Stem Question
Stem Question
Old 12-19-19, 09:41 AM
smoore
smoore's Avatar
Bikes: Primary ride now a LOOK 585-Love it.
Quoted: 112 Post(s)
Liked 49 Times in 37 Posts
Stem Question
Guys,
I have a 90mm x8 degree stem on my Serotta and I want to try a 100mm stem. BUT don't want to increase the stem height. Lengthening the stem effectively raises the stem, correct?
So what's my best approach? I don't need the stem higher, just longer.
Thanks!
smoore is offline
Old 12-19-19, 10:07 AM
masi61
masi61's Avatar
Quoted: 713 Post(s)
Liked 136 Times in 102 Posts
17 degree stems are designed to be near horizontal for road bike typical head tube geometry. So changing to a longer stem would remain constant in height. If you like the slight upward rise of your 8 degree stem, and you want a longer one but no higher - you may have to play around with longer stems of slightly different angles.
Which direction is your 8 degree stem facing -upward or downward? A picture would be helpful here.
masi61 is online now
Likes For masi61:
Old 12-19-19, 01:03 PM
freeranger
freeranger's Avatar
Quoted: 221 Post(s)
Liked 321 Times in 206 Posts
Not a math major, but doesn't seem that 10mm diff with an 8 degree slope would be noticeable. That being said, at Jenson, saw several 100mm stems with 6 degree rise.
freeranger is offline
Old 12-19-19, 02:11 PM
caloso
caloso's Avatar
Quoted: 2539 Post(s)
Liked 1,789 Times in 884 Posts
The simplest thing would be to take out a spacer, if you have one.
caloso is online now
Likes For caloso:
Old 12-19-19, 03:03 PM
shelbyfv
Quoted: 2151 Post(s)
Liked 1,971 Times in 1,064 Posts
+1 That will stretch you out, as will the longer stem. Cheap and quick to see how you like it.
shelbyfv is offline
Old 12-19-19, 03:59 PM
hcgaloi
Bikes: Spcialized RockHopper (free) 1992 Trek T100 Tandem ($220) 2006 Quintana Roo Seduza ($350) 2016 Giant Fastroad ($1100)
Quoted: 46 Post(s)
You can use this stem comparison tool:
Stem Comparison Tool | yojimg.net
hcgaloi is offline
Old 12-19-19, 04:15 PM
smoore
smoore's Avatar
Quoted: 112 Post(s)
Thanks guys, good info. I'm not too concerned about the "looks" but I just don't want to sit up any higher that already am. How can I make believe I'm in the TDF if I'm sitting up like a tourist??
smoore is offline
Old 12-20-19, 07:36 AM
Koyote
Quoted: 2586 Post(s)
Liked 3,361 Times in 1,515 Posts
This question belongs in a math forum...In the trigonometry subforum.
Koyote is online now
Old 12-20-19, 09:15 AM
Ogsarg
Quoted: 502 Post(s)
Liked 737 Times in 317 Posts
Or use a compass and graph paper and draw the angle of your stem extending out it's length. Then use a longer line to determine what angle the new stem needs to be to get the same height.
Ogsarg is offline
Old 12-20-19, 01:46 PM
caloso
caloso's Avatar
I plugged your numbers in this tool and the 100mm stem is only 2mm higher. You could eliminate that difference with thinner bar tape.
Likes For caloso:
Old 12-20-19, 02:12 PM
smoore
smoore's Avatar
Quoted: 112 Post(s)
Ogsarg, compass and graph paper...should I go find my slide rule as well? Whadda think I'm old or something?
Caloso, now we're talking. Thanks for doing the math for me and I'm thinking if I replace my current bar tape with Saran Wrap...that ought do it! UDAMAN!
Thanks guys and Merry Christmas.
smoore is offline
Likes For smoore:
