Tingley fingers?
Tingley fingers?
Mods, please relocate if this in the wrong forum....
Anyone get buzzy hands when cycling? I googled it, and it seems it's a common occurrence, but what I experienced today is hard for me to explain. Today I was indoors, on a spin bike. It was a short workout, HIIT, about 30 minutes including warm-up and warm-down.
When I was finished, I noticed that my fingertips on my left hand were tingly. Just the tips, and it was every finger, including my thumb. It went away in about a minute or two after I stopped teh workout. I've experienced something like this when cycling 2 hours on gravel, but I always chalked that up to the buzz from the gravel. There's no gravel in the bedroom. : )
On my google searches, I saw some causes, like carpal tunnel, or ulnar neuropathy, but from what I can see, these affect some of the fingers, not all of them. I had a tiny tingle in each fingertip. Any ideas? This is the first time I've had it on the indoor bike. I've had it many times on the two hour outdoor gravel rides.
Clark W. Griswold
Quoted: 4335 Post(s)
Liked 3,958 Times
Things could be poorly set up on your bike and you are not able to get blood to your finger tips. A lot of those spin bikes don't seem to be set up like a bike or super adjustable in any sense other than maybe notches on the "seat post"
Quoted: 338 Post(s)
Liked 408 Times
Bad sign.
For me, sliding the saddle slightly backwards (and reviewing the height then) fixed it. I was a bit too forward which meant I wasn't quite balanced on the bike which was apparent if I took my hands off the bars. This put just a little bit extra pressure on my hand which would make my left hand pinky tingle during hard efforts.
Old fart
Quoted: 3583 Post(s)
Liked 3,396 Times
Do you wear gloves? What kind of handlebars (i.e. do they offer multiple hand positions)?
Bad sign.
Indoors I don't wear gloves, outdoors I don't unless it's cold. The spin bike's bars and my outdoor bike's bars (Moloko bar) do have a number of different position, but indoors I only use one position....like a straight bar, somewhat narrow grip, and the bar is flattened in the section that I grip. I just sat on the spin bike, and I do think it puts a lot of pressure on my palm. I will change position and try again. I did some googling to see what the arteries that supply the fingers look like, and the main feed to all fingers is from section in the palm of the hand, exactly where all the pressure is on the bar. I must be putting too much pressure on it. It's interesting that I have never felt it on the spin bike before, but it could be because I've gained weight recently and my core needs a little strengthening.
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2571 Post(s)
Liked 5,605 Times
Sounds like either nerve or blood supply deficit due to compression. Put on your cycling gloves indoors and see if that makes a difference.
Free pseudoquqckery advice served daily.
Heck Yeah wear cycling eyewear on my stationary so my eyes don’t dry out in front of the fan.
Likes For rsbob:
Randomhead
Liked 3,687 Times
Id doesn't take long at all to get numbness if you are compressing one of the nerves running to the hand. Move your seat back a little or get a longer stem.
Veteran, Pacifist
Quoted: 3897 Post(s)
Liked 4,829 Times
How tightly do you grip the handlebars?
Maybe almost not at all for indoor riding. There's no gravel in the bedroom - or potholes, turns or loose stuff, so relax the grip.
Quoted: 667 Post(s)
Liked 529 Times
i get that from spinal stenosis of the vertebrae in my upper neck. Sometimes it is just finger tips, other times my whole hands tingle continuously for weeks/days
Take time to stretch and rotate your upper back. chiropractors are a godsend.
while scary it really isn't a big issue, I've lived with it for decades.
Have to take exception to the longer stem suggestion. For me the single biggest benefit has come from a more upright riding position. This not only takes pressure off the upper back but more importantly put your neck in a more natural alginment.
Guy don't want to hear this but a recumbent will almost certainly cure this problem for you.
Add thick bar tape on handlebars. I also bend my elbows to keep my upper body from pressing down to hard on my hands. Riding indoors you sit in one positron for way too long.
so constantly move hand positions during a ride. Many use rocker plates to give movement to their bike to relieve pain.
Quoted: 1364 Post(s)
Liked 1,676 Times
Indoors, not hard at all. I just kind or rest them on a flat section of the bar. There does seem to be a lot of weight though on my hands.
I sit up some times and ride with my hands down to my sides for 10 minutes. I have a Kicker bike and it I am riding a coarse or workout that is not using the up/down tilt. I will tilt the bike up all the way to relieve pressure on my back and arms.
Veteran, Pacifist
Liked 4,829 Times
The hands & wrists only function is to guide/turn/brake the bike from multiple hand positions, not support your upper body.
Likes For Wildwood:
Yes, I've noticed lately when riding outdoors, my arms sometimes get tired after and hour or so. That's something new. I've gained some weight, and I also haven't done anything but bike. I think when I bike, the rest of the body just wastes away! I'll start doing some work with my Power Blocks again.
Dirty Heathen
Quoted: 889 Post(s)
Liked 906 Times
Everyone's physiology is different, so what works for one, may not work for others.
In my case, going to a lower, wider cockpit with a 24* flared 'gravel' bar fixed that issue for me. Yeah, there's definitely more weight on my hands, but it's where it is that makes the difference.
