Mechanical Issue
Mechanical Issue
Good afternoon!
I own a 2006 Honda Shadow Aero 750cc. It stopped working over a year ago and I've never worked on it before so I exasperated myself trying to figure out what was wrong with it. I ended up getting a carburetor rebuild kit and upon removing the carburetor I found the coolant had turned into a toothpaste consistency green goo. Carburetor was the cleanest thing on the bike but I replaced the parts anyway and then flushed the coolant. I put a vinegar water mixture in there, let it sit overnight, flushed and put coolant in it again.
Bike finally works, but now when I throttle it, it stops putting gasoline into the carburetor at about 50% throttle. Just cuts out and the engine spins down. I just did an oil change to be safe but that's not the issue it seems.
I'm kinda at a loss but if I had to guess Id say I messed up the carburator when I opened it up. I opened it up again and it does indeed stop putting gas in there when I throttle it too much. I don't know how to fix it.
Any tips or tricks? I'm kinda out of beer and patience here. 😅
Thanks!
Thanks!
Quoted: 6193 Post(s)
Liked 4,808 Times
buy more beer. Read some other threads here and think about it some. Welcome if you care to stay!
Likes For dsbrantjr:
Liked 2,968 Times
make sure the hose is not collapsing. If the rubber lines are old, the likelihood of it squeezing off the feed is high. While the hoses are off, snake out the ports that the hoses go to. You can have pressure & not have enough volume.
-Oh Hey!
-Oh Hey!
Clark W. Griswold
Quoted: 4352 Post(s)
Liked 3,990 Times
I wonder if any cyclists join up on motorcycle forums that aren't also motorcyclists and not realize it before hand?
I wonder why Honda called that bike aero? It would seem to me those crotch rocket style motor sickles would be more aero v.s. the more upright position like the Harley type stuff? I don't know.
Liked 2,968 Times
Likes For Troul:
Really Old Senior Member
Good afternoon!
Thanks!
Thanks!
Fuel I can understand.
Did you replace the fuel filter? It may be restricted enough to allow only partial flow. You need gas and you only get 1/2/ of what you need and it dies because the mixture leans way out.
You may have to replace a couple times if you didn't clean out the tank & lines.
Likes For Bill Kapaun:
Bikes: Schwinn Varsity
Quoted: 1931 Post(s)
Liked 742 Times
What type of coolant was in it and what type did you replace it with. some of the newer machines are coolant specific.
Very Senior Member
Bikes: Giant Quasar & Fuji Roubaix
Quoted: 413 Post(s)
Liked 343 Times
Like Bill said, it's starving for fuel, whether it's the filter or dirty lines or even at the screen before the jet, it's not getting enough fuel and leaning itself out till it dies, unless you back off the throttle before it fully stops. I'll bet the tank is full of rust too. Give me a good old Harley any day. At least they're worth working on.
Quoted: 194 Post(s)
Liked 204 Times
I will gladly exchange it for any of my Romet folders, all of which run up to 'full throttle' if you really give the pedals enough 'gas', and will ensure you stand out from the crowd at your next bike meet.
Spare 'coolant' can be carried in the front basket to make sure it remains cool, and has never been known to take on the consistency of goo. What is more, the 'coolant' can be shared with friends, although frequent 'replacement' is recommended.
Likes For Buzzkill53120:
BMX Connoisseur
Bikes: 1988 Kuwahara Newport, 1983 Nishiki, 1984 Diamond Back Viper, 1991 Dyno Compe
Quoted: 399 Post(s)
Liked 108 Times
The problem is one of the jets in the carburetor is plugged, It happened on one of my old CBR600's. Don't waste time on a carburetor rebuild. Go out and buy some "Seafoam green" and put it in your gas and drive around. Mine were so plugged it took two cans of the stuff. Try to keep it close to the speed where it stops working, and you will feel a nice surge in power once it's unclogged.
Likes For coffeesnob:
Likes For Bigbus:
