1969 Colnago Super
Bikes: Several Italian bikes from the 50's - 83, 4 English Lightweights (1949-1970), Riding bikes-Trek 760, SOMA Triple Cross gravel bike, SOMA SAGA DC touring bike, Pivot Les Fat for winter riding and long distance bikepacking. One modern Carbon bike.
Quoted: 36 Post(s)
Liked 104 Times
1969 Colnago Super
Trying to date what I believe to be a 1969 Colnago Super. The head tube lugs changed after 1970, but my bike has the 1970/71 slightly more fancy, ornate design. But the bottom bracket has the 1968/69 9 hole pattern, and the rest or the bike fits the 1968/69 standard. My thought is the bike was built right at the end of the 1969 season with a mix of 'old' 1969 lugs and new 1970 head tube lugs. Thoughts?
Likes For M1T:
Quoted: 4510 Post(s)
Liked 6,377 Times
Likes For merziac:
Likes For VtwinVince:
Quoted: 5888 Post(s)
Liked 3,471 Times
Likes For bikemig:
my name is Jim
From what I know you seem to have called it pretty well as to the date. Beautiful bike.
Flickr Albums
ebay: cicloclassico
70 Pogliaghi ItalCorse, 72 De Rosa, 72 Masi Gran Criterium, 75 Masi Gran Criterium, 77 Melton, 79 Bianchi Super Leggera, 79 Gios Super Record, 81 Picchio Special, 82 Guerciotti Super Record, 82 Colnago Profil CX, 83 Colnago Superissimo, 84 Fuso
Flickr Albums
ebay: cicloclassico
Likes For BlueDevil63:
Quoted: 3464 Post(s)
Liked 2,829 Times
Interesting bike.
the transfer(s) in the fork blades are really curious. Non standard, maybe an attempt to cover a scratch?
the chainstays are really short for the time- the axle is half way back about and the tire to seat tube gap would almost vanish with the wheel all the way forward in the dropouts.
the mix of metal features is what I recall of some way back. In 1972 these were rare at the races, the features varied. Unpresented are the appearance of the fork reinforcements if any.
a bit early for the brazed on cable guides on the bottom bracket in general, there are always exceptions.
Do attend to the brake block alignment on the front brake. (Actually, check them all ) Consider shortening the cable housing a bit for the rear brake.
This is my favorite graphics package.
Quoted: 36 Post(s)
Liked 104 Times
I've had this Colnago sitting a box for 6 months and just put it together for some quick photos. I'll have all the stuff triple checked before riding... Broke my neck and back this summer as a result of riding a 130 mm rear dropout with a 126 mm (unknown to me at the time) wheel. Never again. It does have the inside and outside correct front fork blade supports.
I posted this question/pics on another vintage site and the replies were mixed. The consensus, if you can call it one, was this easily could be a late 69 bike, that it wasn't an early repaint, and that manufacturing details and processes were not what they are today. At appx. 51 years old, who knows, but it is a cool bike and I can't wait to ride it. Thanks for the replies!
Likes For M1T:
Garage tetris expert
Bikes: A few. Ok, a lot
Quoted: 387 Post(s)
Liked 692 Times
That’s one heck of a beauty!
Whenever you get the chance, would love to see more photos, parts details, some history if you have any. Thanks for sharing, what a treat!
Liked 2,829 Times
A bit surprising not to sport Campagnolo brakes. They were introduced in 1968, Colnago was receiving them, traditionalists may have been used to Universal’s, but one did not go to Colnago for a budget build.
that short rear triangle suggest to me this bike was “to order” not a standard frame.
Quoted: 659 Post(s)
Liked 595 Times
Great find. This is when knowing the story of the bike gnaws at the curiosity. Nice!
Quoted: 211 Post(s)
Liked 199 Times
Absolutely Phenomenal !!!!!
I would hang it on the wall in my Sport room !!!!
Of course , I would ride it a " few times" before
VERY RARE !!!!
Congrats !!!
VERY RARE !!!!
Congrats !!!
Quoted: 1607 Post(s)
Liked 2,216 Times
1983 Colnago Superissimo on Flickr
Crawlin' up, flyin' down
Quoted: 1025 Post(s)
Liked 2,525 Times
So it isn't shocking that the 1969 and 1983 geometry look so similar, but it is at little bit, shall we say, noteworthy. I suspect that is why repechage noted it.
Likes For bikingshearer:
Liked 2,216 Times
bikingshearer - Thanks that does make sense. The Le Champion of 1972 had much longer stays.
1973 Motobecane Le Champion 24" on Flickr
As did the Bottecchia (27"wheels)
1972 Bottecchia Giro D'Italia (Professional conversion) on Flickr
Liked 2,829 Times
Help me understand this statement. My 83 doesn't look much different to my eye.
The rear end dimension with the axle all the way forward is 410 mm. A lot more room between the seat tube and the tire.
Colnago incrementally tightened up the bikes as time went on.
Liked 2,829 Times
In the late 1960s, racing bikes were, generally speaking, still sporting longer wheelbases and longer seat stays than either the OP's or yours. Over the next few years, wheelbases and seat stays shrank until, by the mid-1070s or so, most racing frames were sporting the shorter dimensions. The quality of road surfaces had something to do with it, and at least in the US, the relative popularity of criterium racing helped drive the trend. The former made giving up a bit of stability and compliance for a bit more snappy handling viable. The latter made it downright desirable, at least stateside. The fact that the pros rode it made it even more desirable.
A '72, and 73 super same size, 410, 407mm
top tube on the '68 is 1 cm longer.
the "'70's" geometry was pretty stable.
When short reach brakes, and the revised shorter dropouts arrived, things began tightening up.
In the 80's the top tubes got a bit shorter again too for a given size, on average 5mm
Liked 2,525 Times
I've had similar experience with Cinellis. My 1965ish ones (64/61.5 cm ctc) have 44.5cm chainstays, the 1972ish one I used to have (60/57.5) had 43cm ones. Interestingly, the 1965ish ones have a 108cm wheelbase while the 1972ish one came in at 102.5cm. Even allowing for the size differences, that's a significant shortening of the overall frame.
Quoted: 874 Post(s)
Liked 2,287 Times
Having just got my 75 the observations make sense. Mine has the short dropouts with the externally mounted springs for the axel stops. I am still able to have a smooth shifting high and low range with a 53/41 chainring set up and a 28 tooth low on the FW with a NR derailleur. For such a short wheelbase bike it tracks very well and has great stability in tight corners. I don’t know how much if any they changed through the years, but the person I bought mine from also had a 73 and said the ride was identical . That’s why he sold me mine.
Liked 2,829 Times
for me, when the seat stay top eyes had COLNAGO cast in, that is the confirmed next phase of the geometry.
as noted this was a broad brand progression.
masi Cinelli, Gios ( they shortened up early )
Pinarello all got shorter.
heve to give the racers something to trade up for.
Likes For repechage:
Bikes: Several
Quoted: 207 Post(s)
Liked 1,042 Times
According to Velo Retro, Colnago began using the "club" logo after Michele Dancelli's Milan San Remo win in 1970. The playing card decals, as I understand it, were 1970 only.
This is my 1969 Super.
Likes For Brad L:
