just for me, it doesn't bother me that others do like them as thats what cycling is all about, finding the type of bike you like and riding it. =0)
You see, their morals, their code...it's a bad joke, dropped at the first sign of trouble. They're only as good as the world allows them to be. I'll show you. When the chips are down, these...These "civilized" people...they'll eat each other. See, I'm not a monster. I'm just ahead of the curve
Fresh Garbage
They are fun and low maintenance, great for a commuter bike. I would like to have a nice steel road frame, but I would not remove the cable guides
Bikes: Bianchi, Miyata, Dahon, Rossin
Liked 5 Times
low... maintenance...?
proper chain slack is high maintenance compared to dealing with stretched cables.
It's just highly unattractive to steal compared to a geared bike.
no expensive shifters or derailers to steal, all the expensive stuff (frame and wheels) are locked together.
even if you do break through the lock, if you're not used to riding FG, especially ones equipped with clipless pedals and no brakes, you're in for one hell of a ride.
Food for thought: if you aren't dead by 2050, you and your entire family will be within a few years from starvation. Now that is a cruel gift to leave for your offspring. ;)
https://sanfrancisco.ibtimes.com/arti...ger-photos.htm
Real Men Ride Ordinaries
Quoted: 17 Post(s)
Why the hell should I care if my bike climbs better, or goes faster or any of that? All I know is that (sometimes) a fixed gear is more fun to ride. In fact, I think it's more fun to ride precisely because it climbs poorly, goes slower and requires a lot more out of you.
I live somewhere pretty darn flat, with no real variety in terrain for miles and miles. Cycling gets dull. Whenever I go elsewhere, get to ride up a few hills, maybe tackle a real trail or two, my passion gets renewed. Then, returning to my pancake of a home, I turn to fixed gears to make things a little more interesting. Yeah, it's not really a climb, but it's more fun going up those freeway overpasses on a fixed gear than on a geared bike. The path by my house isn't much to a mountain bike, but ride it on a fixed cross bike, and it's a challenge, and it's exciting.
So what if I'm slow, can't climb and all the other faults. I'm having more fun. I don't know about you, but that's why I bike.
Comanche Racing
Bikes: Presto NJS build, Specialized Allez Pro w/ full Dura Ace and Ksyrium SLs, 1990something Specialized Sirrus
my FG bike isn't much slower than my geared bike. Even going up hills. The only time it is noticeably slower is when i go down hills.
Also, what is the point of this thread? Of course i like riding FG.
Wheelnut
Bikes: Fuji feather, Dahon Boardwalk S1
Quoted: 25 Post(s)
I dont think there is such a thing as a bike being too nice to be a singlespeed. There are a lot of handmade track bicycles or keirin frames that are really expensive and nice and are meant to be singlespeeds.
